-   Brother fax2820 paper keeps jamming in the back.
I check all the sensors
took a part the hole back end of the fax, work fine for a few days and it was back to the same thing jamming in the back.
-   Guest
Jul 13, 2008
-   LCD READS: DOCUMENT JAM/CLEAR PAPER JAM FROM SCANNER. HAVE CHECKED AND CLEARED ANY/ALL PAPER. THERE WAS NONE. TURNED-OFF POWER. DID NOT SOLVE PROBLEM. REMOVED TONER/DRUM UNIT. REINSTALLED. DID NOT SOLVE PROBLEM. HAVE PERFORMED ALL TROUBLESHOOTING RECOMMENDATIONS. STILL NO LUCK. PAPER FEEDS ROLLERS STILL CONTINUE TO RUN UNCEASINGLY; AND DO NOT STOP UNTIL LCD WINDOW SCROLLS PROBLEM. CAN YOU HELP?? MUCH THX. BICHE-   biche
Jun 27, 2008
-   How do I remove the drum can't even find where it is located please help me
Pamela-   Guest
Jun 27, 2008
-   I HAVE FAX 2820 SAYS PAPER JAM IN TRAY JAMS EVERY TIME PLEASE HELP CAN'T EVEN USE IT
PAMELA-   Guest
May 01, 2008
-   I HAVE FAX 2820 SAYS PAPER JAM IN TRAY ITS LIKE IT WON'T PICK UP PAPER RIGHT IT JAMS EVERY TIME PLEASE HELP CAN'T EVEN USE IT-   BIG Kk
Out of the lower paper tray when you go to print? Try this, remove the cassette tray and use a water dampened cloth and clean the gray paper pickup roller off. A lot of times this has paper fiber build up that causes the paper not to feed. The printer has a certain timing pattern for when paper should reach a certain sensor, and if it doesn't, then a jam error will occur.
brother fax machine model no.2820: what is the meaning show on the screen :Fax in Momory:60, always...
(More)
brother fax machine model no.2820: what is the meaning show on the screen :Fax in Momory:60, always the fax cannot get through, how to clear memory for outgoing fax ? seems like the failed outgoing fax all stuck in the momory ? 1 more need to confirm is each document the machine will try 3 times to do fax out, if failed 3 times, then machine will automatic clear this document in the machine or not?
I have this problem quite a bit with my Brother Itellifax 2480C - I have found on occassion just turing it off will solve the issue (while losing the incoming fax) and have also had luck opening the entire top section (not the back cover as instructed by the machine) - the whole piece below the glass, which has led to a reset and no loss of the fax which was being received.....there was no paper jammed ever, fyi...........seems to be an issue with the machine - not thrilled with it.....
Comment by Guest, posted on Mar 13, 2008
paper jam every time fax is recieved
Comment by Guest, posted on Nov 09, 2007
what is a cassette tray and how can I identify the gray pick up roller
