Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lxi fill keeps flashing - Hobart 24 in. LXIH-3 Built-in Dishwasher
2 Suggested Answers
  • 110 Answers
SOURCE: Hobart LXI Dishwasher a P3 code is flashing, seems
the p3error is an open or shorted booster thermistor.take off btm panel on the right side is the bstr, do when cold and no power to mach.,TURN OFF BREAKER, ON THE UPPER RGT CORNER OF BSTR YOU WILL SEE THE THERMISTOR.unplug from harness use7/16 wrench to unscrew from bstr. well,get new therm.and installyou can get @ any hobart office in your area, part#328994. dont forget to vote, thanks, monomoy
Posted on Mar 16, 2010
2 used LXi machines, they were power washed and stored. an electrician had to open the electric board (drawer) in order to hardwire machines both machines flash the "door open" (dr op) display.
there is a door switch (reed switch) located inside (I believe) the top right side of the unit and there is a magnet in the same place on the door that triggers the switch. If it isn't adjusted right it wont sense the doors are closed. Odd that both would be doing the same thing. Here are the parts diagrams. Reed switch part number 00-473109 http://www.hobart.co.kr/data_file/LXi.pdf
Sep 20, 2016 | Hobart Dishwashers
My lxi-h won't draw rinse aid through the pump
You need to replace the squeeze tube on the rinse aid pump
May 23, 2013 | Hobart Undercounter/Lxi Warewasher 24"W x...
WE LOST OUR MANUAL AT WORK AND HOBART LXH DISHWASHER KEEPS SHOWING DELIME , HOW CAN GET THIS GO AWAY, THANKS
Use a commercial deliming agent (like Lime Away or LSR). Remove the rack from the dishwasher and close the door. Press Off to power down the machine. Next press and hold Wash (Delime) while pressing ON. Delime should show in the display. The unit will fill with water and then flash Add and Delime. Open the door and add the deliming agent according to the directions. (The sump holds about 3 gallons of water.) Close the door and press Wash (Delime). The machine will start the wash mode for 5 minutes and then do two rinse and drain cycles. Delime symbol will flash while this takes place. When finished, the power to the control will be turned off. Check the interior of the machine for lime deposits. If needed, repeat the delime cycle. If the delime program is interrupted before it is completed, then start the delime process from the beginning.
The manuals and other documents are available to registered users of the Hobart site here: https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FresourcecenterZ2Fdefault.aspx&reason=0&formdir=2 . The direct link is: hobart.co.kr/install_pdf/040.pdf .
The spec sheet is available here: http://www.hobartcorp.com/products/warewashing/undercounters/lxi-undercounter/ .
I hope this helps.
Mar 15, 2011 | Hobart 25 in. LXIH-4 Built-in Dishwasher
Hobart LXI Dishwasher a P3 code is flashing, seems to be working alright. Thanks to any help
Mar 11, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
How much delime agent should I use to clean the system in a Hobart LXI-H?
Depending on how often you delime the dishwasher use 2 cups.The delime light will come on after 1000 cycles set from factory default.If the delime icon is lit and beeps,turn the unit off.
Push and hold the delime/wash button and on button for 5 seconds and youll be in delime mode.
The unit will fill and heat up and display "add delime".Open the door add the delime and press the wash button.The dishwasher will run for 5 minutes then rinse and drain twice then shut off.When you turn it back on the delime icon will be gone.I'm a hobart tech and repair these dishwasher often,any questions let me know and please rate me,Thanks.
Nov 24, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
How do you delime the hobart LXi. Where can I find the manual online?
With the unit off----hold the wash/delime button in and hold the on button in for 5 seconds.the dishwasher will fill and the delime icon will be on,then it will prompt you to add delime,add the delime and hit the wash button.It will run for 5 minutes,fill up twice and drain twice then turns off.
Feb 26, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart LXI
Question--As of today if you look at the display does it read add detergent or add rinse aid?Im asking you this because theres a chemical pump circuit board that senses the chemicals on this d/w.And if the d/w displays those the d/w will keep dumping det/r.a. in.Let me know,if this is not the issue i will get you into the service program and step you thru.
Nov 14, 2008 | Dishwashers
Dish washer over filling?
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
Oct 14, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
150 people viewed this question
Top Hobart Dishwashers Experts
Jason
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
