Canon ap800 settings
Margin settings for canon ap800 typewriter
JayBlair
  • 328 Answers
SOURCE: Margin Release for Brother GX-6750 Typewriter
Typewriters have alimit to how far to the right or left that you can set margins. Once you use the alt & 6 key to bypass the current margin setting then move to the new setting then hold the alt key and touch the 7 key to keep it in the new position.
Posted on Aug 18, 2008
SOURCE: Olympia Startype 3 Typewriter
I need a manual for the olympia startype 3 typewriter. How do I optain that?
Posted on Oct 08, 2008
Geno111
  • 183 Answers
SOURCE: electric typewriter set the margin
if you still have problem, repost with make and model typewriter, different methods are used with different machines
Posted on Nov 01, 2008
pluerick
  • 4 Answers
SOURCE: SWINTEC 8014 S TYPEWRITER
Press "MAR RELEASE", one key right of "MAR LEFT" in the upper left hand corner.
Press back space in the upper right corner until it's where you want it and press "MAR LEFT" to set it.
Tab over to where you want the right margin and press "MAR RIGHT"
Posted on Dec 01, 2008
  • 2976 Answers
SOURCE: How do I set margins on a manual Remington Rand
Where the paper goes in, pull the flap front, squeeze the tabs together and move them to where you want them. You might also have a model with 'LMAR' & 'RMAR' keys. Just pull the carriage to where you want it while holding the key down. At the ends of the carriage, where the paper advance knobs are, there are push levers that will release the carriage to move it around. Spacing is done with the small click lever, usually on the right side. Free wheeling is done either by pushing in on the knob OR button on the left end of the carriage.
You won't find a manual for it. Typewriters rarely came with manuals, they were universally understood, or figured out.
Posted on Aug 08, 2009
How to reset the margins on Brother EM-530
On most electronic typewriters you change the margins by pressing the code button and holding down the press r margin or l margin on the key board. You want the carrier to be where you want the margin set. To set margins beyond the right or left margin move the carrier to the margin and press margin release to go past the margin. Then press code left or right margin.
Jun 30, 2014 | Brother EM-530 Typewriter
How to set right/left margins on brother AX110 electronic typewriter?
space or backspace to the place where you want the left margin. You may have to use the margin release key to go past the present margin. When you get the carriage to where you want the margin, depress the left margin set key. Some have L mar and R mar keys, also some use the code key and another key to set.
Apr 14, 2014 | Brother GX-6750 Typewriter
How to reset margins on kx-r340 typewriter?
Hi;
To set or change the left margin space forward and press the left margin key. If you want to go in the other direction the press the margin release key once(do not hold it down) the use the backspace key to get to the point where you want to set the margin and press the left margin key.
The setting of the right margin works the same way.
Andrew
Mar 15, 2009 | Nakajima AE-740 Typewriter
Resetting the margins on a manual typewriter.
I can't be for sure if these are auto set margins, but it sounds like they might be. If they are, first move the carriage as far to the right as you can. Hold the Left Margin Set (not Margin Release) lever as you move the carriage all the way to the left. Release the Margin Set Button or Lever. Now hold the Right Margin Set Button or Lever (not the Margin Release), and move the carriage all the way to the right while holding the Margin Set. Once the carriage is all the way to the right, release the Margin Set. Move the carriage to the place you want to set your left margin. Hit the Left Margin Set and then release. Move the carriage to where you want to set the right margin. Hit the Right Margin Set and release it. It gets confusing, but Margin Release does not set margins. Its sole purpose is only to bypass the margins. Hope this helps.
Feb 19, 2009 | Royal MS 25 Typewriter
I have a typewriter brother I have a typewriter brother ML300 and I cant figure how to ajust the margin.....please help
Left Margin:
Move the carrier to the place you want to set the left margin by using (SPACEBAR) or (BACKSPACE). If you need to move outside the current left margin, press (ALT) + (M REL) (3). Press (ALT) + (L MAR) (4). The left margin is now set.
Right Margin:
Move the carrier to the place you want to set the left margin by using (SPACEBAR) or (BACKSPACE). If you need to move outside the current right margin, press (ALT) + (M REL) (3). Press (ALT) + (R MAR) (5). The right margin is now set.
Hope this helps!
Jay @ www.granadahillsbusinessmachines.com
Feb 06, 2009 | Brother ML-300 Typewriter
Tab Release
You can reset all functions to original settings by doing this simple self test.
1. Turn typewriter off
2. Hold down the margin release key.
3. While holding down margin release key, turn on typewriter.
4. release margin release key
typewriter will now begin to type on it's own.
5. Turn typewriter off and then on again
all settings will now be cleared.
Feb 02, 2009 | Swintec 7040 Typewriter
Margin Settings
You must position the carrier to where you want the margin then press the left or right margin set button depending on which one you want to set. Use the margin release button to get past the current margins. You may have to use the code button with the margin button to set the margin. Lawrence
Mar 18, 2008 | Brother EM-630 Typewriter
Hello, I need directions on how to reset the margin on a Canon AP 610 Typewriter, otherwise I'll go nuts!! I've already tried each single combination.. please help me!! Thanks! Kathi
Position the carrier to where you want the margin. Use the margin release to get past the current margins. set using the margin set buttton. Lawrence
Mar 04, 2008 | Office Equipment & Supplies
Brother ml 100
when the typewriter is first switched on the typewriter will automatically set a margin 10 or 12 spaces in,depending on which pitch setting you have. To set a margin say on 20,space-bar in to 20 on the spacing scale and then press Margin Set Key. to set a margin on say, 5 first depress the Margin release key and back-space 5 spaces in and then set then margin as before. Remember that the typewriter will "forget" the settings as soon as it is switched off.
Oct 29, 2007 | Brother ML-100 Typewriter
Open Questions:
52 people viewed this question
k24674
