Question about Sony BRAVIA KDL40BX450 40 Inch 1080p LCD HDTV
SONY KDL40BX450 will not turn on
Red standby light will not always come on when plugged in. After repeated attempts of unplugging and plugging TV in red standby light comes on . Sometimes green light can be turned on manuely or with remote after many attempts. Tv then works until it is turned off. Retual must then be repeated when viewing TV is desired next time.
mistersony
  • 320 Answers
SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Posted on Oct 20, 2008
SOURCE: TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
Posted on Feb 23, 2009
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
Posted on Jun 24, 2009
SOURCE: sony bravia tv not working
Hi Elaine!
Please follow the steps mentioned below to troubleshoot the issue:
If the TV standby light is blinking for five times then you may perform the steps given below:
(i) Turn off the TV then disconnect all the cables from the TV.
(ii) Next, reconnect all the cables after two minutes.
(iii) Please make sure that the power cable from the TV is directly connected to a functional wall outlet.
(iv) Next, you may try resetting the TV to the original factory settings.
Please follow the steps that are mentioned below to reset the TV to the original factory settings:
(a) Turn ON the TV.
(b) Press and hold the Power button on the Remote Control supplied with the TV, then press the Power button on the TV front panel.
(c) Release the Power button. The TV will turn itself off, then back ON again.
(d) Next, release the Reset button on the Remote control.
If the standby light still blinks then the issue may be with the projection lamp in the TV and requires replacement.
Posted on Jul 12, 2009
  • 194 Answers
SOURCE: My Sony Bravia Kdl40v300 will not turn on When I
sorry. Hope you still have a waranty. This is not an uncommon problem with the sony's. 99% chance that the panel went out. Could also be a balance board issue, but usually not. Call Sony for an authorized repair center
Posted on Dec 24, 2009
Tv stuck on standby
The internal power supply may have failed.
Nov 04, 2013 | Televison & Video
I have a Sony Bravia, Model: KDL40BX450. It's red 'stand-by' light has suddenly gone off and I cannot turn on the TV. What's going on?
I have a sony Bravia 40" LED TV. KDL40BX450.When I turn my set on it has no sound. And the standby light blinks three times and pauses. I have unplugged it. and even reset it to the factory settings. And as long as the set is on the sound works.but once I turn it off. and turn it back on later.it does the same thing again.no sound. what could be wrong .And is there anything I can do to maybe fix it.
Dec 12, 2012 | Sony BRAVIA KDL40BX450 40 Inch 1080p LCD...
Tv will not stay on standby timer light flashing
On Sony the standby or red is for shutdown---
If you unplug the set and plug it back and turn it on and it repeats this look to see if the light is either constantly blinking or blinking a specific number of blinks---specific number would be an error code.
Apr 29, 2012 | Televison & Video
My PS3 keeps cutting off by itself. It will cut off while I play a game and the red standby light cuts off as if the power cord is not connected. Then, when I try to unplug it and plug it back in, the...
ok whats happened there is your ps3 power cord has become a bit loose in their so get a expert to fix it
i would always recommend a expert to do it never do it unless you know what to do
Jan 11, 2011 | Sony Playstation 3 (PS3) Console
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Standby light flashes but tv will not turn on
Ur high voltage is dying.The block of plastic with a red wire with a cap hook to ur CRT(tv tube).The FBT,it call the Flyback transformer,that is dying.That must be replace.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Problem turning on the TV
I have the same problem. Did you find a solution?
Oct 24, 2007 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Sony BRAVIA KDL40BX450 40 Inch 1080p LCD HDTV Logo
309 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
