My candy c1 145 won't start - Washing Machines
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: My candy future3 dishwasher just won't start the
test the following steps and fix it. God bless you
Power Supply
The main power supply is the first thing to check. Also remove the toe kick and the cover on the power box and check the connections. Also check the 120 volts at the power box
Hi - Limit Fuse
This will fail if your dishwasher overheats and occassionally with power surges. This is easy to check, inexpensive and a quick fix. Just check the terminals for continuity ( remember always remove one wire) if you have none replace the hi- limit fuse
Door Switch
This is the second place to look. Again an inexpensive easy fix. The following video will walk you thru checking the door switch The power comes into the main power box and usually runs to the door switch next before entering the main control module.
Main Control Module / Timer
The main control module or mechanical timer controls all the functions of the dishwasher. To check this you will need to find the 2 leads that supply the power to the control. They will be marked on the wiring diagram. They usually come from the hi - limit fuse or the door switch. When the door is latched you should have 120 volts entering the main control. If you do not the problem is not the control. If you do have power entering the control but none of the functions work properly or it does not respond at all you will need to replace the control module, this is easy to replace but not very inexpensive to purchase. Consider the age and overall condition when purchasing this part.
Motor
The motor may have failed. If the control illuminates on electronic versions the problem may be the motor. To check the motor refer to the tech sheet located behind the console cover on most models, this will sometimes have the ohm reading of the motor. Also check each lead to the metal housing of the motor to check for shorts in the motor. If you do not have the ohm reading specicifications, check for continuity if none replace the motor. Make sure the motor is receiving power.
Float Switch
If the float switch has failed or is stuck the dishwasher control may not respond. The float switch is easy to check and replace.
Posted on Jul 23, 2013
Candy dishwasher. Program setting won't change
what is the make and model number?
May 21, 2013 | Dishwashers
Candy Crush Saga won't connect to Facebook ios and Android
you need to log onto facebook via the computer. go to settings, then apps, choose candy crush click the x to delete app. not the content. once that is done reinstall candy crush on your device. it should start to work. since facebook had got a whole new change things started not syncing properly. this is the fix
Feb 18, 2013 | Facebook Apps
The start button on Candy Nova CDV-262 won't stay in.
there seem to be a bad connection try sliding a thin knife next to the switch and see if that works
Feb 17, 2013 | Dryers
My candy dryer is heating but the drum won't turn what can i do
replace drive belt contact manufacturer for agents for parts
Oct 06, 2012 | Candy Dryers
Zanussi progress 1200 won't take softener into
Hi there
Now I am urprised. There must be three dispensers in your Zanussi as in my Candy.
One is for the main wash another for prewash and the third one for
the softner.
Look in the manual.
Kolbrun
Feb 26, 2012 | Zanussi Washing Machines
Drum wont rotate at all
You mean it won't turn as in it is stuck? Or is it that the motor won't come on to turn it? Check door switch. Does dryer have power to it at all? Please rate my answer so I get points for it.
Jan 17, 2012 | Candy CNW136 Front Load Washer/Dryer
Wash cycle stops and light on the extra dirty symbol lights up
This is might be the drain filter. When the drain filter is clogged, the machine won't empty itself of water.
Candy has a troubleshooting webpage that lists many possible problems/solutions:
http://service.candy-domestic.co.uk/fault-finder/FaultFinder.aspx?Section=11
If you do try to check the filter, keep in mind that opening the drain filter will yield gallons of water on your floor, especially if your machine does not have the drain hose next to the filter opening. You'll need to have some way of transferring the water ready before opening the filter.
Good luck from Detroit, MI.
Jul 18, 2011 | Candy Washing Machines
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
