Question about Pristine Living PL-1018 Kitchen Hood
My Prestine living hood bulb burnt out and I threw it away. But I can't find a replacement as it is a special type. The lenghth is lesser that regular appliance bulb.
  • Anonymous Feb 01, 2009
    kitchen hood bulb is blown out , can/t find the replacement bulb anywhere.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Need to replace the halogen bulb in a Secura 798HD table top oven. Everything else seems to be working. If someone does these kind of repairs it would even be better.
it is possible to do it your self but if the oven has some years on it the cover for the bulb may be stuck from old burnt grease
to add to your problems is it a special bulb only available from the spares department of a service center as the glass for the bulb has to heat resistant to above 350 C so any old bulb will not do
you could get a service technician out to do the job if you have one close by
Nov 29, 2016 | In Microwave Ovens
Headlight bulb burnt out. Upon replacing bulb, found the plug had been hot and burnt the plastic mold around plug. The prong hole was also black. New replacement bulb also burnt out immediately.
Welcome to Fixya
This is a common problem with headlight bulb higher than the 60W bulb. You can actually replace the plug with a ceramic type so that it wont melt. This happens to my car. I am using halogen bulb and burned the plastic mold together with the bulb. Replacing the plastic mold with ceramic type mold fixed the problem.
Thank you for using Fixya!
Jun 14, 2011 | 2006 Pontiac Grand Prix
My drivers side headlight has burnt out and I would like to know how to change it?
Open the hood and locate the offending light twist it approx. 1/4 turn and remove it from housing. If you have not already done so unplug it from harness and replace with same type bulb.
Jan 20, 2011 | 2001 Saturn S-Series
I was stopped by a cop saying I had no taillights, I wasn't able to get to the mechanic right away, the next night my daughter had a similar experience- besides the bulbs, what else would I need to check...
Before buying a bulb/bulbs I would check the fuse box located in the engine compartment. Check the fuse labled 'tail lights' and 'stop lamp'. The fuse can burn out due to a faulty failed bulb. If the fuse is open (technical language for burnt) then don't replace it until you replace the bulbs as a faulty bulb probably caused it to blow. When bulbs die, they sometimes short out On the other hand - I recently had one tail light go out ( I was lucky and caught it and replaced the bulb right away). A week later the other one was burnt out. I'd bought a two pack of bulbs, and had put it in the glove box so the bulb was handy and no tools are needed to replace it. Just open the trunk and remove the cover behind the light. The socket comes out with a counterclockwise twist. Mine were in pretty tight so be careful if you use pliers to grab the socket as they're plastic. Pull the bulb straight out and get the exact replacement. The bulb number is printed in very small print on the bulb itself or on the socket depending on bulb type. The autoparts store clerk will help you get the correct bulb much faster if you have the old bulb in your hand.
Dec 13, 2009 | 2000 Toyota Camry
Changing the low beam headlights on a 2004 Jaguar X type
there are to metal clamps on the back of the headlamp assembly and remove the cover
Sep 04, 2009 | 2004 Jaguar X-Type
Pontiac torrent headlight burnt out? Can I replace it myself?
yuo dont need headlight. the bulb is removable from inside under the hood.. just pull the connector off and remove the plastic hold down. you should be able to pull the bulb out.i hope it was helpfull. thanks
Jan 28, 2009 | 2006 Pontiac Torrent
Changinh headlight with new
Is the problem a burnt bulb or broken headlight? The bulbs come out from under the hood...there is a black serrated knob to losen and pull out...the bulb should be resting within the piece.
Don't touch the bulb with your fingers....only the perimeter. Bulbs can be regular or special high intensity ones...at any parts store. Easy to do.
Nov 23, 2008 | 1993 Volvo 940
When trying to replace my cooker hood lights the new bulbs blow as soon as i put them in. Is there a fuse I could try replacing?
Wouldn't expect a fuse to be the problem with those symptoms.
You need to fish out the old bulbs (that is, the last ones you had that worked for any period of time) and read the ratings off them. You are particularly interested in a number followed by a capital V (so this might be 12V, 120V, 230V or any of a number of others). This is the supply voltage they are are compatible with.
You need to be sure you buy replacements which have the same voltage rating. If your replacements are rated for a lower voltage, they will expire in a blaze of glory the instant you apply power. If they're rated for a higher voltage, they'll glow very dim and yellow.
You have a little more leeway withthe wattage rating (a number followed by a W, eg 15W, 25W). It's safe to go lower (though less bright), and probably OK to go a tiny bit higher but if you go much further than the enclosure is designed for, you risk problems with overheating.
If you're certain you have the right bulbs but the problem hasn't gone away, you'll need to come back with more information. It might help to know: Brand & model of the hood in question, what rating (both V and W) the bulbs are, how long they last, what it looks like when they blow (bright white light, or brilliant blue flash), what it says on the rating plate of the hood, and what part of the world you live in (tells us what the power supply is like).
But my first guess would still be that the new bulbs are the wrong type.
A.
Nov 15, 2008 | Kitchen Ranges
Bulb holder, case
Good Day;
Yes, I can Help>
Oct 01, 2008 | Televison & Video
Pristine Living PL-1018 Kitchen Hood Logo
104 people viewed this question
Top Pristine Living Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Pristine Living Kitchen Range Expert? Answer questions, earn points and help others
