1997 cadillac devile ,northstar
Car starts but will not turn over just backfires.
  • 115 Answers
Is it backfiring while you are cranking the starter? Sounds like the firing order of the spar plugs might be amiss
Posted on Jan 26, 2009
What is the normal operating temp in cooling system of a northstar engine?
For my 1997 Cadillac Deville limousine with 4.6 L Northstar it should be 196 to 205 deg. And top out at no more than 230 deg. F. Check multispeed fans for high speed turning over and antifreeze fluid level in overflow tank. Also, check for head gasket leaks through tailpipe which will show up as steam when you start the engine.
Sep 05, 2014 | 1997 Cadillac DeVille
Why does my 1999 cadillac devills acclerates high without pushing the gas pedal?
have the TPS (throttle position sensor/solenoid) checked. is the check engine light on?
Jul 23, 2014 | Northstar 1999 Cadillac Deville Air Intake...
My 1997 cadillac deville, northstar w/85, regular oil changes, burns almost 2 quarts of oil every change. It is not leaking.
If your car is losing oil, and if there is no evidence of oil leaking, there is no question that it is either losing it through piston rings or through the head (head gasket or valve guides).
Best thing to do is use a HEAVIER WEIGHT oil than specified for the vehicle when new, regularly monitor your oil level and be sure it never falls below one quart low, and consider having the engine overhauled when you start noticing a performance deficit or hear mechanical noise (such as rod knock) from the engine.
Apr 18, 2014 | 2003 Cadillac Deville
1997 seville not getting enough gas to start
For the backfiring, there is a chemical additive process for cleaning the intake system of Northstar V-8's. This is suppose to be done at a Dealer and the solvent stays inside the engine 8 hours or more. It is rumored to be written as a service procedure in the Owners Manual.
Check your battery. A shorting battery will activate the antitheft system. Try a new fuelpump Relay
Feb 12, 2014 | 1997 Cadillac DeVille
2002 cadilac dts devile running hot
You have a Blown Head Gasket.. It is a 4.6 Northstar Engine. Very Common around 90-105K
Apr 10, 2013 | 2002 Cadillac Deville
1998 Cadillac devil leaking all water out
if it is leaking on the trans side of car it is probally the water pump on the Northstar engine.
Jul 27, 2011 | 1998 Cadillac DeVille
Diagram of cadilac northstar engine exploded view of a cadilac northstar engine
need 1998 northstar engine diagram to change the head gasket thanks
Sep 30, 2009 | 2001 Cadillac DeVille
Computers & Internet Logo
David Payne
David Payne
