Question about Kenmore Elite 45986 Front Load Washer
Coder f2o on the panel of our kenmore 42936
Won't drain water
won't open door
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    those washers are good for geting blocked up pumps.remove bottempannel and you will see pump .clean that puppy out and then try again
  • 5,911 Answers
"F20" is a No Water Detect" error. The following link explains:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
Although the error code could have several meanings, start with the simple items, first. (i.e., the post by appldoctom). The drain pump is a likely cause of several error codes. If the you've never checked a drain pump on one of these model washers, please follow the additional hyperlink to ensure you have the proper guidance.
Double-check your connections to the pump and verify it is operating. If anything has been caught in the pump for any significant period of time, it may cause irreparable damage to the motor motor and/or impeller. If the pump fails to run, or if the pump fails to pump sufficient volume, the manufacturer recommends replacing it.
Make sure you read through the link thoroughly and verify everything. Some of these error codes can have multiple causes. if you still have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Jan 27, 2009
42936- My kenmore elite he front-load washer w/steel tub-has scrapping/unbalanced like sound coming from washer when in spin cycle, then after completed there is shredded plastic/fiberglass like mater
Sound like one of the wights has come off or is loose and damaging the drum and other parts take a under the machine and you may see the problem
Jul 29, 2014 | Kenmore Washing Machines
Won't drain the water anymore
Drain motor is usually located on the bottom of the machine. Hopefully you have an access panel separate from the main door panel. Should be a hose coming in and a hose going out. Put the machine in spin cycle and see if you can feel the pump spinning. If the pump is very hot, chances are something is blocking it. They will usually have an access port that can be opened up just for this reason, be ready to catch the water when you open it up, and please turn the machine off first. If you get no sign of life from your pump it may have died. Also check for any blockages in the drain lines. All of this should be easily accomplished with a couple screwdrivers and towels
Apr 10, 2013 | Baumatic BTWM4 Front Load Washer
Kenmore 110.42822 won't spin
This should take 30 minutes: Remove the panel that is located below the front door, there are 3 small screws located at the bottom that hold this... you will see the water pump, which has a access screw plug. Unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean out, then put everything back... this should fix the issue.
Mar 31, 2013 | Kenmore Washing Machines
The washer broke filled with water and won't drain
see this causes and fix it. God bless you
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Sep 28, 2012 | Kenmore Washing Machines
My Kenmore H2t front load washer won't drain and
Hallo there
So it will not do what it is told. This happened to my Candy machine the other day. It was finished and I opened the door, out came water and I got 5 towels on the floor to dry up the water. Closed the door again and put empty water on, it emptied the water, stopped the machine and put spin on and it made it.
My experience ,learned the hard way, to wait long enough after the machine stops as well as between changing programs.
I this will be of some use to you.
Kolbrun
Apr 15, 2012 | Kenmore Washing Machines
The door lock won't open. I unplugged unit to reset, but still can't open door.
try finding the manual release..on my bosch nexxt 300 there is an access panel on front lower right of unit for the drain if i open it and reach up there is a cable to pull on to manually unluck the door...have wet vac ready as there might be water from a clogged drain causeing washer to keep door locked
Oct 10, 2011 | Frigidaire ATF6000ES Front Load Washer
Wsaher will not drain or spin, shows f2 code 42936 200 front loading
will not spin with water in it drain then try spin only if it spins clean out filter and or pump
Dec 21, 2009 | Kenmore Washing Machines
Kenmore HE4 washer won't drain. gets code f02
take bottom panel off ,,it has a screw out filter,,this filter fits directly in your pump..its clogged,,your pump is the fist part you see when you open bottom panel
Dec 24, 2008 | Kenmore Elite 45986 Front Load Washer
Door won't open
disconnect power , remove bottom panel, reach up inside where latch asm is and you can feel tab on bottom of door latch pull down and door will open drain water out of tub and check your drain pump for obstructions. be careful of water left in pump have some towels ready
Dec 12, 2008 | Kenmore Elite 45986 Front Load Washer
Door will not unlock need to get clothes out
whooaaa put down the ha\mmer, it wont open if theres too much water in unit. there is a manual release, but you have to remove the lower service panel to reach it.after removing the panel youll need to stick your hand up along side the front panel right hand side. the lowest ponit of the door latch/lock assy has a quarter sized handle that youll need to pull to relesae the door mechinism., WARNING if there is water visble through the door and you open it you will get wet...before trying the manual release option turn off the water supply and set the machine for drain/spin cycle and see if the drain pump turns on to release enough water to opne the door on its own,if the drain pumps only humms and doenst drain, then theres the issue you have something stuck in the drain pump. in which casse youll need to remove the lower panel and free the clog anyway.
Oct 12, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
66 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
