Question about Zanussi 24 in. ZSF6160 Free-standing Dishwasher
Zanussi zsf6161 error code ,30, water leak
Leak error code 30
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: zanussi dishwasher ZSF6161 starts program then stops after 15 minutes
check this steps and fix it. God bless youFloat Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control.
Posted on Apr 02, 2013
Zanussi wfd1257w giving E11 error on dry cycle. Is there a way to further diagnose the fault?
Hey Rich,
Error Code E11 means that your Washing machine has detected an overfill of water - over filling with water
  • Check drain pump for blockage or obstruction
  • Check drain hose for blockage or obstruction
  • Check drain pump
  • Check fill valve is not jammed open or leaking
  • Check electronic control module
Good Luck
JP
Jun 04, 2015 | Zanussi Washing Machines
Zanussi ZSF6161 dishwasher. the program starts, I can hear some water being moved around then it stops. All happens in the first minute. There is no error code, it just humms it's way down to the end of...
Maybe a clogged pump. Take the pump a part and clean the filters and inside the pump. Check to see if there is food jammed in the hoses while you are at it.
Oct 31, 2013 | Zanussi Dishwashers
Zanussi dishwasher ZSF6161 starts program then stops after 15 minutes
Timer / Control
Apr 02, 2013 | Zanussi Dishwashers
Replace bulb zsf6161
see your instruction manual, and go to the section troubleshooting.
however is very simple, unplug the power and proceed taking the first wire and make note for color wiring, and replace.
If you do not i.manual download from www. retrevo.com
God bless you
Jun 18, 2012 | Zanussi Dishwashers
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Mar 22, 2008 | Dishwashers
AEG 50760 Dishwasher shows Error Code 30
there is water in the base of the macine. lean it over to the side to get all of the water out then try again.
Feb 14, 2008 | Dishwashers
Zanussi error code 30(model zws 1640s)jetstream time line.
Does the machine drain out water in the beginning of the process ? In case it drains out water: -Check first the filters on the inlet water line. - If problem still exist,test for 115/220V on solenoid tags. Good luck !
Aug 06, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Zanussi 24 in. ZSF6160 Free-standing Dishwasher Logo
24 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
