Question about Linksys Wireless-G WPS54GU2 Print Server
How do i get my wps54gu2 connected to my router on windows 7
2 Suggested Answers
  • 643 Answers
SOURCE: Do you know how to set up the WPS54GU2 printer
After starting the Add Printer Wizard, the trick is to select Local Printer
Attached to This Computer. This is counter-intuitive, but you're not
connecting to the printer using MICROSOFT Networking, so MS doesn't consider
this to be a network printer. Don't select Automatically Detect with Plug
and Play.
On the Select a Printer Port screen, choose Create a New Port. Type of Port
= Standard TCP/IP Port.
Be sure that the printer server and the printer are ready before proceeding.
For Printer Name or IP Address enter the print server's IP address. The
protocol is LPR. You'll need to get the Queue Name from the print server
documentation. It's probably "lp" (that's a lower-case el, not a capital
eye).
Posted on Nov 13, 2010
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
What address do i use to configure my linksys wireless router model #WPS54GU2 to my computer. The one I was given http://192.168.1.1 is not working.
In the start menu click on "Run" (or hit windows key + R), in the run dialog type "CMD" and hit enter, then in the black window that opens type "IPCONFIG" and hit enter, then on the line that starts with "DEFAULT GATEWAY" that address is the one you need to use.
Oct 29, 2010 | Linkskey (LKR-604) Router
Is Encore ENHWI-N3 Wireless Router windows 7 compatible?
You should be fine using it with Windows 7, as there is no drivers as such for the router, you are just using the wireless (or wired) connection to the router, and windows doesn't really care how it gets there. As long as the adapter you are using to connect to the wireless network is windows 7 compatible you should be fine.
Hope that helped!
Oct 16, 2010 | Encore ENHWIN3 Wireless Router
Cannot get a 2Wire Gateway to recognize linksys wireless print server (wps54gu2). Can set up using lan and fix IP, enter wep password, etc. Once disconnected, gateway doesn't even recognize device.
1. Need to know what OS ( operating system) you are using.
2. Have you check if the settings are on " automatic DHCP and do you have the router
3.Check the firewall settings. This disconnection if not on the "access list" in the firewall settings.
4. Make sure you have the most current firmware updates on the router.
5. See if you can "ping" the wireless router.
6. check the " up grade history" page.
Apr 19, 2010 | 2wire 2700HG-B Router (2700HGB)
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
Upgraded to windows 7 and i am unable to connect to the internet. I get a limited or no connectivity
I'm thinking modem/router combination. first power down modem and router. Then leaving router unplugged, power up modem, make sure it's sync up then power up router. If this is a wireless connection search for your networks name on computer/laptop..ie View wireless connection. Windows allows a automatic setup if the wireless connection is unsecured. If it is secured Windows 7 will prompt a pass phrase/ or access code. Good luck. Repeat process if necessary
Jan 31, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Is Netgear Route WGR614V5 compatible with Windows 7?
Please note that this router is compatible with Windows 7. Please perform the below steps on your Windows 7 computer to connect to the wireless network:
1. Click START, Click Control Panel.
2. In the main screen, open up NETWORK AND INTERNET.
3. Click on Connect to a network.
4. Select your network and connect to it. If you have a Password setup on the router enter the security key.
5. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jan 04, 2010 | NetGear WGR614 Wireless Router
I have a trendnet wireless router tew 432brp, a new hp windows 7 laptop, and old xp laptop and i want to share the connection with my verizon um175 aircard. this has worked for several years with the old...
The router connects computers together . You are using a windows 7 p.c and connecting it to an internet connection via a usb verizon um175 aircard.
I think you need to share the internet connection with the rest of the network and may need to feed the ethernet cable into the feed port of the router. I have not done this before but logically the windows 7 computer would have to act as a gateway to the internet.
http://www.dummies.com/computers/operating-systems/windows-7/how-to-share-an-internet-connection-in-windows-7/
https://www.ibvpn.com/billing/knowledgebase/53/Internet-Connection-Sharing-on-Windows-7.html
Note the default gateway is going to have to be the windows 7 ip address on the other computers
You may need to set the ip address on windows 7 to a static address and then change the dhcp server settings default gateway and also increase the first address to not include the windows 7 ip address or the routers ip address in the lease range for shcp.
Mar 17, 2017 | Trendware TEW-432BRP 54Mbps Wireless...
No print sharing. Existing but lder Belkin router has no problems, but WRT54g-TM will not print share. Have a Netgear switch box as well, can I integrate the two or even all three to solve print share...
If you are using a belkin router, wrt54g-tm and netgear switch box. Basically they won share the printing. you need a wireless print server..try the linksys WPS54GU2
Jul 28, 2009 | Linksys WRT54G-TM Wireless Router
Wireless-G WPS54GU2 Print Server Lost disk
if you visit the LinkSys website you should be able to download all applicable drivers and files for this print server. Also you will likely be able to access a user manual (in PDF format) which should give you all the information you need.
May 27, 2008 | Linksys Wireless-G WPS54GU2 Print Server
Linksys Wireless-G WPS54GU2 Print Server Logo
41 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
