Bauhn tv Model Ax-42Fd1 after applying power unit switches on with remote only ch number for approx 2sec. then only audio
    Genius:
  • 1,003 Answers
Replace power supply or inverter board
Posted on Jan 22, 2013
5 Suggested Answers
  • 458 Answers
SOURCE: TV will not power on
There is not an internal reset for this. You would need to check what voltages you are getting from the secondary side of the power supply, this would then indicate if the problem is with the main board not starting up the system or if the power supply has a fault. If you have a multimeter then you can carefully check for 24v 5v & 12v supplies. If you are not getting any voltages then the primary side of the power supply may be at fault. The first thing to check would be the fuse at the incoming mains supply on the power board, if this has blown then suspect one of the senmi-conductors & check to see if any of the capacitors are swoolen if so replace them.
Posted on Dec 08, 2009
  • 668 Answers
SOURCE: I have an LG LCD
This is a real odd problem. If these are the only channels this occurs on, I would make sure that the set is not in SAP audio mode. This is switchable through it's on screen audio menu. If you have other sets in the house that you can also receive these channels, see if they have sound. If not, it has got to be a cable company issue. If they do, I would check with LG to see if they have a software upgrade that addresses the problem. Their customer service number is 1800-243-0000.
Most manufactures are pretty tight with their software so they want to deal with the customer one on one.
I hope this helps,
Skyassoc
Posted on Dec 11, 2010
gopakumarg43
  • 74106 Answers
SOURCE: Can I decode a Bauhn lcd tv with built in dvd player Model Number AT- 24FHDC1
No. It can't.
Posted on Aug 27, 2012
SD Tech
  • 14553 Answers
SOURCE: not responding to remote , automatically changing to AV1 , AV2 ..PC ..ect.
First you have not indicated the brand or model but that aside the issue appears to be a bad micro switch or the keyboard with the controls on this set, I would suspect the source or TV video button first, not the plastic button itself but the tiny switch it activates, that is bad---have someone get at that and disable or remove that and the set should again function in a normal way.
The micro switches are momentary and should only operate when pressed, the problem is they fail, and with no one pressing the switch activates on its own.
Posted on Dec 11, 2012
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
Will a sansei urc-501a remote have a code for a bauhn tv model actios fullhd/led/lcd atv40-014
One way to find out is to use the code search function in your Sansui (?) remote to find something that will handle your Bauhn TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Sep 16, 2016 | Televison & Video
Remote code for Bauhn ATV-BA32DV2
bauhn p v r setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... bauhn universal remote control tv but i had vivo tv how ican set up that The universal ... ATV-BA32DV2, have done initial setup, but screen says have to scan ...
Remote code for BAUHN TV model ATV-19HED - TVs - Home theatre ...
forums.whirlpool.net.au > Home theatre > TVs
WhirlpoolDec 14, 2014 - I've mislaid the remote for this TV and I was wondering if anybody new how I could get hold of BAUHN remote IR codes. I've looked everywhere ... 32" (81CM) HD LED LCD TV $222
May 29, 2014
Bauhn 24" Full HD LED LCD TV with DVD
Jan 12, 2013
More results from forums.whirlpool.net.au
[PDF]32" (81cm) HD LED LCD TV
Feb 03, 2016 | Televison & Video
Bauhn 80cm tv model no. ATV-32HDC1N
Could be internal power supply failure.
Dec 25, 2013 | Televison & Video
Need to replace remote GL21A-C2 for Bauhn tv
Just visit the site pointed out here, and check. There are setup code list to some popular models remote controls. Check them, and find out, which remote has setup codes with your brand TV, and select that one. In most cases, Philips universal remote will have it.
Feb 28, 2013 | Televison & Video
Hook up to view dvd's to tv video cables with yellow white and red plug ins.
Hello, here is a sample for auxilary connection for the chdvd300: . Use the AV (Audio/Video) cable
provided to connect the DVD player to
your TV as shown in the diagram.
. Your TV must be equipped with AV
inputs like those pictured to the right in
order to connect this unit.
. If your TV does not have AV inputs, you
will need a RF Modulator to connect this
player to your TV's antenna/cable input.
RF Modulators are available at major
electronics retailers.
Connect the DVD Player to
your TV
CH-DVD 300 Quick Setup Guide
. The goal is to see the DVD player's splash screen on your
TV. To do this, select the Video Input channel on your TV
that corresponds with the input the player is plugged into.
This procedure differs among TVs, but is normally done by
pressing the VIDEO IN or INPUT button on the TV's remote
control to select the Video Input.
. When the DVD player's splash screen appears on your TV,
you're ready to go!
4 Select the VIDEO INPUT on your TV
TM
Pr/Cr
PROGRESSIVE SCAN
COMPONENT VIDEO OUT
Y Pb/Cb
VIDEO
S-VIDEO
L
R
COAXIAL
TV
ANTENNA / CABLE IN
CH-DVD 300
VIDEO R - AUDIO - L
. Plug the DVD player's electrical
plug into a wall socket or power
strip.
2 Plug-in the Power Cord
3 Turn on the DVD Player and your TV
. Press the POWER BUTTON on the front panel to turn the
DVD player on. The POWER LED should now change
from RED (STANDBY MODE) to GREEN (ON).
POWER LED
You can find an quick install wiring schematic at retrevo.com, just type your model number in the search window.
Aug 11, 2010 | Cyberhome CH-DVD 300 DVD Player
I have a tv sky box in lounge and 2nd tv in a different room connected by a co ax cable. I need a desription or a diagram to get everything working. It worked prior to having a new carpet fitted and the...
Check first that the Co-Ax cable is firmly plugged into your SKY box in your lounge.
(I'm assuming that the carpet fitters did NOT put a nail thru your co-ax cable or pushed the cable onto any metal carpet grippers???)
If they might have done this accidentally, then, that's why it doesn't work!
Then make sure that the co-ax cable is plugged firmly into your second TV. Sometimes the central connector within the co-axial socket becomes loose and needs nipping back together with a pair of long-nosed pliers.
I'm assuming that you have plugged the Infra-red remote eye unit back into the second TV aerial socket - before you plugged the co-ax cable back in?
If you have, press the SKY remote to see if the Infra-red LED can be seen in the remote pod.
Finally, make sure that you have selected the correct channel number (or Input) on your second TV remote to select SKY.
Nov 18, 2009 | Televison & Video
Televison & Video Logo
327 people viewed this question
Top Televison & Video Experts
Electro Med Services...
