Question about GE Home Security
Networx nx-1300e power light flaSHES battery - GE Home Security
3 Suggested Answers
  • 74 Answers
SOURCE: I have a networx nx-12 (d.a.s.) home alarm and the
This indicates a low battery condition for the main control panel. Replace the battery in the main control. 12V 4-7AH usually.
Alarmprofessor.com
Posted on Sep 05, 2010
steve_hillin
  • 44 Answers
SOURCE: Can I adjust the volume on my GE Networx NX-148E
There are a couple of things you can do, you can silence the keypad via a programming change to the alarm panel, but this requires knowing the installer or 'go' code. On the other hand, you can change the tone of the keypad by pressing * 0 and using the arrow keys to adjust the tone up and down.
Posted on Mar 05, 2011
We have a Direct Alarm Supplies home Networx NX 16 security system installed in our home after we have a power blackout & the power comes back on the alarm goes off. Is this normal or how to fix
If you have had the system for some while, its internal battery eventually looses full charge by constantly being charged by the system. When you loose power the alarm will try to resort to the battery that obviously can handle the job no longer and forces the system to alarm. Recommend that you replace the battery on a regular basis around 12 / 24 months. Otherwise may be a configuration of your system that identifies power loss as a setting.
Apr 01, 2017 | The Home Security
GE NX-1300E
this kind of issue is usually caused by either a logic fault or an issue on the main board.
Look for a defaulting switch on the board. remove ALL power, press and hold the switch and restore power, this should default the board back to factory settings. You will have to reprogram the system so take note of what areas are assigned to what zones..
Make sure the power pack is supplying the correct voltage too, check on the pack for its output and make sure the same supply voltage is reaching the board.
Also, check for blown or damaged fuses as the keyad should have its own fuse, check these electrically - looking to see if the fuse is damaged is not sufficient, check to make sure it has continuity with a multimeter and be careful if you try using a normal test probe as these can cause issues with digital circuitory.
Feb 14, 2012 | GE Nx1300e Led Network Keypad Nx1300eled
Iowatelecom.networx battery will not charge up. green light come sonbut no power.
I had one of these once, the batteries go bad very quickly, especially if left outside in hot/cold weather. You might need to buy new batteries, you can get them pretty cheap on ebay.
Jun 06, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
I forgot my password for my Caddx NX-8 Alarm. It was installed in 1999
My caddx nx-8 system, have started going into a instant alarm mode for no reason, what can I check for this?
Mar 30, 2011 | GE / Caddx Networx NX 8 Control Panel...
Keypad message reading 12volt low battery on three wireless zones. changed out all batteriies and still getting message.
This could be referring to your battery backup for the control panel. Make sure your battery connections are secure and check the batteries' voltage with a multimeter. If it is showing less than 12 volts and has been connected to the control panel for more than 24 hours, the battery is bad and needs replacement. Contact your local alarm company and ask them verify the battery is bad, and they can install a new one for you right then.
Feb 23, 2011 | GE / Caddx Networx NX 8 Control Panel...
Can I adjust the volume on my GE Networx NX-148E keypad?
Feb 10, 2011 | GE / Caddx Networx Programmable LCD Keypad...
I have a networx nx-12 (d.a.s.) home alarm and the power light is flashing. What does this mean and how do I fix it.
Alarmprofessor.com
May 16, 2010 | Home Security
Hi Liam here I just installed a networx nx4 and when powered up key pad has 1,2,3,4 flashing rapidly with service light on I was able to get rid of service light but zones still flashing And there is only...
This could be a supervision problem. If zone expanders, gsms, keypads, etc. are added to this alarm panel, you must enroll the device with the control panel. This is done by entering into programming mode ( * + 8 + {go code} ) and then simply exiting programming mode by hitting the exit button. The GE NetworX control panel and it's affiliated compatible devices will auto-enroll after about 15 seconds. The default 'go' code is 9713, but this is usually changed by the alarm company installer.
Apr 21, 2010 | General Electric GE NX-591E-GSM NetworX...
Home Security Logo
77 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
