Question about B&K AVR-202
What are the error messages for b&k AVR 202 - B&K AVR-202
APC SmartUPS X (SMX1000)- "AVR Relay Weld" error message
I had this exact problem after a major power out: Fault, call support: AVR Relay weld.
I fixed it by resetting the UPS: Remove battery connect at rear of UPS (it is marked, just unplug the bat connect tab). Plug the UPS back in, and then turn on. Let it power up... it will tell you it needs a battery. Next, power it down and unplug. Plug the batter connect back in (see rear). Plug in the UPS.. power up. Presto.. it is reset. If it is NOT reset, there may be a real 'relay weld'.
May 13, 2013 | Computers & Internet
Super usb cassette capture
You have to convert the cassette's analog audio to digital. Get a Behringer UCA 202 for $30 on Amazon.
Aug 20, 2012 | Audio Players & Recorders
Failed search for TV Channel Pioneer KRL37 - error code 202
Could be a system corrupted error. This might need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
Canon MP280 Scanner error code 5, 202, 54
I think that you haven't downloaded a driver.You'd better access the Internet to download one.(I just solve it in China this way.)
Dec 30, 2011 | Canon MP280 All-In-One InkJet Printer
My B&K AVR 202 will not come out of standby.
hi,
Check the speakers first. Remove all the speakers from the amplifier and switch ON the amplifier. If the amplifier switch ON from standby without any trouble then any one of the speaker is damged or the wiring to the speaker have some problem. . if it doesn't switch ON from standby there is internal hardware faulty.
IF so Please take it any good electronic reparing shope near you. Becuase you hve to check the voltages at all the outputs of the amplifiers. In this amplifier user can't do any thing. To work wit this amplifer need a throuh knowledge in electronics. If you do someting wrong the amp will became irreparable, because its amplifier stage work in high ampere power supply.
OK
Sep 19, 2011 | B&K AVR-202
202 printer jammed error message appears, but could not locate
Here's an article in the Lexmark website on Error: "201 Paper Jam" or "202 Paper Jam". This will guide you on where to locate the cause of the problem. Follow the instructions. But if you're having a really hard time locating it or you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jun 28, 2010 | Lexmark C762dn Laser Printer
Stuck on 202 paper jam error message. there is no paper jam. Tried unplugging but message still persists
check the paper switches, there is one in the front under the cartridge and another one in the fuser unit.
Oct 23, 2009 | Lexmark Optra S 1255 Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Harman Kardon AVR 245 Receiver PROTECT Error Message/Shutting Down All Equipment
could be your receiver only, it has tripped due to discrepancy on the output stage of your amp. that cracking sound in one of your speakers could have caused the trouble. it is possibly shorted. but in your case it could have damaged already the amp that;s why it would not turn on. normally it will first trip, turn on then turns off. but to stay off and not to turn on again is major problem of the amp. or maybe it emanated from miscabling, probably the ceiling speakers got connected to a high output or main amp. but try removing all speakers first then turn the unit on. see if it does power up.
May 22, 2008 | Harman Multimedia AVR 245 7.1 Channels...
Top B&K Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a B&K Audio Player and Recorder Expert? Answer questions, earn points and help others
