Question about Kitchen Ranges
Magic chef with uniburners gas oven will not light
Demy
  • 20 Answers
SOURCE: Magic Chef Gas Range
Does this oven glows before igniting the gas in the oven? if it does this unit uses a glow bar ignitor in the oven and spark module for the top burners.If it you dont see the spark( or hear the ticking sound the there will be no ignition. Do you smell gas even if there was no ignition happening? If there's gas that eliminate your gas regulator. If it's only one burner with spark but gas won't come on then your gas valve is deffective. But if there's gas and no spark ten it could be poor grounding, wiring, connection or switch or even spark module problem. You to need call your local Appliance service provider on this one. I do not recommend anyone fixing gas related problem if they are not a qualified servicer.
Posted on Aug 01, 2007
  • 833 Answers
SOURCE: Magic Chef Gas Oven - Heats up slowly and has intermittent gas smell
STOP USING THE OVEN IMMEDIATELY!!! You are not getting enough air to the burners to burn all the fuel. Not only will you have an explosion hazard, you'll have a carbon monoxide hazard either of which will KILL YOU. Read all of the info below before you begin.
You need to clean all the burners and inlets thoroughly. You probably used the oven for a lot of broiling of meats or it is quite old. The deposits are clogging the tubes which gauge the amount of air entering the burners or the burner holes themselves. The burner tubes are generally removable by removing one screw and giggling the units clear. Before taking anything apart, note carefully the positions of any mix plates and scribe small marks between the two surfaces. Use a heavy duty cleaner or WD-40 to loosen grime. Don't use abrasives like Comet. Then wash in mild detergent with hot water and dry. Be sure all burner openings are clear. After assembly, note the color of the flames. They should be about 90% blue along their length from the burner head. If they are not, you didn't finish the job cleanly or you have another problem. If the burners are old, rusty or have irregularly shaped flame holes, replace them.
Posted on Dec 03, 2007
frcs68
  • 1605 Answers
SOURCE: How do you light the oven pilot on Magic Chef 31000PAW
open the oven. take out the racks and push on the button plan toward the back and left it out of the oven.
you will see a small orfix appromiate middle of the fire ring. light a match to it. put eveything back.
you in business.
Posted on Apr 07, 2009
Maytag317
  • 1136 Answers
SOURCE: Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Posted on Jul 15, 2009
SOURCE: Magic Chef oven won't light
Replaced the ignitor.
Posted on Oct 09, 2009
Magic chef oven with uniburners oven will not light. igniter gets red hot but seems like no gas coming at all. burners on top work fine.
Since the bake burner does glow yet no flame that means that the igniter is weak and should replaced...the way the igniter works is that it comes on and get very hot where upon getting hot it draws a certain amount of amperage which will allow the gas valve to open resulting in a flame. The igniter is indeed coming on yet its not getting hot enough to draw the proper amp drqaw to open the gas valve...by replacing it with a new fresh igniter it will draw the correct amprage and let the gas flow.
GENE
Oct 02, 2011 | Magic Chef Ovens
Tip
Magic Chef Gas Ovens
If your Magic Chef gas oven doesn't light, most likely the oven igniter (rectangle style) is the problem. The igniter may glow and appear to be working, but doesn't get get hot enough to open the oven bake valve. I recommend replacing the igniter first.
on Mar 21, 2010 | Magic Chef 31000 Gas Kitchen Range
Looking into how to convert from proane to Nat gas. Magic Chef Stove Uniburner Model# 31FA-7
Go to their website (Magic Chef) and there should be a conversion kit. Simple to do - you just change out a few parts. Good luck
Feb 14, 2010 | Magic Chef 31000 Gas Kitchen Range
Cpr1100adw magic chef
Most, if not all, gas ovens do not have pilot lights any longer. They are electronically ignited. You could have a loose wire on the igniter or a faulty igniter. If your oven is new it should be covered by the warranty.
Jul 26, 2009 | Magic Chef CPR1100AD Gas Kitchen Range
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Dec 30, 2008 | Magic Chef 31000 Gas Kitchen Range
Magic chefa313-230lw gas ignitio
hi .thanks for the question . A very common problem with gas ovens replace the igniter thanks the appliance doc
Sep 29, 2008 | Magic Chef 9512 Electric Single Oven
Kitchen Ranges Logo
48 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
