Question about CDA Kitchen Ranges
CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
I think my cooker hood is a CDA CPX9 (but it might be a CPX10 or CPX11).
Anyway the hood, or its power supply, has developed a short-circuit as my RCD trips.
When I reset my RCD a blue flash comes from the hood and the RCD trips again. This leaves me without power on all circuits which are linked to thr RCD. So I need to disconnect the cooker hood from the power supply.
I think it must be necessary to remove the chimney in order to disconnect the power. How to I get the chimney off without breaking it ?
Their web site ''download manual' link http://www.cda.eu/Products/Extractors/CPX9 does not work at present.
  • Anonymous Mar 31, 2014
    Flashing f cooker hood
  • 142 Answers
Remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Posted on Jan 27, 2009
No ducting pipe inside the cooker hood chimney what do i need to duct outside
Depends...does the vent access attic?...if so...attach vent material from hood and penitrate roof with roof kit....at lowes
Dec 09, 2011 | Kitchen Ranges
A bulb blew in my tecnik cooker hood and neither the lights of the fan will work? is there a fuse somewhere that I need to change?
In case you are still looking for an answer. The same happened to me.
I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Dec 08, 2010 | Rangemaster Kitchen Hood
We have a intergrated cooker hood in a 600 opening and want to change to a chimney type,have been told you need to leave a gap each side is this right and for what reason please many thanks
Depends where you live, an EU law came in force a few years back stating that you had to leave a 50mm gap either side of a chimney hood for heat reasons, coming from the hob to the underside of the wall cabinets. But i am pretty sure that this is for newly fitted kitchens only as you would find it hard to purchase a 500mm hood. Hope this helps.
Jan 02, 2010 | Kitchen Ranges
Designair 60cm chimney hood chk60ss what gap between cooker and hood ?
If gas cooker you have to get specs.....We usually get the chef of the house to stand in front...Head banging will be a call back we hate...
Oct 27, 2009 | Kitchen Ranges
The wiring from the fan on my cooker hood has no earth is this ok
yes mam earthing is must and should be provided because of safety for the equipment and the operator,
Oct 06, 2009 | GE Monogram ZV1050SFSS 42" Island Chimney...
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
Internal cooker hood
Hi judav,
I'm Harvey the Master Plumber.
Your problem is: You live in a flat with no chimney and you would like to install a cooker hood. how do you do this please?
Is there living space above? If so you can't go straight up. If your range is on an outside wall, it can be piped out the back. If only attic or roof above, no problem. Just pipe it straight up useing B-vent pipe or equivlent. If you can't do any of this just get a hood that vents filtered air back into the room.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 03, 2008 | Kitchen Ranges
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Halogen Lights Failing
I had the same experiences with my lights. I placed a 50v bulb and it blew the fuses. The fusees located on the right side of the bottom duct cover. use 5a 125 v fuse GE part # wb27x10542 but you can find a cheaper fuse at Radio Shack. Good luck
Mar 28, 2007 | GE Monogram ZV1050SFSS 42" Island Chimney...
Kitchen Ranges Logo
724 people viewed this question
Top CDA Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a CDA Kitchen Range Expert? Answer questions, earn points and help others
