Question about Samsung HL-P5063W 50" Rear Projection HDTV
Colors on my hlp5063wx are all wrong
I just changed my color wheel on my samsung hlp5063wx tv. now when I turn it on the color is wrong my blue screen is red. When I get into the menu to look at my color settings where it has red,blue and green . where it says red the bar is blue. where it says green the bar is green and where it says blue the bar is red. All the flesh tones on the people on tv are blue and most of the shadoes are green. I am shore this is the right color wheel a samsung rep looked it up and told me which one to buy. any help would be greatly appr. Adam .D
  • 2 more comments
  • viking47 Jan 26, 2009
    I have already installed it two times
  • viking47 Jan 27, 2009
    I pulled the jumper out and that fixed the problem with the red and blue. The only prob now is my black has a green tint
    you saved me a lot of stress I pulled the jumper and played with the color and it works great now a million thanks well worth ten bucks.
  • viking47 Jan 28, 2009
    Shuttle83 is the man he solved my problem even the tech people at samsung couldn't answer. As far as me being sattisfied with his help I could not be more sattisfied you truly are a wiz. If I ever need assistance in the future I will do my best to get it from you. Again thanks you are one smart motor schooter. Tv picture looks great and my faith has been restored in mankind now all is well in my living room once again. Thanks much Adam D. viking47
    Master:
  • 505 Answers
I was going through all the suggestions. Its likely that the problem is with the Digital Processing board \LCD controller which need to be replaced or repaired. I would sufggest you to contact some local tech shop or Bestbuy. You can also click on the link http://www.samsung.com/us/info/contactus.html# and submit the information.
Thanks
Posted on Jan 27, 2009
    Genius:
  • 1,199 Answers
The Jumper has to be removed from the wheel to work right on your model!
Posted on Jan 26, 2009
    Genius:
  • 1,139 Answers
Hello viking47,
There is a jumper on the color wheel the you need to remove to take care of this problem. These parts are often used in other sets that have a different lay and circuit orientation. Just remove the jumper and you should be ok, please refer to your documentation on where the jumper is located.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
  • Henry McKelvey
    Henry McKelvey Jan 28, 2009
    You requested assistance with the black being out of line?
    OK here is an answer that should work, contact me if it does not.
    Reset your IndexDelay by using this method on your remote. Try to use this: PowerOff, Mute, 1, 8, 2, PowerOn set your IndexDelay to 45 and this should set the black levels to normal.
    I hope this helps,
    Shuttle83
    http://www.electron-age-technologies-llc...
  • Henry McKelvey
    Thank you for the commendation. It is good to know that my mis-spent youth can be put to good use :D.
    Have a good one, and enjoy your TV watching.
    Shuttle83
    llc
    .com/">http://www.electron-age-technologies-llc.com .com/">http://www.electron-age-technologies-llc.com
    Sergeant:
    Novelist:
  • 326 Answers
The procedure to solve it in detail is as on the link below: http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
  • technodeal Jan 27, 2009
    If you are using high def component cables make sure they are plugged in secure and correct. If that is not the case then It could be that the GPU is overheating. You will need to pull it apart and replace the X-clamps with machine screws and replace the silver compound on the GPU and CPU. This should solve your problem.
    Sergeant:
  • 221 Answers
Just remove the wheel and reinsert it again
for exact procedure
how to replace the colour wheel with diagram and procedure
MY TV STARTS EMITTING A BUZZING SOUND AFTER IT'S BEEN ON AN HOUR OR SO. It is a Samsung DLP model HLP5063WX/XAA.
Its likely to be the color wheel which when fails can do several things: A high pitched whine or what is often described as a fan like sound.
Since the set monitors the speed of the wheel if it slows down even a little image may look odd or dark.
you can at worst hear a grinding sound and it means segments in the wheel are shattered or missing
Good news is it is readily available and many average people can replace it---you tube even has video instructions for most of the Samsung models for this.
Only two models were made and Google the model number with Color wheel to locate the one your set uses.
Dec 22, 2012 | Samsung HL-P5063W 50" Rear Projection HDTV
TV SAmsung, the picture is bad after color wheel changed
Hi,it's possible they gave you a different color wheel,there's a silver version and a gold version they spin at different speed,so mostlikely they gace you the wrong version check what this website says about the 2 versions : http://www.discount-merchant.com/product-p/samsung_bp96-00674a_colorwheel.htm God bless you ask for a refund.
Oct 06, 2009 | Samsung Televison & Video
My tv is a samsung dlp. i have determined that
most of the time you just need to replace the color wheel; the jumper they are talking about is on the DMD board which is a metal box attached to the light engine---if the jumper needs to be removed you will have a working set but the color will look odd--usually missing blue or red---it is a small two wire plug with a jumper and can be removed with a hemostat or needle nose pliers.
If you buy the color wheel I have specific instructions that you will not find on line to avoid problems when you replace it--lots of people think they can do it until they try and fail.
if you need direct help: etower.766@netzero.net
if this has been helpful I would appreciate your vote here.
Steve
Aug 10, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
People on tv are blue
you will need to index the color wheel in order for it to have the correct tints
Sep 26, 2008 | Samsung HLP6163W 61" Rear Projection...
Samsung HLP5063WX/XAA 50" DLP
Here is a site for ColorWheel replacement, which is what you need to do if you hear that screeching or fan running noise coming from your TV. Sometimes the wheel just explodes which gives you no picture.
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Sep 29, 2007 | Samsung HCM4215W 42" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
62 people viewed this question
Henry  Thomas
Henry Thomas
