Question about Tomtom ONE GPS Receiver
Tom tom one v1 Loose power connector
I have a tom tom one v1 and I plug it into the car using the cigarette lighter power cord which the tom tom came with.
The problem is that it will work fine for 2 or 3 mins, sometimes even longer and then it will just suddenly go off. I look at the top and the green light is also off. I fiddle with the connector which plugs into the bottom of the tomtom (push it in further most the time, but sometimes push from right to left, back to front etc. The green light then comes back on and I can turn tomtom back on and continue until a further 2 or 3 mins.
Its obvious that the battery doesn’t hold a charge, but why is it not getting a consistent charge, is it the power cable or the connector on the tomtom? Not sure if its related but connecting the tomtom to a computer via usb does not work either.
any advise would be good.
  • swmz Apr 01, 2009
    I have the same problem. The green light will only come on when I pull the pressure on power cord toward myself. I have tried another cord & problem is still the same.
  • 124 Answers
If the problem exists both when you use the vehicle power connector and the usb cable to your computer, then you have to assume that the problem is with the socket on the One. If it's still in warranty, I would send it back to Tom Tom for repair. Contact customer support for repair information.
The link is as follows:
www.tomtom.com
Posted on Jan 27, 2009
My tomtom go 510 will not charge in car but ok at home
The Car chargers are generally the defective unit.
I have also faced a similar issue as the spring loaded cigarette lighter was pushing the charger causing it to disconnect.
Jul 31, 2016 | Tomtom GPS
Valentine one doesnt work
If you can, I'd recommend it taken back for replacement or have a stereo/audio shop look at if you think its worth it.
Jun 26, 2013 | V1 Radar Detector
My Valentine One wont power up and the plug in car works the fuses are fine everything works but when i turn on for power to start the valentine One I here nothing no sound no lights. What do u think it my...
Check the fuse inside the cigarette lighter adapter that came with your V1. You'll have to pop the top off with the hinge to access a hidden screw (star pattern). Total of 3 screws. Inside you should find a 2 amp mini blade fuse, your V1 should have come with an extra fuse (mine did). I had the same issue, no power, changed the fuse and power cord, powered right up.
Sep 09, 2011 | V1 Radar Detector
Can the Tomtom recharge wheh the car is not in use - eg in the garage
No, then tom tom cannot recharge when the car is not on. You need to turn on the car before your tom tom can charge. The battery gets to charge the tom tom when in use. Once the car is turned off the gps will not charge. You can try out a practical by turning off your car and plugging the gps to see if it will work. Or the cigarette lighter, does it work when the car is turned off. Since the cigarette lighter does not turn on when the car is off, then it means it gps cannot charge once the car is turned off.
Hope this information helped you!
Jan 10, 2011 | GPS
I have vectorlite 1.5 Million Candlepower light I want to know the ac charging adapter specification. We kind of lost track of particular adapter in recent moving :(. we appreciate your help....
Most of the Vector spotlights use a class 2 charger with an output of 12VDC 400ma with a positive (+) center connector, which are very common. I have several of these chargers from different manufacturers, and I use them interchangably on whichever spotlight I happen to plug them into.
One complication with my Vectors is they use a coaxial connector plug on the spotlight end that is a size N, which is being phased out and Radio Shack doesn'd even carry any more. If you hae a box of misc chargers, find a 12VDC one with a connector that fits your 1.5MCP light, and that is probably the one that came with your light.
Note that you can also charge your light with the cigarette lighter adapter cord that came with it. So if you can't find an AC transformer that fits but you have your cigarette lighter adapter cord, you can buy one of those cigarette lighter size gadgets that plugs into an AC outlet, and then plug your cigarette lighter cord into that.
Jun 28, 2010 | Vector 1 Million Rechargeable Spotlight
GPS plug do not fit in car cigarette lighter
Buy a adapter for your cigarette lighter socket that has multiple sockets with one that will fit the Garmin adapter.
I've never heard of a problem you are having??
Are you using a Garmin plug?
If not get one.
May 08, 2009 | Garmin Nuvi 660 GPS Receiver
Unit (tom tom 1xl) turning off
One hour is about the time the unit will run without a power source.
You need to check that the cigarette lighter is working. Check the car fuse.
Check the fuse (one of the six bumps) on the cigarette lighter plug has not blown.
Is the cigarette lighter / Tom Tom lead damaged in any way?
Peter
Mar 01, 2009 | Tomtom One XL GPS Receiver
Dead
Does the cigarette lighter work in the car when you press it in? Does it get hot? If not has the fuse blown for the cigarette lighter?
If that is supplying power you may have a fault in the cigarette lighter to Tom Tom lead. Carefully check the fuse (one of the six bumps) in the plug and make sure it is still intact (use a meter).
If the fuse is OK then the lead itself may be faulty and probably needs to be replaced.
HTH
Peter
Jan 26, 2009 | Tomtom ONE GPS Receiver
Cigarette lighter came off
Test to see if you are getting +12V at the center contact and connect meter to an alternate ground point....perhaps the ground wire fell off?? Otherwise I would see if power lead slipped off rear of lighter connector.
Jun 22, 2008 | 2000 Chevrolet Blazer
Will not turn on
do you plug it into the cigarette lighter or is it installed (wired) behind the cigarette lighter. If so and you happen to plug something into the lighter you run the risk of shorting out our friend TomTom (I did it twice)
Sep 12, 2007 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
1,513 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
