Question about Gateway 2520915 Keyboard
Shift key turns cpu off
Both shift keys turns my cpu off. a complete shut down.
It wouldn't just turn the CPU off, since the CPU is only the processor. It would turn the whole computer off.
Posted on Mar 20, 2009
  • MaxxFordham Mar 20, 2009
    (By "processor," I hope you know that just means the one big main chip inside the computer--CPU = central processing unit, a.k.a. processor chip.)
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
What do i do - my iMac 2011 won't turn on - I just hear a whiring sound every so often
Hi Noelle
Probably a bit late now.... but for others
Determine if Hardware Problem or Software.
Remove all peripheral plugs. Just in case of bad shorted device.
Restart & hold Cmd Shift Option Delete keys down. 4 Keys
Resets Parrameter Ram. Eg Clock & mouse settings.
But might help.
Reboot with Shift key Held down. (Safe Boot)
Does it boot up?
Boot with Option key down & choose "Recovery" startup just to prove hardware (CPU) is working.
Internal Hard Drive may be damaged!
Plug another Bootable drive into USB or FireWire Port and reboot with option key held down.
If you can get your Mac to boot.... Install a clean OS X onto a USB memory Stick (16 or 32gb)
Keep this for Booting Problems & Emergency Booting & access to repair software e.g. Apple Disk Utility
or My Favorite Utilities
Bootable Backup Software
http://bombich.com/download
Directory Repair & File Testing & Fixing
DiskWarrior 5 The Disk Utility for Mac Disk Repair Mac Directory Repair...
Cheers
How about an Tick of approval for the effort?
May 13, 2015 | Computers & Internet
I hit the shift key too long on my keyboard at work and it asked it I wanted to filter the keys Or whatever and I clicked ok. Now my keyboard is not working. What do I do?
Do you mean your keyboard is now not responding as it should do, or completely not working ?
If you press the SHIFT key 5 times in succession, a box appears asking if you want to change the 'sticky keys' function in Windows.
This means that instead of holding down the keys for SHIFT. CTRL, or ALT, you can just press them once and they will lock on (like an old style manual typewriter used to behave).
It's most likely you now have sticky-keys turned on, so your keyboards going silly.
Press the SHIFT key again 5 times, and that initial box will appear again. Make sure you click on CANCEL using the mouse only. That should fix it.
Apr 09, 2010 | Computers & Internet
Screen goes black when turned down and it does
try removing suspend on lid close .. refer to your laptop manual .. try this too disable herbernation also ..if nothing works check if you have latest graphic driver !! it might be a problem with ACPI .. but my two solutions should work !!!
Mar 10, 2010 | ASUS W7S-3P100E T7500 PC Desktop
Dell inspiron 1705 9300 17inch shuts down after 15-20 mins win xp
first thing to do is run psa test. turn off laptop. remove batt use ac adapter alone. press and hold on Fn key then press power button once. complete the quick test check if you will be getting error codes like 0142 , 0146 this is hard drive replacement.
Oct 01, 2009 | Dell Inspiron 1501 Notebook
When I turn on my computer I get a grey screen for a few minutes until a blinking folder with a question mark in it appears. Often, my computer shuts off after the question mark folder disappears. I have...
The blinking question mark means that you macintosh can't find a bootable disk. It has nothing to do with the VGA connection. More than likely, your directory structure on the disk is bad. An excellent product to fix this is Disk Warrior. It has saved more hard drives for me than I care to think about. Worth every penny.
As far as booting up from a disk, just put in the CD and hold down the C key until you see the spinning icon.
You could also try these to things if you don't want to purchase disk warrior, but I don't think they will work. Hold down the shift key while you boot until you see the apple logo. The shift key is to boot it in safeboot mode. Or, you could also reset the pram:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Jul 04, 2009 | Apple Mac OS X 10.4
The button on my Kia Sedona gear shift is stuck
I have the same problem, its the screw in the gear shift, take it to kia they will replace it,
Jul 02, 2009 | 2003 Kia Sedona
I can't get a pound sign when I shift 3 what do I need to do
I would initially shut down the machine completely and wait about 10 seconds and restart.
What symbol do you get when you press Shift 3?
Do all the keys on the keyboard depress when you press them? You may have a random key that's sticking thus causing you to get different key combinations.
Hope this helps. Please remember to rate this information.
Thanks
Dec 03, 2008 | Logitech 967224-0120 Keyboard
Boot Problem in TASCAM 2488
Turning the power off with out going through the shut-down process will sometimes trash the hard drive making it un readable. To force format of hard drive hold down the shut down, send, shift and quick routing keys at the same time then turn power on. This will format the HD. When finished the display will show "Factory initalize complete" "please power off" NOTE you will lose every thing on the HD including the demo song.
Jun 19, 2008 | Tascam 2488 Portastudio Multitrack...
Gateway 2520915 Keyboard Logo
139 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
