Question about The Learning Company Super Solvers - Gizmos & Gadgets! (798936820037) for PC, Mac
Want to run Gizmos and Gadgets on Vista PC
Any version of Gizmos and Gadgets available for Windows Vista PC? Or ways to get around the MIDI problems
  • Anonymous Mar 27, 2014
    explore learning only lets me do one gizmo, the same one, every time. it won't let me do the other gizmos, they pop up with a download screen that only has a picture on it.
I got Gizmos and Gadgets to work on my Vista PC by copying the entire CD to C:/Windows/System32.
After that, open the "ssgwincd" folder, and inside that folder open "ssgwincd" again. Inside the second folder there will be a file called "ssgwincd.exe" right click on it and select properties. In the properties window click on the compatability tab and set the program to run in compatability mode for windows 95 and to run in 256 colors and in the 640x480 window
It should then work for you, but I would suggest putting a shortcut to the program on your desktop so you can find it easier later on.
Good Luck!
Posted on Feb 28, 2009
  • 32 Answers
You can run this game by using a DOS emulator, so the game can install and run in the enviroment it was intended for.
DOSBOX is a free emulator program, and works with Vista,
for the download of this program, and instructions on how to use it (if you aren't familiar with DOS, you may have to look up several commands to figure out how to install) please visit http://www.dosbox.com/download.php?main=1
I remember that game from elementary school, good times!
Posted on Jan 26, 2009
Voyetra midi orchestrator
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: http://www.turtlebeach.com/support/files/241/ . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
Nov 29, 2013 | Yamaha Music
I have an older, much older!, Midisoft Play Piano 2.0 software CD. It says it is for Windows 95 or Windows 3.1. I would very much like to get back to learning the piano, but now have Windows 7. Will it...
Hey there,
I don't know if there's an upgrade available, but I really doubt you'll be able to run the program under Win7. The easiest way (and it's still not easy) to run older (win 95/98) programs under XP or windows 7, is to install microsoft virtual pc:
http://www.microsoft.com/windows/virtual-pc/
This will let you install an older version of windows under your current operating system. Its the easiest way i've found of being able to play older games/run older programs.
If this seems like too much of a chore, look for freeware versions of similar programs that will run under Win7. Here's just a few:
http://download.cnet.com/Piano-FX-Studio/3000-2133_4-10394113.html
http://mustech.net/2007/06/12/midipiano-freeware-midi-piano-player-synth-and-more
http://www.pianoeletronico.com.br/index-en.html
Good Hunting
Mar 16, 2011 | Computers & Internet
Want to run gizmos and gadgets on windows 7 PC
¡Muchas gracias! Usted es realmente ?til! Los individuos tambi?n pueden visitar https://plus.google.com/108575569080700033613/posts/4D5pxfTcdu9 para obtener las claves de Windows Original y barato para activar sus ventanas.
Sep 02, 2010 | The Learning Company Super Solvers -...
Windows 7 gadgets working wrong
You dont need side bar anymore, rightclick anywhere on desktop and goto gadgets, Add the ones you want, put them where you want (side, top, anywhere) and thats your gadgets as they were in vista.
If you have installed Windows 7 beta then you must be aware of the bug that whenever UAC is switched off, Sidebar and Gadgets in Vista fails to display properly on Windows 7 Desktop. Though this is not for every machine but many users have reported this problem that their Sidebar and Gadgets are not working properly.
For older beta versions of Windows 7 there had been some temporary workarounds for the same problem. But if you are using Win7 Build 7000.0.081212 then this can be fixed using a simple registry hack which like in Vista will Elevate your Sidebar and Gadgets Process.
If you know how to play with you registry Editor then just open regedit.exe from Run command in Windows 7 and go to KEY
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
\CurrentVersion\Sidebar\Settings From there edit the DWORD value of AllowElevatedProcess and set it to 1. You don’t need to restart your Windows 7 computer after this. If your sidebar and Gadgets were not working properly earlier then they will be fixed instantly.
Jun 19, 2010 | Microsoft Windows Vista Home Premium with...
IT WONT WORK ON VISTA IT SAYS SOMETHING ABOUT THE MIDI DRIVER FOR THE SOUND CARD IS NOT FOUND IS THERE A WAY TO GET IT TO WORK WITHOUT GETTIN A NEW SOUND CARD
if the computer prompts you to install a new sound card, it means you cannot run the program without the sound card. you need it inorder for the progam to be compatiable with your pc desktop/laptop.
Feb 25, 2010 | The Learning Company Super Solvers -...
It doesn't work with vista
If your problem is installing the program, try to get a compatible installation package.
If it installs properly but does not run on vista:
  1. Go to the programs Shortcut right click on it and click properties
  2. Click on the compatibility tab and select the OS you used to run on. Further you can select other features that match your program.
  3. Check on Run this program as an administrator.
  4. Click Ok and test your program's different functions. Check to see if every of its features are working right. If they happen to malfunction better get a compatible version.
Nov 22, 2009 | Cakewalk Guitar Tracks Pro 3 for PC
Game won't run
HI ^^
http://www.touslesdrivers.com/index.php?v_page=29
clic on lancer la detection
follow the instructions
the website will show all missed drivers found so you can download them directly from the website
HOPE IT WILL HELP YOU
RATE IT ^^
Jun 02, 2009 | The Learning Company Super Solvers -...
Bcd3000 not working
Did you install the Vista Behringer BCD3000 driver?
see this link
http://www.behringerdownload.de/B-Control_download/BCD3000-Vista-XP-1.2.0.0.zip
Note!
You didn't mention your Vista version. Like 32-bit of 64-bit.
This driver is for the 32-bit! 64-bit is not listed(yet).
Jan 02, 2009 | Computers & Internet
The Learning Company Super Solvers - Gizmos & Gadgets! (798936820037) for PC, Mac Logo
4,368 people viewed this question
Top The Learning Company Computers & Internet Experts
Stitch85
Level 1 Expert
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
