Question about Frigidaire ATF6000ES Front Load Washer
DISHWASHER DON'T DRAIN
DISHWASHER RUNS COMPLETE CYCLE BUT WHEN I OPEN THE DOOR THERE IS STILL WATER IN THE BOTTOM. I TOOK THE STRAINER OUT BUT IT WASN'T DIRTY
    Novelist:
  • 161 Answers
Check the drain.
This could be a clogged drain line especially if the drain connects to a disposal. Some drains are semi-transparrent and a good light will show the clog. I use a long piece of tubing (snake) to dislodge the clog.
Also, if this does connect to a disposal make sure the dishwasher drain hose is elavated when it leaves the disposal so disposal debris will not get in the dishwasher drain line. You may have to tie the drain line to keep it elavated.
Posted on Jan 28, 2009
Water not draining away, what can I do
Take out the bottom rack and put it aside. In the bottom of the dishwasher, there is a plastic strainer that screws in. Remove the screws and set them aside with the strainer. Feel around for anything in the hole which could be blocking the drain. Often labels, soapscum, food particles, etc., get in there. If there is standing water, mop it out so you can see in there. After you've cleaned out the drain, replace the strainer with its screws and the bottom rack. Try the dishwasher out by letting in a little water (an inch) at the start of the cycle, then turn it to the end of the rinse cycle to see if the water drains out. Hopefully that will fix your problem without having to call in an expert.
Feb 25, 2015 | Dishwashers
Bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
Water does not drain from GE dishwasher.
Remove the drain hose from under the sink to verify that there is no clog. If the dishwasher runs in the "cleaning" cycle, but won't drain, you either have a clog or a bad solenoid. All the solenoid does is opens a little door to change from cleaning cycle to drain cycle. This part is VERY EASY to change. Definitely a project for DIY. The part runs around $60 from a parts place. Check ebay if you do not need it immediately and you can save abt $30.
Aug 16, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher overflowed out of d/w during wash cycle; not draining
2 things to check
First turn off the power(breaker box to dishwasher and sdisposal
open the doors to your sink and and check the hose for any kinks etc
open the dishwasher door, bail out water remove the spinning hub and see if you can remove
the strainer and bail out more water
you can use a baster to **** out more to view
to see if the pump area is plugged
reverse proedure and turn on dw
listen to see if the pump engages on that cycle
hopefully this solves problem
If the pump does not engage you wil need to call for service
Jan 01, 2009 | Mx Commercial Line Drano Max Clog Remover
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
I have an older Bosch dishwasher I just hooked up in my condo. WHen a cycle is done there is no water is located at the bottom of the inside of the dishwasher, yet 2 days later water will drip on the floor...
when you empty you sink, some of the water is going down the drain hose of the dishwasher. take the drain hose up as far as possible in a swan neck
Jun 18, 2008 | Dishwashers
Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Aug 29, 2007 | Asko 24 in. 1585 Built-in Dishwasher
Water not draining
Usual causes are: 1. Something in the drain path blocked. Symptoms: You can hear the drain pump running at the appropriate bits of the cycle, but if you you open the door the instant the pump stops, there is still a pool of dirty water in the bottom. Solution: Follow the path from strainer through drain pump to drain hose, find and eliminate the blockage. Most likely points are the strainer and the inlet to the pump. Hint: You can identify the drain pump by following the drain hose and seeing what it's attached to. 2. Drain pump broken. Symptoms: Usually, you won't hear the pump running at all at the appropriate times; if it does run, it won't sound right. Solution: Take it off and open it up, see if something is blocking the impellor (in which case, fish it out). Spin the impellor with your fingertips; If it won't turn at all, you need to find out why it has siezed (may be fixable) can you feel it turning the motor (a very magnetic, "flippy" sensation). If you can't, the impellor has probably become unstuck from the shaft. You may be able to glue it on, but this fix is unlikely to last very long. Use a multimeter to measure the resistance of the motor windings. If madly different from a few hundred ohms, again a new motor might be necessary. Hint: The pump motor and impellor can usually be bought separately from the pump housing as a much cheaper unbranded part. 3. Back-siphoning from the waste plumbing. Symptoms: You can hear the drain pump running normally at the appropriate times, and if you open the door the instant the pump stops, the machine appears to be empty, but then quietly fills up with dirty water. Solution: There is meant to be an air break (or in some installations and anti-siphon valve)where the machine's drain hose enters the domestic drainage drainage system. Unblock/unjam this. Hint: After fixing this, run the machine empty on the hottest, longest cycle it has; some of that dirty water may not originally have come from the dishwasher. A.
Apr 21, 2007 | Candy 24 in. CD623 Free-standing...
Frigidaire ATF6000ES Front Load Washer Logo
117 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
