Question about Anycom Ex1 Bluetooth Headset
How to pair an anycom executive ex1 to a cellphone
How do you activate the pairing mode in the headset so the phone can detect it?
5 Suggested Answers
PyroPCMan
  • 405 Answers
SOURCE: forgot what the default pairing PIN is.
Default pin is "0000"
Posted on Feb 19, 2009
wbigtodd
  • 19 Answers
SOURCE: pairing a anycom paros-10 an its asking for a passcode
Most of the time you will use the passcode 1234 are 0000.
If not email me back.
Thanks,
Todd
Posted on Jan 02, 2010
SOURCE: How can I pair the anycom ARIS-21 bluetooth with
Just push the button for a long time until the led is not flashing but the colors of the led are changing red and green. I connected it to my laptop and my phone too.
Posted on Sep 27, 2010
  • 91 Answers
SOURCE: can't figure out how to
you must put your blue tooth device into discovery mode most manufactures use the power button,by holding it for 6 to 10 seconds while turning it on will put it into discovery mode and if you have your bt power turned on in your phone menu then you can search or add new device,once they have paired it will ask for a pin or pairing code .Most blue tooth device manufactures use a 4 digit pin code they are as follows 0000,1234,9999,or 1111 i hope this helps
Posted on Feb 22, 2011
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
Forgot passcode and cant find manual so i cannot pair it with my new phone
iIf you know how to put ur device into pairing mode then most pass codes or pins\pairing codes are as follows 0000,9999,1111,or 1234 most blue toth manufactures from north america use 0000 i hope this helps but you need to know how to put ur blue tooth device into pairing mode ,usually you hold the power button on for 6 to 10 second untik u have a solid light or tone depending on the device u have..once again i hope this helps
Feb 21, 2011 | Anycom HCC-250 Bluetooth Headset
Can't figure out how to pair anycom bsh 100 with my phone
Feb 20, 2011 | Anycom BSH-100 Consumer Headset
How to switch on jabra bt150 blutooth handset
First Fully charge the BT150. Turn BT150 on by pressing the "answer/end button". To put the BT150 into pairing mode press the answer/end and volume+ at the same time to activate pairing mode. Next Set your mobile phone to detect a Bluetooth device. Press yes or ok to pair phone with Jabra BT150. Put in pass key 0000 (four zeros) Then press yes or ok. Your phone will confirm when pairing is complete. Enjoy your earbud/headset.
Dec 26, 2010 | Jabra BT150 Wireless Headset
I have a kyocera bluetooth and I lost the code to pair it with my phone how can I find it? 739G-001 is on the headset. I can pair it with my phone if I can find the passkey I have a samsung phone. The...
I just paired one that sounds like yours with my phone and don't remember needing a pass code, but try 0000
From the quick start guide at:
http://www.kyocera-wireless.com/support/pdf/bluetooth-kyo105-quick-start-guide.pdf
PAIRING THE HEADSET WITH YOUR CELL PHONE
Note: Ensure your headset is powered off, and your cell phone is powered on.
a. Press and hold the Multi Function Button for 6 seconds until the LED Indicator flashes red and blue. A tone will sound indicating your headset is in pairing mode.
b. Activate the Bluetooth connection from your cell phone. Execute the search function to search for Bluetooth devices. When the search completes, a list of supported devices will be displayed on your cell phone screen.
Note: The headset will not be detected unless first placed in
pairing mode.
c. To start the pairing process, select KYO105 from the device list.
d. When prompted select 0000 as the passkey.
Jul 18, 2010 | Samsung Lands Phones
Can not figure out how to connect my ANYCOM Milos-9 to my cell phone. no instructions came with product.
Turn off the Anycom headset. After it is off, press and hold the silver power button. You will see a blue light come on but dont let go off the power button, keep holding it till the light turns red. Then the device will be in pairing mode. Turn on the phone and make sure that the phone is visible in the bluetooth settings. Scan for a device in the phone and you should see the Anycom headset. If it asks for a code to enter then the code is either 0000 or 1234 or 9999.
Dec 27, 2009 | Hagenuk Anycom MILOS-9 Bluetooth Headset -...
Dec 20, 2009 | Anycom Aris21 Bluetooth Headset Wireless...
I am trying to pair a Blackberry 8900 to the HS830 Bluetooth device. I know the passcode is 0000. But the Blackberrry is not detecting the HS830 at all. It detects other Bluetooth items, but not this one....
Put the headset in PAIRING mode, if it has been paired with another phone, it will not accept a new pairing or another phone until you put it in pairing mode again. Press the button until the LED gets steadily ON, search the headset and pair it with the new phone. It only accepts one paired phone at a time.
Nov 04, 2009 | Motorola Mobility HS850 Consumer Headset
I need to know how to connect it to my phone
The owners manual for the Aris21 Bluetooth Headset is available here:
http://files.anycom.com/documents/manuals/cc3101-manual-en.pdf
Specific instructions on how to connect it will depend on your Bluetooth mobile phone model. Typically, this has to be done by going to a setup or connect menu and then selecting the options to discover Bluetooth devices.
Before you start the process, make sure the Aris21 is fully charged and the charging cable is disconnected from it and while the
Aris21 is powered off, press and hold S1 for 10 seconds: red and green LEDs flashing alternately will indicate that the headset is in pairing mode.
Then follow the operating instructions for your Bluetooth mobile phone to start the pairing process. Bluetooth may take several seconds to establish a connection.
Your phone's display should indicate that it has found the “ANYCOM ARIS-21” headset and asks if you want to pair it. You should confirm this. The phone's display would prompt you for a passkey or PIN. Enter a sequence of “0000”.
The headset LED will flash green every 3 seconds, indicating successful pairing. Usually the phone will also ask whether
you want to change the headset's name. It is recommended to approve the ANYCOM ARIS-21 name and not change it.
If pairing does not occur as expected: Turn the headset and the phone off and wait for 10 seconds. Turn the headset and phone on again and repeat all steps from beginning. Pairing does authorize the devices like mobile phones and headsets with each other and only needs to be performed once.
After successfully pairing the ARIS-21 and the mobile phone, you may need to establish a Bluetooth link between them according
to the operation manual of your mobile phone. To establish the link, press S1 shortly. Use Nokia 6130i as an example, the mobile
phone will show „Do you accept ARIS-21 request for connection?” Select YES to establish the link. You are ready to make and
answer calls on the Headset. For other phones, please follow the operation manual to establish the link.
Aug 30, 2009 | Anycom Aris21 Bluetooth Headset Wireless...
Anycom Ex1 Bluetooth Headset Logo
42 people viewed this question
Top Anycom Radio Communications Experts
eradiostore
eradiostore
Are you an Anycom Radio Communication Expert? Answer questions, earn points and help others
