Question about Toshiba HD-A30 HD-DVD Player
Toshiba HD-A30 HD DVD player not playing movie getting "mssg" display
Not playing movies getting "mssg" display
techman
  • 3130 Answers
SOURCE: Movie Freezing
Sounds like youe unit is getting tired my freind. they dont make em like they used to. The unit most likly needs a tracking or focus servo alighnment, but to put it on a bench, and have a tech adjust the alighnments, will most likly exceed the cost of a new unit. The laser could also be getting weak, and the replacement optical assemblies for this unit alone cost about 60 bucks. Then you have labor and alighnment cost, as you don't just throw in an optical pickup assembly and it works. Good Luck Please, do not forget to rate this thread.
Posted on Dec 10, 2006
SOURCE: TOSHIBA HDDVD PLAYER A20
I have a problem like this but mine will play regular dvd's
and just stop playing hd dvd's . exact same message
gene
mrjazz1959@gmail.com
Posted on Dec 13, 2007
SOURCE: Toshiba HD-A30 won't play digital sound with HD DVDs
Try checking your audio output in the setup screen of dvd player. Try setting Digital Out HDMI to Auto, if it isn't already. See if that helps.
Posted on Jan 01, 2008
marked
  • 6487 Answers
SOURCE: Toshiba SD-5000 DVD Player - disc tray stuck
Try first turning off the player and turn it back on and eject it using the eject button on the unit and also try to eject it using the remote.. IF still wont eject this can be a mechanical function on the ejecting part of the unit that you may need to open the unit and check for that..
Hope that helps.........
Posted on Aug 07, 2008
Neoklassic1
  • 70 Answers
SOURCE: Unable to play back
Shouldn't matter what the OS (operating system) is. What you need to do is to make sure you convert the movie to proper format which would allow you to view on DVD player after burning. Usually you need a seperate software. Your DVD player should say what formats are compatible. Usually listed on unit or in manual. Avi is a great format but when you burned it to DVD your computer probably created a Data Disk. Which would make it unreadable by DVD player. Check to make sure you are able to convert to format that's readable by your player.Good Luck
Posted on Nov 09, 2008
The display does'nt show the 3d logo so is this a fault because i'm not getting any effects from the 3d glasses and they do work (glasses)
U also must have a LED 3D tv for the 3D DVD movie play on a Blu-ray player to play to get for the 3D movie effect.U now that wright?
Nov 24, 2010 | Samsung BD-UP5000 Blu-ray and HD-DVD...
Mine wont play anything a DVD it recorded it wont let me finalize
Today with HD High Definition TV these kind of problems appears because the new dvd players have more video resolution options, so, for playing all variety of dvd, and home done dvs,s (like family movies on dvd) you need set up your resolution video on your DVD player at 480i or 480p option, not higher because some DVD movies (mainly oldies) have lower resolution than newer , for example new movies on HD format have 1080 P resolution, and if you have this option chosen in your DVD player you only can see this kind of videos, on the other hand if you have chosen 480i or 480 p on your dvd player , you can play all dvd formats including home movies made with any movie software, in this way you can play dvd-r and +r movies and of cours you can play HD movies also. So put some dvd where your dvd player works well (you need see the dvd menu in the tv screen), then press stop. Then press setup in your remote control, go to video resolution and choose 480 I or 480p, then press ok AND ENJOY THE MOVIE.
Smart techniques
Jul 07, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Cannot get the visual from the videos
Smart techniques
Jun 24, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Dvd player will not player dvd's or cd's
When you put the DVD in, you mean it will not launch the appropriate player to start playback of the video?
Maybe your autoplay settings are messed up.
Try launching your movie playback software and attempt to manually play the disc and see if this works.
Another thing, is your drive listed under my computer?
Aug 16, 2008 | Toshiba HD-A30 HD-DVD Player
HD-A3 Movies Don't Play Video, but Menus are fine?
Might be a resolution issue, the menus are most likely in 480, while the video might be in a resolution not supported by your tv. Try changing the resolution and see what happens.
Jun 29, 2008 | Toshiba HD-A30 HD-DVD Player
Unlock to use Region 2 dvds
No region hack for this player.
Jan 29, 2008 | Toshiba HD-A30 HD-DVD Player
Converting up to 1080
Hello. You have to use the HDMI port and connect to the HDMI, or DVI, port on the back of the TV to get 1080. Even if playing HDDVD, this cable is necessary to get the increase. That, and the TV has to be in 1080 too. If you look at the display, on the front of the player, while watching the DVD, it will tell you at what resolution the DVD is playing. The HDMI to HDMI/DVI must be installed to get the increase in resolution. I have a Panasonic HD 34" 1080i widescreen TV, with DVI connection. When connected, the player played my DVD's at 1080i on my TV, while at only 480i thru the composite cables.
On some older movies or series(I like Star Trek- TNG), it doesn't work well due to the transfer to the DVD. Most newer DVD's, such as Batman Begins (there is an HD out, but I have DVD only), improved on the upconvert for me nicely.
Jan 21, 2008 | Toshiba HD-A30 HD-DVD Player
Toshiba HD-A35 region unlock
I am in need to find what an error code is on my HD DVD player. The code is 408 bc 504.
Jan 19, 2008 | Toshiba HD-A30 HD-DVD Player
Dec 28, 2007 | Toshiba HD-A30 HD-DVD Player
gene
Nov 03, 2007 | Toshiba HD-A20
Toshiba HD-A30 HD-DVD Player Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
