Question about Precor EFX 5.25 Elliptical Fitness Crosstrainer
EFX 5.25. Erro code 30. I had mice chew up the wiring between the two circuit boards. I have replaced the lower board and the wiring harness. Still shows error code 30
  • Precor Master
  • 6,694 Answers
If you wish to get some details About treadmill Error codes ; check the site linked here. Pull up older posts almost all treadmills are listed . Surf the site with patience.
http://electro-medical.blogspot.com/
Posted on Mar 07, 2016
  • Precor Master
  • 914 Answers
Precor Error 30, 31, 32 and 33, Communications Error Probable Cause 1. Bad interconnect cable between upper PCA and lower PCA.
2. Interconnect cable is mistakenly plugged into the CSAFE connector at the upper PCA.
3. Elliptical 5.17 equipped with old software version 1.01 in upper and lower PCA.
4. Upper and lower PCAs have mismatched software.
5. Another component plugged onto the PCA is overloading the +5VDC power supply.
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Test unit with a know good interconnect cable or test the interconnect cable for continuity. Replace interconnect cable if necessary.
  2. Disconnect the interconnect cable from the CSAFE connector and attach to the proper position on the upper PCA.3.
  3. Replace the upper and lower software of the 5.17 elliptical with the most current versions.4.
  4. If one of the PCAs is found to have software version 1.01, replace it with the most current software version.
  5. Disconnect all components from the upper and lower PCA leaving the data cable connecting between the upper and lower PCAs and the AC power going to the lower PCA. If the unit shows any error other than the error 3x, reconnect components one at a time. Reset power between each newly connected component until the error 3x reappears. Whichever component was last connected when the error 3x reappears, is the cause for the error. Replace the faulty component.
  6. Test unit with a known good lower PCA. Replace the lower PCA if necessary.
  7. Test unit with a known good upper PCA. Replace the upper PCA if necessary.
Precor Error Code 30 31 32 33
Posted on Aug 29, 2014
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Just replaced the circuit board on my whirlpool 30 inch double oven..... no codes showing..... now the lower unit is getting warm, event when everything is shown off.
Recheck your wiring, some how you have miss-wired the lower element. Half of the current to the element if direct from the terminal block (L1-Black), other is from the relay on the board (L2 -Red). I hope this helps as this post was 6 days ago. Good Luck
Apr 08, 2014 | Whirlpool GBD307PRS Stainless Steel...
Is there a replaceable fuse for the efx 546i
Battery operated 546s have a fuse on the lower board, plug in models have a fuse on the lower board and fuses in the power inlet.
Jan 01, 2014 | Precor EFX 546i Elliptical Version 4
How to repair a 546 efx precor
Assuming the buttons are working, the numbers change on the display, and the incline works, it may be the lower circuit board or the generator. If it is a very old unit, it may be the electromagnet or the data cable that connects the two circuit boards.
May 08, 2013 | Precor Efx 546 Elliptical Version 2...
After cancelling auto clean I received an error code F14
"F1-4" error code means "Runaway temperature, lower oven".
The first thing I would do is check the lower oven temperature sensor. Pull the range out, remove the rear cover and locate the sensor wire harness to the control board. Measure the sensor resistance at the control board. Normally it suppose to be about 1100 Ohms at the room temperature. Also check the sensor wire harness and the sensor plug.
If the resistance reads wrong then replace the oven sensor.
If there is nothing wrong then the control board has to be replaced.Here is the sensor to order if it is bad.Here is the control board.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | Maytag MER5775Q Electric Kitchen Range
Frigidaire Affinity washer (LAFW3511KW0) with an E41 error. I have unplugged to reset (no change), checked the stricker (fine), removed outer seal and disconnected and reattached (I also received an E41...
Install the door lock/switch assembly with the door switch harness disconnected but "jumped". Jump a wire between the wire harness terminals and if the error code (E41) stops appearing when the machine is started, the door lock/switch assembly is indeed faulty and needs to be replaced.
Check the continuity of the door switch harness connecting the switch and terminal J2 of of the control board if the error code (E41) still appears every time the machine is started after putting a jumper wire between the door switch harness terminals.
Make sure the connectors are clean and snugly connected to both. Replace the wire harness if you are skeptical about its condition. Disconnecting the door switch wire harness (J2) from the control board and putting a jumper wire between the leads of terminal J2 on the control board will directly confirm the condition of the wire harness and the board itself. The wire harness is the problem and must be replaced if the error code E41 stops appearing. On the other hand, consider replacing the control board if the error code still flashes even when the leads of terminal J2 on the board is shorted ("jumped").
Aug 21, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have a norty track C2500 an the screen went blank
I suggest checking your power plug then check or reset the circuit breaker on the treadmill next to the cord if that ok and the unit is still dead. Unplug unit the remove motor shroud and if you own a multi meter start checking the AC all the way to the lower board and see where the Ac is missing.
If the Voltage is good to the board then check DC Out put going the console wire harness should have 5v or 12v DC depending on model if missing then replace lower board if present, then check the continuity of wire harness if bad replace harness. If good upper console needs to be replaced
May 25, 2010 | Nordic Track Exercise & Fitness
My dynamix treadmill the red power light comes on but the circiut board not powering up
I suggest checking your power plug then check or reset the circuit breaker or fuse holder on the treadmill next to the cord if that ok and the unit is still dead. Unplug unit the remove motor shroud and if you own a multi meter start checking the AC all the way to the lower board and see where the Ac is missing.
If the Voltage is good to the board then check DC Out put going the console wire harness should have 5v or 12v DC depending on model if missing then replace lower board, if present, then check the continuity of wire harness if bad replace harness. If good upper console needs to be replaced
May 25, 2010 | Exercise & Fitness
Treadmill has no electrical response at all...check the outlet and power strip...nothing...any ideas
I suggest checking your power plug then check or reset the circuit breaker on the treadmill next to the cord if that ok and the unit is still dead. Unplug unit the remove motor shroud and if you own a multi meter plug the unit in and start checking the AC all the way to the lower board and see where the AC is missing.
May 20, 2010 | Proform Sport 1000 Folding Treadmill...
Precor EFX 5.25 Elliptical Fitness Crosstrainer Logo
108 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
