Question about Parrot SA Parrot MKi9200 Advanced Color Display Bluetooth HandsFree Car Kit
Microphone doesn't work
I can hear others I'm calling but they cannot hear me
Samsung galaxy lll got wet. Major functions seem to work, however, the microphone doesn't let you hear the other end of the call even though you have made a connection
i will give a little secret.Put your cell phone open in a recipient with a quantity of Rice, this will absorb the humidity by 24 hours. Please keep the rice cover all the cell phone. and try again.Of course after you take the cell blow with some gum dryer hair.
God bless you
Jul 30, 2013 | Cell Phones
My microphone doesn't work, when I try to talk on Skype the other person can't hear me. How can I fix it?
If it's broken you can't fix it, but you can replace it . Or maybe it just got deconfigured try reinstalling the drives.
Aug 28, 2011 | HP Compaq nc6320 Notebook
I can hear people, but they can't hear me - apparently my microphone isn't working (and no, it's not set to 'mute')
Check if the microphone is not muted. The mute button is at the top left of the keypad when a call is being received or made. If the mike is not muted, then try the following steps:
I. Switch on phone with SIM Card.
2. Select Menu.
3. Select Settings.
4. Select Call.
5. Select Hearing Aid.
6. Set Hearing Aid to OFF. And that should solve the problem. If this does not work then the microphone might be damaged and may need to be changed.
Jul 24, 2011 | LG CF360 Cell Phone
Samsung Monte, faulty microphone, doesn't work during calls
Get it Replaced from samsung service center.
Jul 05, 2011 | Cell Phones
When using Skype I can hear other person fine but she can barely hear me. I have tried to adjust sound on skype but it doesn't seem to make a difference
I had the same problem and I replaced and/or used "external mic for Notebook " for this purpose and everything is ok now..
pls use new mic and make a test call to SKYPE to hear your mic voice as well..
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 20, 2011 | Labtec Verse 504 Consumer Microphone
Hi i got a skype ? when im on skype and the other side plays a ytube video i can hear the music and sound that is good! but when i do the same they can not hear it. so what do i need to do or set so when i...
The microphone you are using is only picking up sounds that are close to it. Try moving your speakers closer to the microphone. Also make sure that your speakers are facing towards the microphone.
If this doesn't work please comment so that I can further assist you.
Jun 16, 2011 | Video Game Consoles & Games
The speaking function of my handset doesn't work. I can hear the other party but the other party cannot hear me.
the problem is your hand phone microphone, it located on your phone motherboard (in some brands) the solution is you need to replace your microphone with a new one.
just bring it to service center and it won't cost much
May 13, 2011 | Cell Phones
Cannot hear my voice in microphone
These instructions are for Skype 4.2 for Windows or below. Before continuing, we strongly recommend that you upgrade to the latest version. For Skype 5.0 and above, refer to these instructions. If you're not sure which version of Skype you're using, it's easy to find out.
If the person you are talking to in a Skype-to-Skype call cannot hear you there are a number of steps you can take in order to help you set up your system correctly so that others can hear you.
Try calling Echo123. If you can hear your own recorded voice then your playback device (headphones, speakers, etc) and microphone are set up correctly and the problem might stem from low internet bandwidth, or that the person you are calling has not set up their sound devices properly.
If you cannot hear your own voice in Echo123 check that your microphone is on.
Test Echo123 again to see if the microphone now works..
THANKS.
If none of these steps work you might need to adjust your computers sound setup. Have a look at our Sounds Setup Guide.
Also check out our Troubleshooter for more help with common sound setup issues.
Apr 28, 2011 | Skype IM
Can not hear the beep notification when a call comes in. Have moved the mic earpice up for more volumne, Any other solutions?
The lifer is what notifies your headset that it has an incoming call. Try turning the ringer volume up on your phone first and see if that solves the problem. If that does not help, it could be that the sensor on the lifter is going out. The lifter ships with a ring detector that has a 2.5mm jack on one end and a small round microphone on the other end. You could try plugging this into the back of the lifter and setting the microphone next to where the lifter is mounted on your phone. This might help in picking up the sound of the phone's ring tones. If that doesn't help, you might consider replacing the lifter.
Good luck from Headsets Direct!
Mar 04, 2011 | Plantronics CS70 Wireless Headset
Parrot SA Parrot MKi9200 Advanced Color Display Bluetooth HandsFree Car Kit Logo
15 people viewed this question
Top Parrot SA Cell Phones Experts
Outback Jack
Outback Jack
Miroslav Rusev
Miroslav Rusev
Level 1 Expert
Are you a Parrot SA Cell Phone Expert? Answer questions, earn points and help others
