Question about QMark LFK304 Fan Forced Wall Heater - Perfect for Offices
Qmark 5813-2027-000 Dpdt Thermostat Schematic
My son took apart our forced wall heater and took the thermostat off the wiring plugs, but he can't remember which wire goes where and there is no schematic diagram on the inside of the wall heater to show how to wire it back. From the power source there is a red and black wire (with two posts for that on the thermostat), and from the fan unit itself there are three posts (two black wires and one red)
3 Suggested Answers
appman67
  • 32 Answers
SOURCE: Problem wiring 240amp baseboard heaters
12 gauge wire sounds under sized for the application. And 20 amp 240 v breakers might be sufficient if you where wiring the heaters separately. But be sure that your wiring is not romex - because romex is an insulator and is not permitted in conduit. I would suggest that you up size your wire to 10 guage and your breaker to 30 amp as well. Then double check your heater wiring connections to insure that they're wired the same throughout.
Posted on May 03, 2009
panilling9
  • 284 Answers
SOURCE: I am trying to replace a electric baseboard heater
if you have a electric meter check the voltage coming out of the wall to be sure it is 220 v???? (meter across black and white)then with your meter only test black wire to ground and white wire to ground seperately you should have 110 from each wire to ground?
If you have only 110 to the black and no reading on the white, you either have a bad breaker or a 110v circuit
If you read 220v and you new heater is rated for 220v black to black and red to white wall thermostat or built in as long as you have 220v to your connection from the wall or your wall thermostat when turned higher than room temp.
Bare grounds tie together and mount to your green ground screw
Posted on Sep 25, 2009
  • 4736 Answers
SOURCE: where can i buy a thermostat for my heater fhu5-4b
Northern Tool sells ceiling mount Fahrenheat Heaters Try them, they may have it as an accessory or optional item.
Posted on Feb 10, 2011
The heater runs constantly, the thermostat seems to work, I check continuity through it, it opens and closes. What else could cause not to shut off?
QMark MUH (0521) Compact Heater Wont shut off ... - Fixya
www.fixya.com > ... > QMark > QMark MUH (0521) Compact Heater
QMark MUH (0521) Compact Heater, wont shut off related issues. Get free help, solutions & advice from top QMark experts.
QMark MUH (0521) Compact... Repair Questions - Fixya
www.fixya.com/support/p437492-qmark_muh_0521_compact_heater
Recent QMark MUH (0521) Compact Heater questions, problems & answers. ...thermostat on and contactor makes buzzing noise, fan dont run but its not seized it willfreewheel when you spin it ... How do I turn off my q mark wall heater there.
QMark MUH (0521) Compact Heater Shut - Questions - Fixya
Dec 01, 2015 | QMark MUH (0521) Compact Heater
Stopped coming on. Checked breaker, CFI in b'room, etc. Took grill off, nothing apparently loose or disconnected. 18 months old. Any ideas to try b4 calling electrician? Jim @ 828-230-0077
This 120V / 12A heater *requires* the full capacity of a 15 amp circuit - which means it must be on its own 15 amp circuit and not added to any other 15 amp (outlet or lighting) circuit.
Double check for a circuit breaker in the tripped or off position (or blown fuse). Reset and turn on (or replace fuse) as needed. If circuit breakers and fuses look OK - it may be a faulty heater, thermostat, connection, etc.and calling an electrician might be the best and safest solution.
Oct 23, 2015 | QMark CRA1012T2 Fan Forced Wall Heater -...
Intertherm baseboard heater model 1580. Need thermostat
Home Depot carries I believe 2 different T-stats , wall mount, and unit mount. Try there. Or you will need to get it touch with the manufacturer. Also have info, 120 or 240 volt.
Mar 06, 2011 | QMark Portable Hydronic Electric Baseboard...
I need a replacement toggle switch for a chipper/shredder.The 1/12 hp motor experiences frequent slow downs, depending on what is being chopped. Sometimes it even stops momentarily, I presume causing...
My friend did a pretty good search for similar toggle
1) He found a 'wall-type' 30Amp DPDT at Global
2) He said he couldn't find others ... but the internet changes.
3) This switch could be mounted in a box that screws to side of chipper. Switch will work fine with 125V.
4) Radio shack and the automotive stores carry 5 amp versions of the DPDT, but they burn up like you said
5) Here is wiring schematic for switch schematic
6) Note: Wiring is different than automotive-type DPDT toggles where power connects to center pole and loads connect to outside poles
-Power on global DPDT connects to poles L1 and L2
-L1 switches to A1 & B1 ... while L2 switches to A2 & B2.
-Poles L1=>A1 and L2=>A2 turn on-and-off at same time
7) In a reverse of the schematic shown above, my friend is using the global switch on 30Amp water heater to switch voltages between 120 and 240 so we know switch can handle the amperage. schematic
Sep 30, 2010 | RTO 30 Amp Dpdt 3 Position On-off-on...
Do i need a low voltage transfomer to hook up my
what kind of thermostat to you have, did you purchase the thermostat with the unit are you upgrading to a electronic thermostat, If you are using the mechanical thermostat that comes with the unit you will not need a thermostat. please see the link below and page 11
http://www.wfc-fc.com/pdf/Monterey_Top_Vent_IOM.pdf
Jan 17, 2010 | Honeywell Programmable Thermostat Heater
DPDT thermostat for Singer baseboard heater.
as close as I've found
http://keithspecialty.com/k/67-411.htm
http://www.heater-store.com/specialty-thermostats_91_ctg.htm
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
My son took the old thermostat off the wall and didnt mark the wires. I have a new CT87K4446. The wires I have coming out of the wall are red green and white. On the new thermostat I have R W Y screw downs...
Usually when you have the Y terminal on the thermostat (that would be cooling terminal), there should be 4 screws to connect to. They would be R- to transformer, W- to furnace or heat, Y- to outdoor air conditioner and G- to furnace blower.
You might go to the furnace to see where these wires go, they should have the same terminals on the furnace except for cooling, it usually connects to the outdoor unit wire directly.
Oct 12, 2009 | Heating & Cooling
I am trying to replace a electric baseboard heater that is 220 volts and I am unsure about the wiring. the heater has a red and black wire and there is a white and black wire coming out of the wall.How do...
if ur are replacing the heater and it was originally 220/240 ur wiring should b ok but to b sure trace the line wire back to breaker panel and look at breaker the white and the black should b hooked up to separate breakers if the white is hooked up to a ground bar usually on the inside side of the panel and the black hooked up to breaker ur line is 110/120 and will cause problems when hooked up. if the lines r 220/240 than red can hook up to white and black to black
Sep 25, 2009 | QMark FBE15002 electric baseboard heater...
QMark LFK304 Fan Forced Wall Heater - Perfect for Offices Logo
719 people viewed this question
Top QMark Heating & Cooling Experts
paulcarew
john h
Bill Boyd
Are you a QMark Heating and Cooling Expert? Answer questions, earn points and help others
