Question about Unknown ProLectrix 80-4998 Windsor Wall or Free Standing Electric Fireplace,WallMountedBowFront Panel,Flame Effect,Safety Thermal Cut -Off,Free Standing Base
PROLectrix Windsor Electric Fireplace-How to change bulb?
The lighting effect has stopped working which I presume requires abulb change but _ dont know how to access it.
How do I clean the dust from an Amish fireplace
This shut down is a safety feature on the unit so it doesn't over heat.
You need to remove a cover that's in the back on the bottom and
take compressed air to blow out the dust. Concentrate on the
blower especially. Best done out doors.
This is also a good opportunity to see if the blower still turns
freely. If not it'll need lubed or replaced.
Sep 01, 2014 | Unknown Heat Surge Amish Crafted...
How to make ice cream?
You want to make ice cream with a fireplace? Interesting.
Jul 30, 2014 | Unknown ProLectrix 80-4998 Windsor Wall or...
Unit turns itself off
It's dusty inside. I came he to find out how to clean it
Mar 12, 2014 | Unknown Heat Surge Amish Crafted...
My heay surge stove will run for awhile and then shut down
The heater is thermostatically controlled, so once the room temperatures reaches the heater's preset temperature, the heater cycles off. This is normal.
However, If the heater goes off BEFORE the room reaches the preset temperature, suspect a high temperature safety switch that may be tripping. Does the heater come back on after it cools down?
Oct 08, 2013 | Unknown Heat Surge Amish Crafted...
Heat surge fireplace
Customer Service
1-800-924-7964
Mon - Fri: 8:00am - 9:00pm EST
Sat - Sun: 9:00am - 6:00pm EST
custserv@heatsurge.com
Oct 12, 2012 | Unknown Heat Surge Amish Crafted...
My Clairion SD1015 just stopped working. It's been working fine for 1 1/2 years.
the process this unit uses to evaporate water (boil water) leaves behind any minerals from the water . this builds up on the heating element and requires regular cleaning .. you can soak it in white vinegar to help remove the scale .. here is a URL that gives specific instructions on how to do that ...
http://www.clairion.com/usermanuals/DD_SD_eng.pdf
if there is enough buildup, the heating element gets too hot ... it may trip a thermal fuse .. if this happens then its likely that the machine will appear to have no power at all ... the thermal fuse is located inside the machine and is soldered or crimped in .. it requires a person with technical expertise to change that .. the heating elements go bad but not often ..if your unit lights up but simply doesnt give vapor output then it may be overheating inside due to buildup on the heater ... it might take a couple of days to get all that cleaned off the heater ... there are two sensors that detect that the machine is assembled correctly .. if its not then it will refuse to operate ... also one of the sensors could be bad ..
Aug 18, 2009 | Clarion Humidifiers
I have a Venta VS370 humidifier which works fine immediately after I change the filter but after a few days the vapour stream diminishes significantly and it ceases to be effective: is this a malfunction?
Filters need to be changed regularly depending on environment may have to change more often.
These systems can be very troublesome. It is possible that you are having mineral buildup in your system from the water supply. You can try adding 1/4 cup vinegar to your water to help clean away deposits. See if that helps .
Mar 08, 2009 | Venta Airwasher VS370 2 Gallon Humidifier
What should my humidifier be set at for the winter?
Hi, Jennifer:
I'm no expert, but those who are seem to agree that the first thing to check is your evaporator panel. Aprilaire recommends replacing it annually--so if you haven't replaced it recently, that would be the first step to take. Next, check the power supply to your Aprilaire unit. Turn the humidistat to 0%, and then turn it slowly back toward 35% until you hear a click at the unit. If you don't hear a click, you'll want to check that the unit is in fact getting electric power (you may want to get an electrician or furnace tech to do this). If you do hear the click, the next thing to check is whether you have sufficient water flow to your Aprilaire unit. On mine, I had to adjust my water supply saddle valve, as well as the inline valve on the discharge side of the solenoid (see prior post from this morning)--and this seemed to clear the lines and restore water flow. Once you achieve proper water flow, you will probably want to set your humidistat at 35% for winter temps of around 20 degrees F--but be sure to adjust it downward for colder weather. Comments, anyone?
Dec 13, 2008 | Aprilaire 700 Humidifier
Unknown ProLectrix 80-4998 Windsor Wall or Free Standing Electric Fireplace,WallMountedBowFront Panel,Flame Effect,Safety Thermal Cut -Off,Free Standing Base Logo
Top Unknown Humidifiers Experts
Mack Baxter
Dennis
Are you an Unknown Humidifier Expert? Answer questions, earn points and help others
