Question about Oster Microwave Ovens
Oster OMW1199 microwave/grill oven
Double hook lock, one hook broke, after repairing the oven will not work but the clock and the light do, then adjusted the door more snuggly, now nothing works, located the fuse, don't know how to check it. help!
  • 883 Answers
SOURCE: Oster Microwave/Convection/Grill
first, get your money back or get a replacement for no charge. now, unplug the oven for 15 minutes and try again. if no-go, then some device is faulty that only a tech can find
Posted on May 28, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave oven - just stopped stopped working
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: neff h7871
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 06, 2008
SOURCE: Oster 1.1 cu. ft. Stainless Steel Combination Microwave Grill - OMW1199
After six months I just figured it out. Push the cook by weight button in and hold it until the clock function comes on. Turn left for hour and right for minute. Figured this out by holding the cancel button in and a child lock came on, I didn't know how to release it so I reversed the process by holding it in and it cleared. I tried it with the cook by weight, which has a small clock icon next to it and voilla.
Posted on Nov 03, 2008
jlaw21652
  • 3 Answers
SOURCE: Frigidaire GLMV168CS1 Microwave - Sensor Error
If you are handy take it apart. Somewhere inside is a small switch that the door activates. Switch might be broken or a small plastic actuator might be broken. What do you have to lose at this point except time?
Posted on Feb 14, 2009
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Hi, I have an Oster OMW1199 microwave that will not heat food. The light turns on and the timer works, but no heat.
I bought-the oster microwave and like others it did not last long before it stop heating. I took (careful precaution!!) and (unplugged the the unit!!) to view the fuse which of course is the main problem why this microwave does not heat up. Everything else works well but the heating. But since I changed the fuse to something very close to the same amp of the actual fuse it did work fine next to nothing.
I did not find any problem other than the noheating. This should only be attempted by someone who is in fact has close knowledge of electricity. The process is safe (WITH THE CORRECT PRECAUTION!!).Ever since I replaced the fuse and found out that that was all it needed I have been using it for 8 mths. Note--I did take measures into my own hands which is not recommended by anyone. But it is the old-fashion way...
Aug 28, 2011 | Emerson Fans Emerson MW8115SS Microwave...
Received for Christmas 2010. Worked great! Few nights ago, made something to eat, and it shut off. Light, clock, everything. After a few minutes, it came back on. Used it last night, same thing. But this...
The joys of purchasing items with a bought out warranty. Check the plug and contacts on the fuse.
You could either call a microwave repairer and pay for callout and repair or purchase a new one.
May 30, 2017 | Oster OGG61403 Microwave Oven
Oct 26, 2008 | Microwave Ovens
I have a Neff Microwave/Oven/Grill combo. The grill and the oven parts still work, but the clock has gone off and the microwave part does not work. What can i do to fix this?? Thanks
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jun 25, 2008 | Neff Microwave Ovens
Changing light blub of oster microve oven
The lamp is located under the stainless top cover of the microwave which unscrews from the back and sides, the bottom corners in the back have special torx screws which are meant to thwart you from removing them but a pair of locking pliers does the trick. Then under the cover on the top of the microwave there's a black elliptical shaped base with only 1 screw holding it down, that is the lamp. Pull the female spade connectors from the lamp, unscrew it and take it out. Oster has about the worst customer service around so i have not verified that they will sell a replacement lamp but if you can find a 20W 120V replacement with spade connectors that will do.
Jan 15, 2008 | Microwave Ovens
May 28, 2007 | Sharp R-930AK Convection/Microwave Oven
Microwave Ovens Logo
64 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
