Question about Canon PIXMA Pro9000 Printer
Canon Pro 9000 "holder is in the replacement position. Close the printer's cover." but neither is true. How do I get rid of this error?
The ink tanks are all half full or better. I've taken out each ink tank and cleaned the sensors. What else can I try? This error keeps occuring.
SOURCE: Ink tank lamps - the magenta horror
here is the advice that Canon Customer Support give -------
Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
In response to your query please be advised that you should try to remove the ink tank and reinstall it in the position. In case the error message will appear, please try to unplug the device for 1 hour from the power source.
In case after re-plug the device will show again the error message regarding the magenta ink tank, please be advised that you might either test the device with a new magenta ink tank in order to find out if the device or the ink tank is the faulty one, either contact one of our service centers for further examination of your device. We are sorry for the inconvenience.
Please click on the link below to visit the Canon UK website where you can find details of your local Authorised Service Facility as well as other important information needed to send your Canon product for repair:
https://self-service.canon-europe.com/uk/pages/ss_Layout.cgi?LINK_ID=8270&LANG=en&build_frames=1
Yours sincerely,
Canon Support Centre
Posted on Feb 09, 2008
  • 49 Answers
SOURCE: Canon printer i 475D
This may be worth a try
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Jul 03, 2008
SOURCE: CanonPIXMA iP90 Color Ink Tank installation problem
can anyone tell me what to do
Posted on Sep 24, 2008
  • 421 Answers
SOURCE: Canon MP520 Scanner / printer
This is down to a hardware error in the tank itself. Only remedy is to replace the ink tank and not use refilled or copy tanks.
Posted on Dec 05, 2008
SOURCE: Error messages: U150 + Ink tank errors have occured
An on-line problem solver answered this question for me as follows, and it worked beautifully. I had previously tried just removing the ink cartridges, and then re inserting them, but that did not work.
"This is a somewhat common problem with the metal contacts that connect to the ink cartridge. Sometimes it can be fixed by cleaning the contacts, but other times it requires getting a new ink holder from Canon customer service.
To clean the contacts, you'll need a Q-tip and some isopropyl alcohol (it's important that it is isopropyl and not another kind of alcohol). Pull out the ink cartridges and clean the contacts on each one with the Q-tip dipped in alcohol. In particular, you want to make sure there are no fingerprints on the contacts. Then, turn off your printer and do the same with the contacts in the ink holder in the printer. Once the alcohol has dried on both sides, reinstall the cartridges and give it a try.
If this doesn't work, I recommend calling Canon tech support, so they can send you a replacement part."
According to Canon's instruction manual, you must complete the cleaning in less than 10 minutes. It took me about five. I did exactly the tech suggested, and after turning everything off and waiting a minute or so, I restarted everything, and the problem was solved.
You must be careful though, because if you leave a Canon Pi6600 cartridge out of the printer for more than 10 minutes, not only will the cartridge tray move back to the "off" position (out of reach), but the ink cartridges nossles will dry out and possibly not work. Also, do not "squeeze" the ink cartridges or you will get ink on yourself.
Posted on Jan 10, 2009
E15 keeps flashing and wont let me use printer
issue: ERROR LED: E, 1, 5
Solution: Reseat ink cartridge (MP150 / MP170 / MP450) Reseat Ink Cartridges Reseat (remove reinstall) the ink cartridges if an error appears Removing Ink Cartridges: After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.Press down on the semi-circular tab to release the cartridge and then remove it.Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.nstalling ink cartridges after confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position. Note: After confirming that the scanning unit support is fixed into position, release your hands.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.) Confirm that the ink cartridges are installed properly <1> The ink cartridge is not installed properly.<2> The ink cartridge is installed properly.Fold the scanning unit support and close the scanning unit (printer cover).Wait until the preparatory operation is complete; it takes about one to two minutes
Oct 01, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Hi, I have the Canon Pixma MX310 and I tried to replace the ink cartridge but I messed i up and I still don't know how to replace it... I think it's error 5100 or something because it says it on...
Installing ink cartridges:
Make sure that the machine is turned on, lift the Scanning Unit (Printer Cover) with both hands, then pull the Scanning Unit Support (A) down into place.Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.Note: - Do not attempt to reattach the protective tape once you have removed it.do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
  1. *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  2. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)Confirm that the ink cartridges are installed properly.OR
  3. <1> The ink cartridge is not installed properly.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
  5. Wait until the preparatory operation is complete; it takes about one to two minutes.
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
Sep 24, 2011 | Canon PIXMA MX310 All-In-One Printer
Hi, my canon MP250 is displaying the error P08 and error 5200 on the computer. Can you help me please
Start with printer powered off
1. Open cover of printer and verify that the ink cartridge carriage is not in the center of the printer. Leave cover open.
