Question about Dometic Rooftop RV Air Conditioner
Fan hums I have a motorhome with 2 ceiling AC units. One is giving me a problem. When I turn the heat/cool switch to off and put the fan switch to on from auto all the fan does is hum. I'm hoping that it only needs some oil. How would I find where it is located to get to it? It is Dometic model #620426321.
  • cooperc866 Jan 27, 2009
    I was at the computer yesterday so it was easier to ask the question than to open things as i usually do to find out. After reading your responce I went up and after removing 4 screws there it was. I moved the squirl cage around a few times. It didn't move as free as it should, probably hadn't been used in months and we just bought the motorhome. I had my husband turn on the fan switch and it still wouldn't move so I spun the cage carefully and had him turn the fan switch again and it took off. After a few minutes I turned it off and it started the next time so I assume we need to give it a lube rather than it be a problem with a start cap or centrifical switch???? but I think we have found the problem which is the most important thing as the temp today is going to be 80. Ha and thank you. I'g going to put this site in my favs.
  • 96 Answers
Go on top the RV to the unit and take out the screws holding the cover on and the fan motor is under it
Posted on Jan 27, 2009
Trying to find manual for a Hampton Bay ceiling fan. I have two. Tag on fan says model: AC-552AL, Item# 154620 NN, Another sticker on fan says 05/02 E192641 UL Listed CEILING FAN 47BF
You should find what you need here:
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Parts-Remote-Wall-Controls/Hampton-Bay/N-5yc1vZbvmuZp4
Apr 03, 2017 | Hampton Bay Dryers
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
My blower on my carrier furnace unit won't turn off? a/c or heater doen't turn on.
gas furnace??? check the start capacitor, put unit in ac mode and see if fan comes on(switch fan to on at thermostat) if it does not a fan problem or capacitor problem. when in cooling mode thermostat controls fan, when in heating mode, furnace controls fan
Feb 18, 2015 | Carrier Heating & Cooling
On 1994 southwind motorhome rear ac unit clicks but fan doesnt blow but it lights up as unit is on
Check in your unit for a switch on side wall or near ceiling for selecting which AC unit gets power. Should be front, back, or both. Usually black knob to turn. Sounds like 12 volt power getting to it that tells it what to do, but also need to switch over to allow 120VAC power to actually supply power to it for running fan, compressor etc. Be sure to check all breakers in panel as well. You will probably not be able to run both at same time unless plugged in to 50amp or plugged in to 30amp, and generator running as well. I'm thinking a 94 only has 30amp power cable anyway.
Oct 26, 2013 | Dometic Rooftop RV Air Conditioner
I have a rooftop ac unit on my popup that was replaced two years ago. The unit works fine but I would like the fan to shut off when the compressor isn't running. Is there a switch for putting the fan...
Please describe your controls. Does it not have low fan, high fan, low cool, high cool on the dial at ceiling? If yes, low cool or high cool setting should shut it down when temperature is reached via thermostat dial.
Aug 29, 2011 | Dometic Rooftop RV Air Conditioner
Unit will run if the thermostat is switch on ON, but if left on AUTO unit will hum and won't run.
For most Thermostats on and auto is for the fan switch function. There s usually another button for heat off cool. When you turn a\c or heat on , the fan switch should be on auto.
Jul 10, 2009 | Heating & Cooling
One day my RV Coleman ac just quit running on low cool but every other setting works fine. Any ideas?
Is your Air Conditioner run with a wall mounted thermostat or the ceiling pack controls? If it is the ceiling pack controls, then your selector switch has gone bad and needs to be replaced. This is located in the ceiling pack itself and is relatively easy to do. You can easily test it with an Ohmmeter, going through these steps:
To check the selector switch, remove wires from the terminals
and rotate the switch to the proper position and read
continuity as follows:
Terminals Switch Position
L-1-3 Lo Heat
L-1 Lo Fan
L-2 Hi Fan
L-1-4 Lo Cool
L-2-4 Hi Cool
* If you do not wish to remove the wires from each terminal,
disconnect the 9 pin plug from the a/c unit.
Hope this helps,
Jeff
Jun 27, 2009 | Coleman Mach 15 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
176 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
