Question about Staples Office Equipment & Supplies
I have a staples shredder model TXC22A and the approaching cool down light stays on continuously. It will work in reverse but will not work in forward motion
fellowesrep
  • 102 Answers
SOURCE: Shredder not working
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Sensor is usually located in the center of the paper feed opening.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Posted on Mar 02, 2008
SOURCE: Model: SH9210PL
sensor is dirty. clean the sensor. it is located approx. 3 inches from left side of paper slot, 1 inch below top.
Posted on Feb 22, 2009
Testimonial: "I got this reply long ago & it worked perfectly. I was a new user & obviously did not do every thing necessary to remove it from my question list. "
  • 215 Answers
SOURCE: Fellowes PS60C-2 shredder doesn't shred
there are two switches under the cutter area. 1 for sensing when your basket is full, (sometimes these bin-full flaps get stuck in the up position, energizing the switch) and the other is a switch that detects if your basket is installed. fellowes has modified these shredders so many times, that there are alot of different configurations. look for something that resembles a flap under the head and make sure its in the down position. as for the basket sensor, some baskets had 2 projections on the left and right top of basket. one may be broke. if so, you can "cheat" the switch with a screwdriver to see if thats the problem.
hth,
razors
Posted on Apr 15, 2009
  • 45 Answers
SOURCE: Our shredder is making a loud, grinding noise.
simply try resetting the machine. unplugging it waiting for about 30 seconds then plugging it back in, also is the unit mounted properly on the unit? It might be one of the gears that is not broken...if you have a warranty now would be a good time to call them as they will fix or replace the part for the unit.
SOURCE: staples SPL-770M shredder with overheat light even when cool
Just a FYI: I had the same problem. Nothing appeared jammed. But I took the housing cover off and low and behold the rubber roller that turns the shredders had MELTED to the inside. That's why it wouldn't work. This happened while shredding a single DVD - something I had done effortlessly on numerous occasions. You may want to check to see if the roller melted or if some debris has jammed up inside the unit, like mine did often.
Posted on Jan 08, 2010
Staples Shredder SPL-TXC22A makes a "clunking" noise during use. Noise diminished after feeding a couple of WD-40 soaked paper towels but noise returned. Fixable?just use it until it dies and replace?
probably find that some cutters have been damaged and are hitting each other rather than sliding past each other
using wd 40 is lubricating those cutters but as the lubricant is used by the new paper it becomes inefficient
get a quote for repairs but generally ( unless the machine cost is in the 4 figure area) it is not cost effective to repair
Nov 28, 2016 | Staples Office Equipment & Supplies
I have a Staples Shredder model SPL-TXC6A (serial 0809026807), which I have been using a lot lately. The auto and reverse buttons will not function, & neither will the forward button.
If you have used it a lot, it may have tripped the thermal fuse. Normally, these reset themselves. One thing to make sure of,, is that the safety switch under the machine is firmly on the pin in the basket under it.
This is a light duty shredder, you can only use it for two minutes!
6-sheet, light-duty, up to 25 uses/day
Runs 2 min on / 4 min off
http://www.snoopdeal.com/bargain/43085/Staples-SPL-TXC6A
Nov 21, 2016 | Office Equipment & Supplies
Why wont my staples titanium shredder continuously shred?
Not giving a model number, it's hard to say. But quite probably after use for 20 mins, the machine starts getting hot, and then it shuts down while the machine cools down.
I had the same issue with a shredder of mine. It prevents the machine burning itself out.
If you want one that just keeps going and going without heat issues, you have to pay more for a better shredder. Unfortunately.
Jul 30, 2014 | Industrial Paper Shredders Office...
Staples Shredder SPL-TXC22A always has the jam light lit and will not work even though there is nothing jammed. It works if I press and hold the down button twice. It also works continuously if I turn off...
Home office shredders get jammed because the mechanism is not self cleaning. If you remove power and expose the mechanism you may find that, indeed, a shard of paper is triggering the jam sensor. These shredders require periodic removal of the bits of paper from the mechanism, an exercise that can consume hours of picking with tweezers while thinking there must be a better way.
Dec 10, 2013 | Office Equipment & Supplies
Staples TXC22A. Why does Jam Light prevent shredding?
Your meticulous cleaning may have overlooked embedded residue from coated paper or paper laminated with plastic. It may be necessary to use a sharp pick and even a utility knife to remove the material bit by bit.
Feb 05, 2013 | Office Equipment & Supplies
Staples SPL-770M shredder with overheat light even when cool
Sep 10, 2009 | Office Equipment & Supplies
The unit shuts down after using for 4-5 minutes and I smel burnig
Sadly, light duty machines as yours do overheat and shut off. Shredders are rated for run time. An example: 4 min run time with 60 min off to cool down. I could not find your machine's rating. However, given the 10 page volume I would guess the rating close to the 4 min on.
High volume shredders are rated as continuous run. They should never over heat.
Apr 21, 2009 | Cross Infoguard Shredder SX102M
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Terry Hair
Tom Chichester
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
