Question about Sony STR-DA2400ES 7.1 Channels Receiver
Pre outs not working - Sony STR-DA2400ES 7.1 Channels Receiver
Pre out for Sub woofer on AVR 1601 not working
Is this a new problem, as in it worked before? If it's a new hookup, it's possible the sub you have isn't powered. In which case, it won't work. PRE out is 'preamp' for powered subs.
Dec 27, 2013 | Denon AVR-1601 Receiver
What is the pre out used for
PRE OUT/PWR IN - (1) Effects Loop - Connect PRE OUT to an effects device input, then connect the effects device output to PWR IN. (2) Multiple Amps - Connect the primary unit's PRE OUT to the auxiliary unit's PWR IN. The primary unit is used to control all auxiliary units. (3) Recording or Reinforcement - Connect PRE OUT to sound equipment's input. Both jacks use a TS (Tip-Sleeve) standard type plug for connections. PRE OUT includes onboard tone shaping.
Sep 22, 2013 | Fender Frontman 212R 100W 2x12 Guitar...
Which pre-workout supplement should I use if I perform a high-intensity exercise?
There are many options that are available in the market but if you are looking for the best one that can also be known for being healthy than you must look for Mega form as this is one of the best natural supplement available and making the best possible way to stay healthy and fit for longer.
Feb 06, 2013 | Health & Beauty
Does it matter at what time I take a pre-workout supplement?
Yes, Time matters a lot.
As your body needs some time to absorb all the nutrients and direct them to your bloodstream.
The best time to take pre workout supplements is 15-30 minutes before you start your workout.
If you want to get all detailed information about pre workout supplements and the guidelines to buy them then you can refer Weighted Training clothes.
Feb 04, 2013 | Health & Beauty
Can not get signal out of pre outs for aux amp
Page 21 of your owners manual will go into better detail, bu in order for the pre out to work, you have to be running to another powered amplifier. Plus you must go nto the user menu and tell the system to turn the pre out on.
Jun 20, 2012 | Denon AVR1610 51 Channels Receiver
Speakers are connected to pre-amp or power-amp? pls explain connections , what connects with what , between cd player + pre amp + power amp + speakers.
Do this, CD audio out jacks to the PRE-AMP INPUT jacks, then PRE-AMP OUT jacks to AMPLIFIER INPUTS then from AMPLIFIER to speakers, This will work similiar with any sound source unit ie. Radio Tuner, Tape deck, etc. Just think of it this way, a PRE-AMP is BEFORE the AMPLIFIER, all the AMPLIFIER is going to do is AMPLIFY the sound to your speakers, HOPE THIS HELPS!
Feb 03, 2009 | Audio Players & Recorders
No Sub Woofer Pre out output
I've got the same model and the pre out transistor needs to be replaced,
sometimes you can get it to work by unplugging the reciever and the pre out
then plug in the reciever and plug the pre out in a couple of times or so untill it comes on
or unplug the amp from the wall then plug in the pre out , turn on the reciever wait for sounds to come on then plug in the amp.
if that don't do it the pre out transistor needs to be replaced
Oct 16, 2008 | Pioneer VSX-D511 Receiver
My old yamaha wont stop buzzing
HI SIR .THAT IS NOT BIG PROBLEM.ALL YOU HAVE TO DO MAKE SURE THAT YOUR PRE HAVE THE FLL.1 PROPERLLY EARTHED(THE GROUND FROM YOUR AMP ALSO GOES TO THE PRE )2 ASK YOUR ELECTRONIC MECHENIC TO CHECK IF THER'S NO BROKEN GROUND ON THE BOARD INSIDE.
Aug 17, 2008 | Audio Players & Recorders
Sony STR-DA2400ES 7.1 Channels Receiver Logo
20 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