2. Unplug the electrical cord from the printer and wait 30 seconds.
3. Plug electrical cord back in, when ink cartridge carriage moves to the center of the printer quickly unplug the electrical cord again. This should leave the ink cartridge carriage in the center of the printer so you can get to it.
4. Lift up the gray arm that surrounds the ink cartridges.
5. Remove the entire ink cartridge holder (not just the ink cartridges). It will lift out easily as a unit. Lower the gray arm that you lifted to remove the cartridge holder.
6. Close printer cover. Plug electricity back in.
7. There should be a message about checking the ink cartridge on the display (I can't remember exactly what it said but it was something like that).
8. Open printer, lift the gray arm that surrounds the ink cartridge area and reinsert the ink cartridge holder (with the ink cartridges in it). Lower the gray arm.
9. Close printer cover.
10. The display should appear normal now, and you should be able to print again.
Jul 21, 2011 | Office Equipment & Supplies
I have a canon pro 9000 printer , I have a new printhead how do i replace, is it easy?
Yes its simple to replace the print head follow the steps mention below :
1.Open the top cover of the Canon printer. The print carriage will then move to the center position.
2.Press the tab on each ink cartridge, then lift the cartridges out.
3.Raise the lock lever, then lift the old print head out of its cradle.
4.Remove the new print head from its packing material, then place it into the cradle in the same orientation as the old one had been.
5.Lower the lock lever until it snaps into place, then reinsert the ink cartridges.
6.Perform the Printer Head Alignment adjustment in the printer's maintenance utility.
Jun 26, 2011 | Canon Office Equipment & Supplies
I am refilling the black ink of my canon printer using continuous ink container but the black color doesn't flow into the end of the hose and it didn't print at all, please help
  • Check the printer's power/alarm light. If it is flashing orange, count the number of flashes. Look up the flash code in your printer's user manual to diagnose the problem.
  • 2 Remove and reinstall the ink cartridges if the power/alarm light flashes 5, 7 or 15 times consecutively. This indicates that the issue is a cartridge error, an incorrectly installed cartridge, or an unrecognized cartridge. These errors can be fixed by reinstalling the ink cartridges. Make sure that you are using the correct ink cartridges for your Canon printer.
  • Turn on the printer and open the front cover. The ink cartridge holder should move to the replacement position.
  • 4 Verify that the colored ink cartridge is inserted in the slot on the right and the black ink cartridge is inserted in the slot on the left. Swap the cartridges and reinstall them in the correct slots if necessary.
  • 5 Check to see that both ink cartridges are level with one other and parallel to the top of the ink cartridge holder. If either cartridge is wedged at an angle, gently apply pressure to the cartridge until it clicks into the correct position.
  • 6 Close the front cover of your Canon printer and wait while the printer initializes the newly installed cartridges. This can take a minute or two.
  • Jun 12, 2011 | Office Equipment & Supplies
    My 9500 printer is not printing one color and ive done the deep cleaning as instructed. how do i remove the print head so i can clean it?
    Turn the printer on.
    Lift the cover to expose the print-head mechanism.
    The print-heads will slide to a position from where you can "unlock" the ink-cartridge from its holder, and then gently remove the empty(???) ink-cartridge.
    Insert a new ink-cartridge (or refill the empty cartridge).
    Close the lid.
    Print a "test" page.
    May 27, 2011 | Canon PIXMA Pro 9500 InkJet Photo Printer
    I get a message that the holder is in the replacement position. After replacing the ink cartridge, close the printer's cover.
    You could try to remove both ink cartridges
    Unplug printer and plug back in after at least 3 minutes
    Turn on printer
    Reinstall both cartridges.
    Dec 12, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    I'm getting a 5100 "check printer" error on my
    Reseat (remove / reinstall) the ink cartridges if an error appears. Removing Ink Cartridges:
    2. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    3. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
    4. Confirm that the ink cartridges are installed properly.
    5. Fold the scanning unit support and close the scanning unit (printer cover).
    6. Wait until the preparatory operation is complete; it takes about one to two minutes.
    If you need more help come back.Post / thumbs / testimonial are welcome!
    Nov 23, 2010 | Canon PIXMA MP180 All-In-One InkJet...
    Canon PIXMA Pro9000 Printer Logo
    47 people viewed this question
    old marine
    old marine
