Question about Danco Faucet Cartridge
How di i replace the danco 3s-11h - Danco Faucet Cartridge
What is the Danco Flat Washer 2-1/4"X3/4"X1/8" made of?
The Danco Flat Washer 2-1/4"X3/4"X1/8" ismade of neoprene rubber.
Jul 15, 2012 | Danco Flat Washer 2-1/4"X3/4"X1/8"
Forgot my password 038-913213
I have a nice little router like this and I'm about convinced you have to disconnect the power then push the Orange button on the back for at least 3s while you plug in the power.
(you might need a paperclip to push the button which is almost inside the enclosure)
This should return your device to the factory default settings!
Sep 26, 2011 | D-Link DI 514 Wireless Router (DI-514)
Replaced danco cartridge 88198 three times. only
Danco is an after market faucet parts company that recreates parts cheap for hardware supply chains and such. You would be ahead to try and find the brand of faucet you are trying to repair and get OEM parts. They will probably cost a little more, but will hold up a lot better. I hope this helps.
May 18, 2010 | Danco Faucet Cartridge
Does danco offer a replacement cartridge for american standard cartridge O28610-0070A
Danco is an aftermarket supplier of plumbing repair parts for almost all major brands. Look for a danco part that looks like the part you need then check the "compatible with" list on the package.
Apr 12, 2010 | Danco Faucet Cartridge
Looking for cartridge for Tuscany Brass Tub Faucet Single Handle appears to be Ceramic Disk Type
While there are several cartridges that look similiar to what you have posted, Danco it self is an aftermarket parts replacement business. From my point of observation, your posted pic is of a Delta stem which visually has some distinctive attributes. Most every thing Danco makes is a copy or OEM replacement part packaged under their name.
Mar 16, 2010 | Danco Faucet Cartridge
How to modify Danco handles to work on Valley II faucets
Do not modify the handles, just buy the pieces missing. they are available through Danco. Even though i prefer using original parts.
Jan 10, 2009 | Plumbing
Danco Faucet Cartridge  Logo
62 people viewed this question
Top Danco Home Experts
Donni Steen
Andrew Bugbee
richie46
Are you a Danco Home Expert? Answer questions, earn points and help others
