Question about Vizio M220VA 22 in. LCD HDTV
How do you get fox 42 on antenna tv in Omaha, ne
Get fox tv
Should I buy a fox antenna they say you can get fox free
you can get the antenna but it is the fox box that the signal so that you can watch fox
Dec 12, 2017 | Televison & Video
Buying a tv fox antenna in the uk
I have 2, even though I am within 5 miles of a transmitter neither work. You welcome to buy mine.
Jun 02, 2017 | Televison & Video
Had my channelmaster 4046 HD hooked up to a vizio tv and got all major channels. Now have hooked up my antenna to an RCA tv and can't get NBC and local FOX station is jumpy
The tuner in the RCA has poor sensitivity. Radio Shack sells a inline amplifier that may help, make sure you can return it if it doesn't. Move the antenna outside if possible and as high as possible, that may help. Good Luck!
Feb 14, 2014 | Channel Master CM-4046HD MODERNtenna...
I can't get FOX on my converter box--what is the channel # for FOX?
It could be your antenna. Some retailers sold consumers UHF-only outdoor antennas and not VHF/UHF combo antennas. Other outdoor antennas may not have a power boost included for the VHF antennas (rabbit ears). The new DTV signals from stations are now broadcasting in lower power signals than before June 12.
Outdoor Antenna
KMSP/FOX 9 and KARE 11 both broadcast on VHF signals. WCCO and KSTP broadcast on UHF signals. You will need a VHF/UHF outdoor antenna to pick up KMSP and KARE 11 and also get all the other channels.
Indoor Antenna
Check your antenna to make sure it's a UHF/VHF antenna. You may need an indoor antenna that has rabbit ears -- that is the best way to get KMSP/FOX 9 reception on your TV. Your antenna should have a power boost to amplify the VHF signal if you are having trouble getting FOX 9 or KARE 11.
What Antenna Is Right For You?
Need help locating the proper outdoor antenna to receive your local television broadcast channels? Based on geographical maps and signal strengths, AntennaWeb.org locates the best antenna for you, whether it's a home satellite system, high-definition television (HDTV) or a traditional analog set.
Make sure you antenna is pointed toward Shoreview, where FOX 9 transmits from.
CALL FOX 9 FOR HELP: 952-944-9999
Apr 07, 2010 | Televison & Video
I need a remote
New universal remotes come with a code sheet that should cover most every brand TV ever made. I recently got a Phillips brand universal remote from Wal-Mart and set it up to operate a 15 year old JVC TV.
Nov 20, 2008 | Memorex MT1127 TV
Sony 42'' Grand Wega problem
The problem has been solved! Although the 3 yr extened service warrany we purchased through Sears ran out 3 weeks before, to our suprise, sears contacted us and said that Sony was going to fix the set free of charge! The serviceman came today april 14th, and put a whole new projector in the set. He said that if we where to have paid for it, it would have cost us$2119.00 Sometimes miracles do happen.
Apr 11, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
No Channels
First check to make sure your coax cable is in the correct slot, (Make sure it is plugged into the outside port). The other port on there is the ATSC antenna which would only be useful for over the air broadcasts if your area has them (I believe Omaha, NE would be able to get KETV over the air)and if you have an applicable antenna. You are using the proper format (NTSC_M), if you are using the WinTV application, on the upper left side of the screen you will see your channel up/down buttons, in-between them is an addition button for video source, try changing this to see if you are able to scan more channels. My initial reaction is that you are using the ATSC tuner for scanning the channels. I will check back frequently to check for more information for you.
Aug 17, 2007 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Vizio M220VA 22 in. LCD HDTV Logo
79 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
