Question about Car Audio & Video
Can i hook up two kicker zx 400.1 amps together
    Scholar:
  • 116 Answers
No,you can't as prthe specs here http://www.crutchfield.com/p_206ZX4001/Kicker-ZX400-1.html?tp=115&tab=features_and_specs but you CAN run one amp per sub. Either a 2 ohm sub or a DVC 4 ohm would be per-fect. Just make sure that each sub is in it's own chamber not sharing air with the other.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Nov 09, 2012 | Kicker Car Audio & Video
I have 2 JL Audio 8W0's rated at 75 RMS. I had a MTX 280 Amp pushing them but need to replace it, what brand and size amp do you recommend for these speakers.
  • This Kicker Amp will compliment them JL Audios like nothing else. KICKER ZX Series ZX350.4 4 channels all rated @ 75 watts RMS. If it was me that would be my choice for a replacement amp.
http://www.amazon.com/KICKER-ZX-ZX350-4-Amplifier-4-channel/dp/B000ENSSPM
Regards, Tony
Apr 29, 2011 | Car Audio & Video
Hi, I currently have the following Kicker Amp's.\r...
it depends, sometimes if your speaker is wired, if you have two dual 2 ohm subs and wire them in series ( +to+ -to- ) then they will wire down to .5 ohms, in which your amp is not stable other possible problems may occur if you wire these amps together to power one or two subs
May 18, 2010 | Car Audio & Video
Zx-8100 amplifier is red lighting.
try wiring them differently. here is a link for u to go to http://www.crutchfield.com/learn/learningcenter/car/subwoofers_wiring.html . once there find your amp configuration (ie. mono, or 2 channel) then down to the type of subs an how many subs ( ie. 2 dvc (dual voice coil) 4 ohm subs) an that will show u how the subs should be wired and wired to the amp.
Mar 21, 2010 | Volfenhag ZX-8100 Car Audio Amplifier
Can i hook up my sub if it's wired to a 2 ohm and my amp is 4 ohm
Hi martineztag
You should never connect a load of an impedance less than the min the amp is able to drive. This can have disastrous consequences that may easily result in failure of the amps output stages. You need to use a different configuration that does not overload the amp in this manner for safe operation.
regards robotek
Jan 19, 2010 | Kicker Solo-Baric S12L5 Car Subwoofer
Hooking up 6x9's to a amp
yes as long as u put in on the high pass filter (HPF)
Dec 07, 2009 | Kicker ZX200.2 2-Channel Amp - 140W ZX...
Kicker zx 1000.1 green light flickers and no sound
The first thing I would suggest is to check all connections to the amp and speakers, especially the ground. A loose ground can cause the problem listed. You can test this by temporarly running a ground from the amp to the battery neg. . If the amp fires up ok then that means your grounding point for the amp should be checked and cleaned and reattached firmly. If you have a meter(multitester) set it to ohms and check the impedances of the voice coils in the woofers. If one is cooked it may be shorted and tripping the amps protection. Always hook thing up with the sys off and then turn on and test.
Jul 21, 2009 | Kicker ZX10001 Car Audio Amplifier
How to get the best out of this amp
"google" subwoofer wiring diagrams to find out how to hook it up to the right ohms and everything..........hope this helps
Mar 21, 2009 | Kicker ZX350.2 2-Channel Amp - 220W ZX...
Car Audio & Video Logo
90 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
