Question about RCA E13335GY TV
Tv don't turn on !!!!
Hi, My Tv don't turn on.I can ear a dimming(cycling sound ) coming from the fly back (like if it will be ok but it stop and doing again. Any suggestion !!!!!!
  • jimmy bilodeau Jul 20, 2007
    chassis # tx826yd and model #e13335gy from RCA
    Have change the 330uf 200v caps from the power supply but...nothing !!!!
  • 147 Answers
Hi Jim,What model is it....More Info Please
Posted on Jul 19, 2007
SOURCE:
KONKA KDL32AT23U 32 in LCD Television No back light, sound OK
Not likely it is the back light if you can eventually get it to come up.
Some general information (cap?):
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.3_29_2012_1_25_02_pm.jpg
Mar 29, 2012 | Televison & Video
When i turn the tv on the picture and sound come on ok then after a few seconds the picture goes off but the sound continues
solution
step 1 : at first test your fly back transformer
step 2 : test your video I.C.
step 3 : test contrast control system section
step 4 : A.C. transformer out put voltage testSend report :[email protected]
thank you.
please only one vote me.
Jul 28, 2011 | Televison & Video
When I turn on the TV, the DVD player has always made a sound as though it was being activated. It would cycle for a few moments (like it was looking for the DVD) and then the sound would stop. But...
You kneed to replace the DVD Deck. Very easy, just a couple of screws on the side and pull the deck out. When you pull the deck out, if there is a cable connected to it, you will need to take the back off and disconnect the cable. Some models have it and some don't.
Jul 20, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
NO VOLTAGE ON [email protected]
If your TV don't have heater at AFC.Try to check first the B+ voltage on the ply-back transformer if you have 110vdc.Use a multimeter tester (range on DC) then place the black test prob (-) to the ground of the TV and the other one is on the B+ pin of the ply-back transformer that usually found on the 3rd pin.
  • If you don't have a B+ supply,try to look at the power supply section and check some open resistor and shorted transistor and also look for the fuse if busted.
  • If you have supply voltage on B+,you should know if the ply-back have oscillation.Normally it have a humming sound if the ply-back is oscillated and test the secondary of the ply-back using multimeter tester (range on AC).
  • If the fly-back have oscillation and the heater still no supply check the resistor that comes directly from the secondary of the fly-back it usually have 5 to 7 volts ac.and replace it with the same value and wattage.
I hope this solution will be helpful.Thank you and good luck.
May 03, 2011 | Televison & Video
1.9 motor runs at 2000 rpm at stop in drive 2000 Saturn Sl2
Sounds like your timing is off. Could be your timing belt is off or your distributor is off.
Both are tricky to work on. Might even be one of the fly wheels are out off sink.
If your lucky and it's the distributor all you need to do is start the car, loosen the bolts just a little,
enough to turn it, than turn it by hand .But DON"T turn it to much.
You can use your ear to hear the difference when turning. Only need to turn it a fraction of an inch at a time to hear the difference.
Hope this help and good luck.
Feb 09, 2011 | 2000 Saturn SL
Hi its CRT 32" proline
first check bright and contrast controol
if not open the cover of the set,make on see if crt filment okey or not and measure it about6,3v it comes from fly back,,,then check controol grid around400v,,,,then check 180v going torgb tr on crt socket at last check fly back transformer
if all are right the problem in crt it self
Jan 07, 2011 | Pro Line Televison & Video
Sreen comes after 30 minutes sound ok
capacitor related
fly back usually causes no power up
Jun 04, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Weird sound coming from the inside
TV needs some kind of service and dust inside to be removed.
Regarding sparks sound, it can be leakage of high voltage of Fly-back Transformer. Qualified tv technician can check and repair it as high voltage risk is involved here.
Thank you.
Sep 23, 2008 | Sony KV-27FS12 27" TV
TV won't turn on I have a flashing red light and there is no picture or sound
Check the site www.magnavoxhelp.com. They have kits to fix this common problem.
Jun 21, 2008 | Philips Magnavox 51MP392H Rear Projection...
AKAI PTH5498 54 INCH...TV WILL NOT COME ON...
DOES THE TV SEEM TO BE CYCLING ON AND OFF, BUT NEVER COMES ON? WHAT I MEAN IS DOES IT SEEM TO BE TRYING TO COME ON, BUT SHUTS DOWN IMMEDIATELY CONTINUOSLY AND WILL ONLY STOP CYCLING THIS WAY UNTIL IT'S UNPLUGGED? DOES IT MAKE A SQUEAKING SOUND FROM BEHIND THE SET WHILE THIS IS HAPPENING?
Oct 08, 2007 | Akai PTH5498 54" Rear Projection...
RCA E13335GY TV Logo
66 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
