Question about Discovery Channel Discovery Exclusive Sky & Land Telescope
Need manual for kids sky and land telescope - Discovery Channel Discovery Exclusive Sky & Land Telescope
Where can I find an instruction manual for edu science land and sky 360 (50mm refractor) telecope?
Check the manufacture. If you didn't have it too long take it back to T...R...US and go elsewhere and by a good scope.
Aug 31, 2014 | Edu-Science Edu Science 50mm Telescope...
Tip
So you bought a COMPUTER GOTO Telescope!
First the good news. Personally I believe a computer GOTO scope or a Dobsonian telescope with PUSHTO makes a great telescope for a beginner.
Why? Because you can use the hand controller to help you find those dim sky objects that are almost invisible from a typical suburban observing site with lots of light pollution.
Also if you pay attention you will learn many of the brighter stars in the sky, the Constellations, and the location of many of the brighter sky objects.
Now for the bad news. There are many cheap goto telescope systems being sold that do not work as advertised, and you still need APERTURE to see many of the dimmer sky objects. So a goto with a little 70mm refractor mounted on it will frustrate you!
Right off the bat let me list a few links to the better goto and pushto telescopes. See these web sites:
http://www.telescope.com/control/product/~category_id=intelliscopedobs/~pcategory=dobsonians/~product_id=27183
http://www.meade.com/lx90/index.html
http://www.celestron.com/c3/product.php?CatID=9&ProdID=33
http://www.amazon.com/dp/B0023RRD9Y/ref=asc_df_B0023RRD9Y994674?smid=ATVPDKIKX0DER&tag=googlecom09c9-20&linkCode=asn&creative=380341&creativeASIN=B0023RRD9Y
This is just the mount, you need to also buy the telescope tube. I would suggest a 6 inch Celestron SCT Optical Tube Assembly (OTA), and also what is called a "dovetail" metal bar to mount the scope tube onto the side of this goto mount.
http://www.celestron.com/c3/product.php?CatID=8&ProdID=31
http://www.celestron.com/c3/product.php?CatID=11&ProdID=392 This is a computerized equitorial mount. It works differently than the scopes listed above.
http://www.celestron.com/c3/product.php?CatID=13&ProdID=415
That should be enough to get you thinking! All of the ones listed above will have good goto performance IF:
You read the manual TWICE!
Test the scope out INSIDE in the light before you take it out at night and learn how to operate the hand controller.
Follow all the instructions in the manual about training the drives and or calibrating motors.
Accurately center BOTH alignment stars. Yes you will need to learn the names of a few stars in the sky.
AND NEVER plug or unplug the hand controller while the scope is turned on! This can burn out the circuits in the scope!
I would suggest that your first goto telescope be like the very first link above; a Dobsonian with a PUSHTO hand controller. This is the cheapest and best entry point to own a computer telescope. Yes, the prices are a little higher and old timers will tell you you do not need the computer goto to find objects in the sky.
I disagree! Beginners get very frustrated with the hobby when they cannot find anything other than the moon or several bright planets; or search for several hours to find one other dim sky object. Also most of us live in light polluted cities, and hopping around from star to star to find something is not really possible.
Add eye problems like cataracts and you will only see 6 or 7 stars in the sky, not enough to use to find other sky objects.
If you decide to buy a GOTO scope, please attend several star parties at your local Astronomy club. Many of the members will have this kind of telescope. You can ask questions, and they may even let you DRIVE the telescope!
Remember, READ the manual, train the drives, and do all the other initial setup that the manual recommends. Yes, you will need to know the names of a few bright stars in the sky! Your new computer telescope is not as smart as 3CPO in Star Wars!
Clear Skies!
Joe Lalumia
on Dec 31, 2009 | Optics
I need the instruction manual for venture rx-9 reflector telescope
http://ventureoptics.com/RESOURCES_files/Telescope%20Instruction%20Manual-NEW.pdf The user manual is available to download from the manufacturer's website, along with additional support resources.
Telescopes Sky Earth
Feb 02, 2013 | Optics
I took apart my edu science Land and Sky 90X telescope and didn't realize there were two lens at the large end until they slipped apart in my hands (one thicker than the other) and got mixed up. There was...
You will need to experiment replacing the lens in various configurations to see what works.
Next time NEVER disassemble an eyepiece or a telescope lens. Only the outside surfaces ever need cleaning.
Apr 09, 2011 | Edu-Science (10166) Telescope
I have a 90x Land & Sky telescope and the 20mm eyepiece has disappeared. Is it possible to get a replacement?
Yes -- eyepieces come in 3 sizes .965, 1.25, and 2 inch sizes. Measure the hole in the focuser and buy the correct size.
Here are two retailers:
http://shop.telescope-warehouse.com/
http://www.agenaastro.com/
Dec 15, 2010 | Edu-Science (10166) Telescope
Where can i get the eye piece for my Orbitor Land & Sky Telescope ?
This scope uses .965 eyepieces. The best place to find them would be on Ebay. Unfortunately, you can not get great selection (look for Konig or Kelner format)
If you are really interested, buy a .965 to 1.25 eyepiece adapter. There are many 1.25 eyepieces out there.
Nov 14, 2010 | Citiwell International Orbitor 7036...
How to use telescope at night?
Many people have the same problem-- with these small telescopes you are stuck with seeing only the moon, and several other planets, and maybe a few bright star clusters.
These are all TINY objects (except for the moon).... when you look through the telescope you are looking at a section of sky about the size of your fingertip held at arms length-- the scope must be pointed DIRECTLY at the object. Practice on the moon first-- and then try to find Saturn which is up in the sky right now-- it looks like a dim (slightly yellow) star.
Download a free star chart at www.skymaps.com ---
Apr 01, 2009 | Edu-Science (10166) Telescope
Discovery Channel Discovery Exclusive Sky & Land Telescope Logo
61 people viewed this question
Top Discovery Channel Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Discovery Channel Optic Expert? Answer questions, earn points and help others
