Question about Sharp Televison & Video
My Sharp lc-42sb45ut turns off and on by itself
It will shut off and on at random
  • 3 Answers
SOURCE: my sharp lc 32d42u shut off and won't turn back on
IF YOU STILL HAVE SOUND I AM PRETTY SURE WHAT THE PROBLEM IS...
Posted on Nov 20, 2009
  • 117 Answers
SOURCE: My Sharp Aquos LC-52D64U shut off by itself, and
sounds like power supply/ohm supplies for repair in uk
Posted on Nov 23, 2009
  • 8457 Answers
SOURCE: Sharp lc-60e88un is less than a month old. It
Call 1-800- USA Sharp for warrrenty repair.You have to talk and test by the Sharp Tech. "Randomly"known as intermitten problems,hard to determine what exact parts are dying.
Posted on Sep 01, 2010
bugoy31
  • 1238 Answers
SOURCE: i have a sharp aquos model Sharp Aquos LC-20B2U 20
if your TV lights the indicator when you power it on,, your problem is your back light is busted you can replace that and when the indicator not lights the problem is your power supply you can fix it by finding defective parts by using multimeter usually the trouble that i encounter to power supply is open/change value of resistor leak capacitor and shorted diode and transistor such as regulator you're always welcome
Posted on Mar 05, 2011
bshldn
  • 736 Answers
SOURCE: How to connect my Vizio vsb200 to my sharp
This television does not have audio outputs so you wouldn't be able to connect these two devices--well the one digital audio output this television has is not compatible with any of the inputs on this Vizio. Double check please by looking for a hole/input on the Vizio that will match up with that on the Sharp television. If I am wrong and there is one then you would need the digital audio cable. I believe this television takes a coaxial digital audio cable, and the hole that would correspond to this cable on electronic devices is normally black in color.
If I am correct and there is no way to connect these two devices directly then you would connect your devices to the Sharp television for video only and connect their audio cables to the Vizio's inputs.
Posted on Mar 08, 2011
My Sharp LC-42SB45UT Television was on and the sound on it just quit.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 15, 2017 | Sharp Televison & Video
What is ic903 on a sharp 715t3150-3 power supply board
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 27, 2014 | Sharp Lc-42sb45ut 42" - Active 42" Tv -...
Lc 42sb45ut
its losing its mind..bury it
Jan 08, 2014 | Office Equipment & Supplies
Sharp lc-60e88un is less than a month old. It shuts off and on all by itself randomly. No blinking light or codes.... HELP!
Sep 01, 2010 | Sharp LC60E88UN 60 in. LCD TV
Sharp LC-52SE94U shuts down and restarts automatically
There is a software update for this model via the Sharp website. Included is a link to the compressed folder. Once you uncompressed the folder there are instructions in the folder on how to install the update. It doesn't specifically say this is a fix but as a TV technician personally its the fist thing I would try.
Link to Sharp software update
Nov 17, 2009 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
Random turning off/on while watching tv
sounds like it could be a power issue. is the powercord on the back of the tv detachable? make sure its plugged in tightly. also if using a surge protector reset surge protector. if not using a surge protector try a different outlet. also if gfci outlet (has reset button on outlet itself) try resetting the outlet by pushing the reset button
Apr 04, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
T.V. turning on
yes my 26" sharp aquous LCD does the same thing, turns itself off and on at random times without explanation. I sent to authorized service center they replaced the power supply under warranty then it failed within 6 months and neither the repair center nor sharp will do anything about it other than sell me a new powersupply for $425.00. I have contacted a power supply repair center in Texas who has vowed to fix it once and for all. We'll see in the next week if they fix it or not.
Oct 30, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
