Question about Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Elite dishwasher Options light up but nothing runs.
2007 Kenmore elite dishwasher wont start up. All the option lights, High Temp, Sani Rinse, Heated Dry will light up but nothing else. It ran two days ago with no problems, now nothing.
  • 15,935 Answers
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers.
The problem is usually attributed to water supply temperatures being too low when filling.
Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models).
There is a reset sequence that you can try to clear the fault.
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times.
The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button.
This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher.
This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line).
The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits.
If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is.
The flashing light will be a series of flashes, followed by a pause.
If you indeed have a component problem, it will depend on the number of flashing lights in the sequence.
Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
My dishwasher seems to be stuck in washing mode. how do I troubleshoot?
the schematic behind the lower panel below door should have paper in clear bag with how to get codes.
May 13, 2014 | Kenmore 24" Built-In Dishwasher with...
Kenmore Elite 665.15929001 Dishwasher, flashing Sani-Rinse light, won't start
Kenmore is **** with a double PP go buy a Maytag or GE and throw it threw the appliance dept like the Discount tire guy did on TV. I have asked the same question on 4 different blog's and no answer. The question to where they were actually built is unavailable. They only warranty products for 1 year and their disclaimer's add up to when you walk out the door. They are just JUNK! sorry I do not know the answer, first you will pay the repair man then end up buying a new one anyway. Same as me..Peace!
Nov 14, 2012 | Dishwashers
Kenmore dishwasher model #665 15872000 is stuck on time saver option for washing and I can't get it to switch to any of the other options such as normal wash
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Feb 11, 2012 | Dishwashers
I have a Kenmore elite dishwasher. The Pots and Pans red light is flashing and the Heated Dry light is solid red. Nothing I do will change that. I've tried pushing any combination of buttons and ...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 19, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Kenmore elite dishwasher has no lights or any sign of power. Breaker not flipped, power good....
press back and forth the sani rinse button and high temp button..keep pressing back and forth repeatidly until lights will light up and it resets the system...
Feb 27, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
My kenmore elite ultrawash dishwasher, model # 665.16289402, will not start. The green clean light keeps blinking and when you go to push start after selecting which wash program it does nothing.
youll need to enter a diagnistic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, htne press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Dec 24, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 27, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite 8269645
I have this model, but not this problem (my impeller motor seems to have burned out). Anyway, try pressing Hi Temp Scrub, Air Dry, Sani Rinse, Air Dry, in that order and see what happens. Mine appears to reset and run through a set of warm-up tests.
Nov 13, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 16032 Built-in Dishwasher Logo
657 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
