Question about Frigidaire Refrigerators
How to change water filter on frigidaire / model lfus2613lpo refridgerater
Don't know how to get filter out to change it
Maytag317
  • 1136 Answers
SOURCE: how can I change the water filter on a frigidaire fridge
Hi, The filter is in the upper right hand corner of the fresh food section. Turn the filter cup counter clockwise to remove it. There will be a filter cartridge in the cup that you replace.
Please let me know if this has been helpfull or if I can assist you further
Thanks
Vic
Posted on Jul 17, 2009
Krazytech
  • 725 Answers
SOURCE: I have a Frigidaire Model FRS26ZSH need water filter instruction
Filter Status Press and Hold five seconds to reset light. (This light will tell you when to replace the water filter.)
press the button to the right of water filter to release filter...
Posted on Sep 19, 2009
localwonder
  • 6784 Answers
SOURCE: Is there a filter on the water for my
HI. This unit is not equipped with a water filter. If there was a filter, it would be located on the front/lower grill area(bottom part of your unit). It would be accessible there.Unfortunately, this unit dose not have a filtration system.
Posted on Oct 22, 2009
Testimonial: "Thanks for the quick response. "
aasc
  • 1606 Answers
SOURCE: I have a GE model GSL22JFPH BS refridgerater and
Then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is a heater for the water dispensor tube , pt # WR49X10173 , which should keep this from happening again .
Posted on Nov 19, 2009
woodchuck789
  • 4059 Answers
SOURCE: We bought a home with
Part 30 on this diagram is your filter cap. It turns to open and remove the filter
Posted on May 31, 2011
Frigidaire side by side refrigerator model # LFUS2613LPO quit making ice or dispensing watr
Change the water filter and then purge the water into glasses or buckets for about a total of 3 minutes, then you should be fine. Otherwise, if you have problems after completing that, then you have a blockage or restriction in the water valve.
Jul 28, 2012 | Refrigerators
I have a side by side refrigerator & the water filter light is red & the filter needs to be changed. The refrigerator was manufactured 11/04 model # ED26HEXNQ00. I don't know what kind of...
The light will just come on based on time not on if the filter is really need to be changed, you can push and hold the button to reset it, and another six months or so it will light up again. I do not have the same model as you, but mine is in side the ref. top right side, others are on the water line in back.
I have two filters before the refrigerator on mine still go's off I just reset it. If the filter is really needing to be replaced your water would slow to a trickle.
Jun 30, 2011 | Whirlpool Refrigerators
Just wondering if this unit has a filter or filters that need to be changed?? (Frigidaire 70)
Yes, your unit has an air filter, that should be removed and cleaned at least once every two weeks, while in operation, The filter is located behind the louvers on the front of the unit. To access and remove it, remove the water bucket and just inside the bucket holder at the top of the opening, you will see a tab type of handle. This handle is part of the filter frame. Pull that down and out and the filter will come with it. Back flush the filter with clear warm water. Dry it thoroughly, before reinstalling it in the unit. Never operate the dehumidifier without the filter installed.
To assist you further, in case you have misplaced your Owner's Manual, I have included a link to the Manual for your model. You can download and print the manual for future reference.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020266a0180en.pdf
Hope this helped you. Please let me know. Thanks.
Jun 25, 2011 | Frigidaire FDF70S Dehumidifier
Frigidaire Dishwasher model FGBD2431KW will not completely drain after wash cycle. What might cause this?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 15, 2011 | Frigidaire Dishwashers
How do i replace the water filter.
http://www.frigidaire.com/manuals Enter your model number
Manual link:
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241661500en.pdf
Actual precedure with pictures is on page 14 of the above link.
GENERIC Installation Instructions:
  1. Unscrew the filter cup and dump out the water
  2. Pull the old filter straight down and discard
  3. Place the new filter in the filter cup
  4. The end of the filter with the small o-ring should be up
  5. Screw the filter cup (with filter) up onto the housing
  6. The filter will self-align as the cup is tightened
  7. Reset your 'change filter' light (if your fridge has one)
Resetting your filter change indicator light:
  • Press and hold the reset button on the dispenser until the green light flashes (up to 15 seconds)
Thanks for choosing FixYa,
Kelly
May 24, 2011 | Frigidaire Side By Side Refrigerator 26...
I can`t find the water filter
Dont know the model right off but the water filter is usually in the top back on inside of fridge usually where the dials for temperture are located
Mar 19, 2011 | Frigidaire FRS26H5AS Side by Side...
Want start lights come on but water want come out
DO YOU HAVE A FILTER ATTATCHED? DID YOU PUT A VALVE ON YOUR PRIMARY WATER SOURCE? I F YOU DID THEN YOU SHOUD CHECK TO SEE IF YOU TURNED IT ON. iF THATS NOT IT THEN SOME TIMES ON NEW REFRIDGERATERS THEY PLACE A LEVER OR A BUTTTON . oNE MORE QUESTION DID YOU HOOK UP THE WATER LINE FIRST BEFORE YOU STARTED THE UNIT ?IF NOT ITS POSS FROZEN.
Oct 13, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Is there a filter on the water for my Refridgerater Model #FRS20WNF. If so where can I buy a new filter and how do I replace the existing one? The water is starting to taste funny.
Oct 22, 2009 | Frigidaire Refrigerators
Sep 17, 2009 | Refrigerators
Refrigerators Logo
62 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
