Question about Innocom Technology IT-MI201 Modem
Innocom IT-MI201 win7 - Innocom Technology IT-MI201 Modem
I have an inncom thermostat in my room, and it keeps doing a thing where it will turn on, but only the fan, for about 3-15 minutes, then it will shut off. And I can only get the thing to turn on when it is...
if you set the t stat in VIP mode you can operate the fan manually but you shouldnt have to do this. it sounds like the t stat is losing communicatio with the HVAC reciever board.
Jul 08, 2010 | Innocom Technology WIRELES ADAP|INNOCOM...
Is this modem compatible with windows 7
The compatibility generally occours while installing a softaware.
Its suppose to be comaptiable...
Jan 23, 2010 | Innocom Technology IT-MI201 Modem
I need to reset my router, the model is IT-WL540 please assist ASAP
On the back of the router is a reset button. This button has two (2 functions:
1. Reboot. When pressed and released, the Wireless Router will reboot (restart).
2. Clear All Data. This button can also be used to clear ALL Data and restore ALL settings to the factory default values:
To Clear ALL Data and restore the factory default values:
1. Power Off.
2. Hold the Reset Button down while you Power On.
3. Keep holding the Reset Button for a few seconds, until the RED LED has flashed TWICE.
4. Release the Reset Button. The Wireless Router is now using the Factory default values.
Hope that helps!
Jan 11, 2010 | Innocom Technology WIRELES ROUT|INNOCOM...
I NEED TO ENTER MY CODE FOR NEW HOOK-UP WHERE?
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 07, 2010 | Innocom Technology Computers & Internet
Driver
hi.
sir what u can do is that u can try this website,it might help u.........
moz-screenshot.jpgmoz-screenshot-1.jpghttp://www.dll-provider.com/download-k:need%20the%20driver%20for%20INNOCOM%20PCI%20IT-WL543%20Wireless.html?aff.id=1950&aff.subid=3
OR
if it is helpful pls. rate this solution for me pls....
Feb 09, 2009 | Innocom Technology WIRELES ADAP|INNOCOM...
Driver
use your control panel, go to control panel clickon printers and other hardware, then phone and modem options then click on the advanced at the top and a menu should come up with the manufacturer name for the modem it will be high lighted in blue, then write it down and find it on the web. if not just log into the internet select your add hardware and use the install wizard to find the drivers for you and it will down load them for you. XP can be a wonderful program with this type of help.
Dec 12, 2007 | EZ Media MI201 (MDEZHDV92PCIR) Modem
Innocom Technology IT-MI201 Modem Logo
Top Innocom Technology Computers & Internet Experts
David Payne
David Payne
Are you an Innocom Technology Computer and Internet Expert? Answer questions, earn points and help others
