Question about Canon PIXMA iP1600 Printer
Encountered problem inserting cartridges
Was experiencing trouble inserting ink cartridges in my canon ip 1600 printer. Need help with instructions. Thanks.
    President:
  • 1,901 Answers
Hi. Go to this site:
Pixma iP1600 Support
On the Support and Service tab there is a Search Our Knowledge Base block.
Below "Please enter your question:" type in "replace ink cartridge". (Without the quotes of course.)
Click on "Search". One of the choices that appears is "How do I install the ink cartridge(s)?"
Click on it and a window will open with pictures and animations to guide you through the process.
Thanks for using Fixya.
A "Fixya" rating would be most appreciated.
Posted on Jan 27, 2009
I don't know how to load the ink into the printer of the iP 1600 Canon pixma
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Apr 25, 2011 | Office Equipment & Supplies
Canon ip 1600 'color cartridge not recognized and/or device not r
Two things. 1. check your cabling to make sure your printer is properly connected. 2. clean your printer's inkwells.
If you send me an e-mail, I can send you a service manual for a Canon Pixma iP1500. Manual is the same for both printers. I can also send you the software service tool. I have both, as I have a Canon iP1500 printer (cheap ink cartridges).
My e-mail address is: 7ohnnyramone@gmail.com
Best of luck, -Ric C.
Aug 03, 2010 | Canon PIXMA iP1600 Printer
Refilling a cartridge
You need to use a very thin needle (25 gauge medical needle works well) on a syringe. There is a tiny hole in the canon 40 cartridge under the label which you need to fill. To refill the color cartridge (canon 41) as you look at the cartridge, the hole at the top is magenta, the hole to the left is blue and the hole to the right is yellow, use a separate syringe and needle for each color. Every now and then you will need to use some cartridge cleaner to soften/clean the sponge in the cartridge. I use 0.5cc of cleaner then let sit overnight before adding ink. You need to be sure the label is replaced well or use good tape to keep the ink from escaping.
Sep 06, 2008 | Canon PIXMA iP1600 Printer
Installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Apr 04, 2008 | Canon PIXMA iP1600 Printer
Canon iP 1600
dear
you can refill your catridge, open the label .... make a whole with knife or something edge, and the red color in center position, the yellow in the right position , and the blue in the left position
don't refill too full, about a 30 cc inks
oke maybe it can help you
thks
cropp
Feb 19, 2008 | Canon PIXMA iP1600 Printer
The ink absorber is full for pixma 1880
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jan 15, 2008 | Office Equipment & Supplies
Using refilled cartridges
Are these chipped cartridges/ If so you will need to get hold a cartrisge re setter Most ink suppliers/manufacturers do them.
Jun 02, 2007 | Canon PIXMA iP1600 Printer
Canon PIXMA iP1600 Printer Logo
142 people viewed this question
old marine
old marine
