Question about Brother HL-2040 Laser Printer
I have a brother laserjet printer. I replaced the drum recently. The pages are coming out light grey and I have taken everything out twice and cleaned everything but still happens.
  • indianbob5 Feb 19, 2009
    i have a brother hl 2040 - I have changed the drum and the cartridge and get no image to speak of???
    New Friend:
  • 114 Answers
It may come from moisture in your paper. change your paper.
If not solved , clean the OPC by isopropile.
Posted on Jan 31, 2009
HP color laserjet CP 1510 printing stripes on the left
Is this for all colors or just one color? There are three color toner cartridges plus a black cartridge.
Mar 09, 2015 | HP CC378A Color LaserJet CP1518ni...
My drum light is flushing
Open front door where toner/drum goes in
Hold GO button down for about 5 seconds
All lights should come on then go out when GO button is released
Shut door and wait for warm up to end
Drum light should no longer be flashing
If still flashing then try procedure again
Oct 14, 2010 | Brother HL-2040 Laser Printer
Page looks "dirty" print is not clear
this is normally one of three things in my experience with these printers.
- either the printers drum unit has come to the end of its life and needs replacing
- the toner unit is coming to the end of its life or is a very cheap replacement cartridge not a brother original
- the fuser unit has become fouled up and is marking the page.
both of the first two parts the drum and toner are replaceable, i would recommend getting the original brother parts as they tend to work a lot better than most refilled cartridges i have seen for sale.
this should solve the problem, as its basically excess toner sticking to the drum due to age greying up the papers color.
if neither of these solve the problem you can get kits to clean the fuser unit, but i have never used one of these, as our company keeps a small stock of replacement parts for these printers in case we need them.
Dec 29, 2009 | Brother HL 1440 Laser Printer
Low print quality
It depends upon the number of prints you have done since Feb and the toner cartridge capacity. Some toner cartridges have 2500 page capacity others have 5000 pages or more.
If you think you have not exceeded or reached the cartridge capacity, take it out of the printer and give it a shake in a horizontal position to distribute the toner evenly across the drum and place it back in the printer. This also works when the toner is nearly empty.
Sep 09, 2009 | Brother HL 1440 Laser Printer
Brother HL 2040 drum light flashing after drum replacement
The drum light is triggered by a page counter. To reset it, hold the GO button with the drum door opened until the light goes out (10 seconds). Close the door and it should be reset.
Aug 07, 2009 | Brother HL-2040 Laser Printer
I have a Brother MFC 7220 printer. When printing, there is an almost indelible, yet noticeable line down the left-center of the page. How do I get rid of it? In short, how do I clean the Brother MFC...
This could be the result of several problems. The quickest, cheapest, and easiest thing to try is to clean the "corona wire". This is done by removing the drum/toner unit. On the drum unit (the big grey cradle) is a blue tab with an arrow on it. Slide this back and forth twice, being sure that the two arrows line up when you are done. Put it back in the machine, and make a copy or print from your computer to test the quality. If this does not solve the problem, you may need a new drum (every 12,000 pages) or a new toner cartridge (about every 2,500 pages).
Apr 09, 2009 | Brother MFC-7220 All-In-One Laser Printer
HP Colour Laserjet 3550 printing problems
I can tell you that it is NOT the Fuser unit. I would change the drum unit first. This would be the most likely cause.
Mar 11, 2009 | HP Color LaserJet 3500 Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
Flaws at top of each page when printing
Replace toner cartridge drum is scratched
(Possibly by staple going threw machine if that what each of the five marks look like, all those removed staples always seem to end up in printers)
You can pull it out (I think right top cover opens and cartridge pulls up and to the right)  then .. turn it over and gently pull back cover see drum has same marks as you see on paper, you can gently rotate drum by using gear on edge do not force it only turns easy one way, Do not touch drum surface very delicate and sensitive. Normal disposable item buy a New cartridge here is HP part number for your model  HP C8543X (HP 43X) Toner Cart.
Oct 19, 2007 | HP LaserJet 9040n Printer
Brother HL-2040 Laser Printer Logo
51 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
