Question about Harman Multimedia AVR 245 7.1 Channels Receiver
My Harmon kardon avr 245 won't stay in Dolby digital mode
HK AVR 247 no power up
Could be an open internal fuse or power supply failure.
Sep 19, 2016 | Harmon Kardon Harman Kardon H/k Avr20 Mkii...
Harmon avr 445. Wont. Turn on
First check power cables and fuse
Jul 08, 2013 | Audio Players & Recorders
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
My Harmon Kardon AVR 2600 goes to protect mode when powered up. After many tries it will fire up but at times it's up to twenty times. I did load the software upgrade 6 months and it has been fine
Check all speaker wiring for shorts, if okay! there is a problem in the audio output stage of the unit or the protection circuit is not working properly. I would suggest a pro to evaluate.
Apr 02, 2012 | Harman Kardon AVR 2600
I have a AVR 3600 Harmon Kardon reciever and once and a while the sound will just cut out then come back on. In the display it will change from dolby digital to another format then just come back on. Any...
Looks like the Power relay is switching off and on by itself. Chances are that a power capacitor might be going weak. Get in touch with a Harmon technician to fix this.
Mar 05, 2011 | Harman Kardon AVR 3600
I have a harmon kardon avr 120 and a samsung blu ray player.the audio is connected through the optical cable. the receiver however is only playing 2 channel audio. but my direct tv, which is also...
Check that the player's Dolby / DTS is enabled. Sometimes it is defaulted in the player to 2.0 / Stereo PCM. What model Samsung? Those Harman receivers are old favorites of mine...
Jan 06, 2011 | Harman Kardon AVR 120 Receiver
Blu- Ray Surround Sound
Try optical from PS03 to reciever then change sound settings in menu.
Oct 22, 2008 | Sony Playstation 3 (PS3) Console
Harman kardon avr-147
Hi Javis. This is perfectly normal ! This mode change is done because the receiver auto detects the digital audio signal and sets the receiver's DSP to decode the signal correctly. You can go into the OSD menu to bypass the auto detection of it, but it's not recommended at all ! You're getting the best audio quality by doing so. Thanks ! cheebster.
May 07, 2007 | Harman Kardon AVR 240 Receiver
Harman Multimedia AVR 245 7.1 Channels Receiver Logo
Top Harman Multimedia Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
Steve
Are you a Harman Multimedia Audio Player and Recorder Expert? Answer questions, earn points and help others
