Question about Canon PIXMA MP130 All-In-One InkJet Printer
Loading ink in a mp130 canon printer
How do you replace ink in mp130 printer
  • rizla
    rizla Jan 26, 2009
    hi honey
    just type in the search ink and scroll down to ? 10 this will give you a guide for doing the ink.
    riz.
    Guru:
  • 1,463 Answers
Hi honey
have a read here this should guide you ink.
riz.
Posted on Jan 26, 2009
Canon mp130 shows error "
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
Reset for mp130
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit..........Done
i hope this help
Jan 26, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Waste Ink Absorber on Pixma MP130 multifunctional is almost full.
You don't have to change the waste ink absorber. There are two in the MP130 and they cost about $15 each. I have found though that you can just reset the counter and let the printer run without any problems. I have done this with three now with no problems. Reset procedure is:
1. Start Printer
2. Press button MENU, then SCAN, COPY and again SCAN – the printer will go into the service menu.
3. select NVRAM ACCESS and further BY OK.
4. select SET Abs- m level and reduce to zero.
5. select SET Abs- r level (if there is) and reduce to zero.
6. Turn off printer by button POWER.
Jan 05, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Canon mp130 ink cartridge jammed
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Sep 03, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I changed ink my printer showing wrong cartridge
Make sure you are using factory new Canon ink cartridges.
If you purchased re-filled cartridges or third party cartridges that is most likely your problem.
Don
Jun 14, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Inktank problem with mp130
hi
it's show u a red/orange light blink it's show u hae a refield cartig insarted u need to press red light buttons for 5sec. and then light blink off and only green light only show now give pring if again orange light blink press 5sec. don't give any kind of link on show messages in windows it's gone automaticaly if u have any quary please tell me...
thanks
jo_chinmay
May 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Waste ink asborber i almost full... how do I fix
I am providing you with a link that will provide you with everything you could possibly need as the owner of this printer. This link on Canon's Web site will give you access to user guides/manual, driver and software downloads, support, specs for the system and much, much more.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10442
This link will take you directly to the Support & Service tab on the Canon Pixma MP130 page.
(If not, simply click the tab labeled Support & Service).
Type "waste ink absorber" in the text box then click Search.
Click 1. ERROR LCD: WASTE INK NEAR FULL which will result in 4 solutions to this problem:
  • Ink absorber replacement options - mp130
  • Press ON/OFF switch to reset the multifunction device
  • The mp130 may require repair
Try 1 and 2 first. You must click on the solution to view the details.
This should also be helpful in the future event that you may need to download drivers or access the manual to troubleshoot/fix an issue. Drivers and Guides can be downloaded from the Drivers & Software tab.
Hope this helps! Share your experience by rating this solution.
Thanks for using Fixya!
Mar 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Ink cartridge jammed
Canon FaxphoneB95 gives message"Cartridge Jammed". How can I solve this problem. Need Answer Urgently Please.
Dec 14, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon MP130
0.gif Re: CANON WASTE TANK RESET CODES for Canon MP130 by tac (2/15/07 1:52 PM) reply + / - CANON MP130
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will include printer.
2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
4. select SET Abs- m level and advance value equal to zero.
5. select SET Abs- r level (if there is) and also you will establish into zero.
6. you will turn off printer by button POWER.
Jun 27, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon Pixma MP130 all in one printer
do you have a manual on this printer?
also, see this for more assistance
Apr 25, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
63 people viewed this question
old marine
old marine
