Question about Tomtom ONE GPS Receiver
Dead i bought a tom tom one had it for 8 months the it would not stay on batery kept going dead sent it to factory they sent it back never work right when i put it on my pc to charge upit holds the charge for abuot 4 hours the goes dead the charger in the car does not charge it ???????
  • 74 Answers
Does the cigarette lighter work in the car when you press it in? Does it get hot? If not has the fuse blown for the cigarette lighter?
If that is supplying power you may have a fault in the cigarette lighter to Tom Tom lead. Carefully check the fuse (one of the six bumps) in the plug and make sure it is still intact (use a meter).
If the fuse is OK then the lead itself may be faulty and probably needs to be replaced.
Posted on Feb 08, 2009
Why is battery draining ford 2002 Taurus SES
Remove negative cable from battery, connect a test light to negative terminal, opposite end off light to negative battery post. ( let sit for 3 to 5 minutes). Then start pulling fuses, when the light goes out that's your bad circuit. God-Bless! Its worth a try.
Oct 01, 2015 | 2002 Ford Taurus
My nobis 9" tablet keeps popping up windows saying unfortunately blah blah has stopped working. i turned it off and turned it back on and now i can't even get the home screen. please help
Nobis 9 tablets are defective. Many, if not most, of them end up having bad internal memory. They might work for a week, a month or maybe even two months but, sooner or later, theminternal memory goes bad. When this happens you get the stopped working error messages and in many cases it will no longer boot up. Just Google, Nobis NBO9 stuck on go and you will see you aren't the only one who got ripped off when you bought this POS.
I know, I have one. I sent it in when the internal memory went bad. Cost me 20 bucks postage. They fixed it and sent it back. It worked about two weeks and the internal memory went bad again. Then they gave me the runaround and refused to issue me an RMA.
Stay away from anything sold by Bidwell that uses the Nobis brand. Better yet stay away from Bidwell period. They are rip off artists, IMO.
Apr 07, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
My tomtom rider 2 will not turn on
My tomtom rider 2 will not charge on my bike and will not charge from mains electric, when i use my tomtom in the car it works.
Cheers Tim
Mar 23, 2011 | Tomtom RIDER GPS Devices
I have brought this device 2 months back in october 2009,but now it is not catching the satellite,and not showing further route..i have tried couple of time .its not working
You're asking about a Tom Tom, right?
Try hitting Reset.
1) Find the Reset button (in a hole on the bottom of the unit). Press and hold it using a paperclip or a dull pin.
2) Turn the unit back on. Does this solve the problem?
If not, try:
Reset Factory Settings. To do this, first Show All Menu Options (this is from the Preferences menu).
Then, again from the Preferences menu, tap Reset Factory Settings.
Have you made a backup of your Tom Tom? You do this from Tom Tom Home on your home computer.
Nov 23, 2009 | Garmin KasePro GPS Leather Case Bag for ...
Tom tom wont stay charged what can i do
If it will not stay charged then the battery is defective, these type of batteries have an average life of 2 years, less if they are run dead allot, more if they are left on the charger and kept fully charged between uses.
Oct 25, 2009 | Tomtom One XL GPS Receiver
I need to reprogram my tom-tom one and change who it belongs to as well as the address.
On the map display touch the screen once
Look for the spanner / wrench icon and touch that once.
Kepp using the Right arrow until you see RESET FACTORY SETTINGS
Touch YES.
That should make it as you bought it.
Sep 24, 2009 | Tomtom ONE 3rd Edition GPS
TomTom One GPS fault
I had the same problem after downloading the latest maps, the unit was slow to boot up and would not find any satelites. I had no response from e-mails to Tom tom tech support and I was going to give up and buy a new device if this fix failed. I had tried paper clip resets and resetting to factory settings but they had not worked.
After reading the previous answer to this link I searched Tom tom support for 'clear flash' and the search results were more useful than the FAQ on the normal support pages.
I used Tom tom home to uninstall the current software application and then reinstalled the latest version (I had to go through several updates as my version of the software was from when I purchased the unit in 2007), I then downloaded and ran Clear flash and made sure that I disconnected the tom tom from my PC using the correct procedure (using the eject button in the bottom of the tom tom home screen as I read that this could have contributed to the problem in the first place).
After another reset the device came to life and after a few minutes searching for satelites outside the device worked as it should (try checking the configure GPS option if it is taking a while to find a signal, it could be just me but it seems to speed up the search process).
Hope this helps.
Apr 07, 2009 | Tomtom ONE XLS Car GPS Receiver
Fujisu laptop batery not chargin
try to check if other battery is working when being charge,if the problem is in ur battery u have to return and ask for replacement fron the store where you purchased it.nobody can repair battery pack.tnx
Jan 10, 2009 | Toshiba Satellite A105-S4004 Notebook
Can't get update maps or voices. where do i go on my pc i go to but they show other sights which one is right?
Have TomTomgo 710 Can't download anything at all. Keeps coming up error time out. Cost £350 2years ago this month & this is the first time tried to download.NOT GOOD ENOUGH Have sent error report to Tom Tom!!!
Dec 08, 2008 | Tomtom GO GPS Receiver
Tomtom ONE GPS Receiver Logo
124 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
