Question about Gateway FPD1975W 19" LCD Monitor
My fpd1975w monitor is flickering - Gateway FPD1975W 19" LCD Monitor
  • 585 Answers
The Gateway FPD models develop problems after a couple or more years of use. The repairs are fairly easy for the savvy technician. The power inverter board in the back of the monitor contains some capacitors, they may be 470 and 220 mfd or 680 mfd depending on when they were made, @ 25 volts, with a 105 deg. C temp rating. They go bad due to heat issues and the currents they have to filter. Replacement of the capacitors usually restores operation.
Posted on Jan 28, 2009
  • 1 more comment
  • Bruce Volkers
    Bruce Volkers Jan 31, 2009
    Did thid answer your question?
  • maddfkr Dec 06, 2010
    kinda. where do i get new capacitors? how hard are they to change
  • Bruce Volkers
    Bruce Volkers Dec 07, 2010
    I find them on e-bay. Search by the values in mfd and volts. Replacing the capacitors requires a good regulated soldering iron of at least 60 watts, a desoldering tool such as a soldapult or similar tool found at MCM Electronics and similar suppliers. Also requires good soldering skills.
FPD1975W TFT LCD monitor my monitor blinks a blue power light and flsahis a white screen but it does not turn on ?
A flashing power light indicates a failure of the power supply, this will also cause the white screen. Here is a link to a page showing what parts need to be replaced to repair the power supply board and get your monitor back running again.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps, if so please rate my solution,
BuddyMc
Oct 09, 2011 | Gateway FPD1975W 19" LCD Monitor
Monitor flickers on and off and won't stay on
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Dec 22, 2009 | Gateway FPD1975W 19" LCD Monitor
FPD1975W monitor issues
Check your video card. it may be a bit lose in the port. Also, you should reinstall your video card drivers as well. make sure your monitor is plugged into the correct video card AVI/dvi input port.
Jan 27, 2009 | Gateway FPD1975W 19" LCD Monitor
Flickering screen
If you bought it new in this last August, don't put up with it but get it fixed under the warranty. That is what warranties are for.
Jan 23, 2009 | Gateway FPD1975W 19" LCD Monitor
GatewayFPD1960 TFT LCD 19 inch
cheak wheather cable is connected properly
Jan 08, 2009 | Gateway FPD1975W 19" LCD Monitor
FPD1975W 19" screen went out.
I HAD THE SAME PROBLEM. BLUE POWER BUTTON WOULD TURN ON-OFF-ON-OFF WHILE THE SCREEN FLASHED. THEN AFTER UNPLUGGING IT THE SCREEN WOULD FLICKER. THEN JUST WOULDN'T COME ON. GO ON EBAY FIND SELLER BAMMBAMMFRAN OR SEARCH FOR YOUR MONITOR. HE SELLS A PRODUCT REPAIR FOR $30(NOT INCLUDING SHIPPING). I SENT MY BOARD TO HIM. YOU CAN TAKE YOUR MONITOR APART AND SEND HIM THE INVERTER BOARD OR THE WHOLE MONITOR, ONLY DIFFERENCE IS THE SHIPPING COST. HE WILL LET YOU KNOW IF IT IS FIXABLE(THE INVERTER BOARD). IF I REMEMBER CORRECTLY HE ONLY CHARGES IF IT IS FIXABLE. I TOOK MINE APART AND SHIPPED THE BOARD TO HIM. HE FIXED IT AND SENT IT BACK TO ME. MY MONITOR WORKS GREAT.
Oct 24, 2008 | Gateway FPD1975W 19" LCD Monitor
Thin yellow line on the right of the LCD Screen
If it's a straight line from top to bottom panel could be defective.Not much you can do as cost of panel will compare with a new monitor.
Samir
Jun 08, 2008 | Gateway FPD1975W 19" LCD Monitor
MONITORS
Inverter Power board 19 Gateway Monitor FPD1975w
Apr 09, 2008 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD1975W 19" LCD Monitor Logo
319 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
