Question about G-Technology G-DRIVE (90801201) 250 GB Hard Drive
Indicator light is too bright
How do you dim or shut off the light on a g-drive
I have a 2002 Buick Rendezvous and the radio and heater control backlights have shut off simultaneously and now only the vent control and trunk release lights work.
I would take a look see at the ground circuits for the none working lights . The incandescent back lighting lamps are then grounded at G200, G301 and G302. You would need factory service info for the location of the grounds .Like this from buick
G200
Right side of the I/P, secured on the underside of the cross car beam, behind the I/P compartment . The I/P compartment is the glove box ,don't know why they just don't say that . You could also check out the power and ground from the componet that's not working ! You can find factory like service info. from alldata
http://www.alldata.com/ . Check out some videos on youtube
https://www.youtube.com/watch?v=efKoWifdcag&t=224s
Interior Lamps Dimming
The second group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination and of incandescent lamps.
• The door switches and the window switches
• The HVAC control head assembly
• The radio
• The instrument panel cluster (IPC)
• The steering wheel controls
• The heated seat switch
• The HUD switch
• The lift glass window release switch and traction control switch
When the ignition switch is turned to the ON position, the vacuum fluorescent (VF) displays (radio and HVAC control assembly), incandescent lamps, turn on at maximum brightness. When the park lamps are on and the ambient light sensor indicates low light conditions, all incandescent back lighting turn on at the dimming level indicated by the IP dimmer switch. At the same time all vacuum fluorescent (VF) displays dim to match the indicated dimming level. The BCM L fuse in the console fuse block, supplies battery positive voltage to the BCM. The I/P courtesy lamps supply voltage circuit of the BCM, supplies battery positive voltage to all the dimmable lamps. When the headlamp switch is placed in the PARK position, the BCM will then dim the interior lamps to the dimming level indicated by the IP dimmer switch. When the driver selects a dimming setting by moving, the IP dimming switch potentiometer, all incandescent back lighting lamps are provided with a specific voltage. The incandescent back lighting lamps are then grounded at G200, G301 and G302. When the IP dimmer switch is moved from MIN to MAX, all vacuum fluorescent (VF) displays, as well as all incandescent back lighting respond from Minimum intensity to maximum brightness in response to the IP dimmer switch.
The driver may select parade mode by manually turning on the park lamps during daylight conditions. The front park lamp circuit supplies voltage to the instrument panel cluster, radio and HVAC assembly for a park lamp on input, and the displays will become full bright.
Dec 03, 2016 | 2002 Buick Rendezvous
Which fuse is for the instrument panel back lighting?
Does the radio play ? Are any other back lighting components not lighting ? Does the HVAC control panel light up ? You probably need new radio !
The second interior lighting group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination, LED illumination and incandescent lamps.
When the ignition switch is turned to the RUN position, the radio VF display turns ON at maximum brightness. When the park lamps are ON, all incandescent and LED back lighting turn ON at the dimming level indicated by the instrument panel (I/P) dimmer switch. At the same time all VF displays dim to match the indicated dimming level. The panel dimmer switch potentiometer is an input to the body control module (BCM). When the driver selects a dimming setting by moving the I/P dimming switch potentiometer, all incandescent back lighting lamps are provided with a specific voltage. When the I/P dimmer switch is moved from MIN to MAX, all VF displays, as well as all incandescent back lighting respond from minimum intensity to maximum brightness in response to the I/P dimmer switch.
Dose
Jul 14, 2015 | 2008 GMC Sierra 1500
Corolla 2006- both driving headlights dont work,dims work. brights work if lever is pulled back, bulbs have been tested .wiring appears to be fine . all other lights,indicators are fine. car is drive
as positioning the lever in certain positions allows the lights to work then the problem will most likely be in the light switch itself. Replace the light switch unit.
Nov 21, 2014 | 2006 Toyota Corolla 1.6
Lights get very bright and goes dim on 1992 honda civic
At idle and during drive time, I notice that my lights go bright and them dim on occasion.
Any clue as to why?
Feb 13, 2013 | Honda Civic Cars & Trucks
Bright indicator on dash on when lights are on. Dim or Bright.
could be light from a separate source. Try turning off the instrument lights and try hi/low again. If you still see the light on both hi/low, it could be in your control arm(turn signal indicator).
Nov 16, 2009 | 1999 Plymouth Grand Voyager
Dim interior lights, power locks wont work......
Try looking at your battery. Check the cables to make sure they are tight and clean. Brush the corrosion off with a wire brush. Now, if you have a wiring schematic, find the ground for the interior lights and clean it up too. Oh, put vasoline on it, and the battery cables, to keep them corrosion free. Check the other grounds in the car cabin too.
Aug 10, 2009 | Buick LeSabre Cars & Trucks
Brights not turning off and dims not coming on all the way
Plese click this link it will works.....
https://techinfo.honda.com/rjanisis/pubs/om/CW0707/CW0707O00071A.pdf.
sir once we finish this chat you will be asked to rate the chat. that time please dont forget to give a good rating
and review. because many customers dont rate the chat and we experts are left with no credits for providing a
solution.
so please dont forget to rate the chat after end of the session. this is just a information to you. always use end
session button to end the session.
Oct 22, 2008 | 1999 Dodge Ram
G-Technology G-DRIVE (90801201) 250 GB Hard Drive Logo
114 people viewed this question
Top G-Technology Computers & Internet Experts
Piyal Perera
Piyal Perera
dbgreenfield
Level 1 Expert
Mark Schmit
Mark Schmit
Are you a G-Technology Computer and Internet Expert? Answer questions, earn points and help others
