Fax beeping after a message was sent out.
L sent a fax, and lmmediatly all l began to hear was a beeping sound. does that means that my fax has been sent or what?
  • loreoisa Jan 27, 2009
    thanks, l checked with a regular phone and there was no dial tone.
    Genius:
  • 2,120 Answers
It means it never found a dial tone. Check the line with a regular phone.
Posted on Jan 27, 2009
  • Leroy Elliott
    Leroy Elliott Jan 27, 2009
    Thanx for the Fixya!
How to erase memory in Brother 8690 MFC - it keeps printing unwanted faxes which are stored in the memory! It is junk mail and 20 pages long and I want to cancel it. When I press "Stop" and pull the power...
Try to press and hold Job Cancel button until a message Job Cancel (All) appears. Press OK to confirm.
If not working, the next is what I found in user manual:
Remove paper from the printer to stop it printing. Turn it on, if not.
Set Remote Access Code, if not already, pressing Menu, 2, 5, 2. Enter three digits - 1, 2, 3 - for example and press OK.
Dial your fax number from a telephone or another fax machine using touch tone. When your machine answers, immediately enter your Remote Access Code (these 3 digits followed by *). If you hear one long beep, machine is saying that you still have faxes in memory. Then you hear two short beeps, that mean the machine waits your command. Use the dial pad to press 9 6 3.
If you hear one long beep, fax messages have been erased from the memory.
Nov 03, 2017 | Brother Office Equipment & Supplies
The answering machine and the fax come on at the same time when someone is calling in - therefore they cannot leave a message due to all the squealing
I don't see a specific question being asked, but I assume you want to know how to be able to stop the answering machine and the fax machine from answering calls @ the same time.
The easiest solution would be to order another telephone line and use it for the fax machine.
The only other option would be to purchase a device that "listens" for the polling beep that fax machines make and, if it hears it, sends the call to the fax. If it doesn't hear it, the call is sent to the answering machine.
Here is an example:
http://www.usr.com/products/telephony/telephony-product.asp?sku=USR4000
Apr 09, 2011 | AT&T ATT1739 Digital Answering Machine
When i send a Fax how do i get a copy that the fax was Recived to the person i sent it to
You will get sound signal like longer beep. when you get three short beeps it means error (sent fax was not successful).
Also you can set XMIT report (means after every your sent fax, you will get printed out sheet with confirmation or error for previous sent fax - not recommended, will increase consumption of paper and toner).
If want to, follow steps:
- press key "Menu/Set"
- press "2" key
- press "4" key
- press "1" key (will see "trans: off")
- with navigation key "down" or "up" select "trans: on" or "trans: on + image"
- then press key "Menu/Set" to confirm it
Done
Feb 02, 2011 | Brother IntelliFax-2820 Laser Fax
I recently bought fax HP2140 and a while ago I saw fax ringing and info: receiving but nothing came thru. It is important to me that I receive faxes because I bought it for business purpose. My nanny threw...
The fact that the phone was ringing and the fax answered the call doesn't necessarily mean, that it was a fax transmission; someone might have called your number and tried to talk, but hung up hearing the fax beep.
You have to ask someone with a working fax machine to try and send you something, then you will be sure whether your fax works fine or not.
If this check will prove that it's indeed your machine that has some issue, then look for any error lights or messages on the display. If there was something wrong with paper, printing head, drive or whatever, you would certainly get some error message.
Oct 25, 2009 | HP 1250 Plain Paper Thermal Inkjet Fax
No print on rec'd or sent faxes
Surely you don't have blank copies rec'd and sent as these are two different parts of the machine entirely. I'll assume you mean rec'd and copied. Sounds like you've left a packaging seal on the cartridge to me - or it's a faulty cartridge. Remove the cartridge and check that all packaging has been removed - especially plastic strip that prevents toner from dropping into the cartridge.
Jul 01, 2009 | Canon FaxPhone L75 Plain Paper Laser
NEED THE MACHINE TO ANSWER WHEN THE PHONE SENDS THE SIGNAL.
After making my post, I went to the official Brothers website for the 4100 FAQs and "Operating Instructions." Here's what I found. Set your 4100 set to the "Fax/Tel" mode. Press "Menu", then the number 2 (Fax), then number 1(Set-up Receive), then number 1 again (Ring Delay). Use right arrow key to increase. Once increased, press the "Set" key. You'll see the message "Accepted." Now press the "Stop" key to exit "Menu." This will now give you up to 4 rings before the fax auto answers. Inorder to send a signal by phone to remote start the fax just follow the instructions I copied directly from Brothers instructions for the 4100: If you answer the call on an extension phone (this is any phone plug into a phone jack on the same line) and hear a beep every 3 seconds (automatic fax) or just silence (manual fax), press *51(remote activation code) on the telephone keypad, wait to hear the Brother machine turn on (chirping sounds) and then hang up. I don't have anyone that can send me a fax right now to test it out. I'll have to try it in the morning. Hope this works for you.
THEOH
Feb 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Faxes won't complete transmission
those noises you hear are line noises via your phone line, not machine related but they wreak havoc on faxing. first you need to replace the actual line connecting the fax machine to the wall. If this doesn't fix the problem then have your phone lines tested. also make sure your machine is set for digital or analog service, depending on which you have. Good Luck.
Sep 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Can't receive faxes
Are you set to AUTO ANSWER?
Unplug and replug power cord.
Aug 13, 2008 | Samsung SF-560 Plain Paper Laser Fax
What does "TAD" mean when it appears on the screen?
TAD is Telephone Answering Device. TAD mode is the only mode that can be used with an external telephone answering device (unless you are using a distinctive ring number for receiving faxes). Your telephone answering device must be connected to the jack on the fax machine (labeled "EXT" for USA). When someone dials your telephone/fax number (to send a fax or to speak to you), all the telephones (including the FAX) will ring according to the number of rings you set on the TAD. The Ring Delay setting is not recognized in the TAD mode. If you do not answer the call, the TAD will answer. As your outgoing message is playing, the Fax is in the background, silently listening for fax tones. If the FAX hears fax tones, it will automatically go into the receive mode. If the FAX does not hear fax tones, it remains silent, allowing the caller to leave a message. The above information is correct for a Brother fax machine. Is your fax automatically picking up the call or do you have to push a panel button to start the receive fax process? Perhaps the fax is already "in" your fax machine's memory and only needs a manual printout. Check the fax call log.
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
82 people viewed this question
jasbo
jasbo
