Question about HP 48gx Calculator
Try to recover memory
Variables have gone, now I have two soft black keys at A B menu keys areas that say D.01 and D.02, press the D.01 and D.02 keys D.01 D.02 words appear in status area next to HOME
  • HP Master
  • 8,016 Answers
Press [Right Shift cyan key][ ' ] to return to the [HOME] folder. Press the [MTH] under the white [A] key and the math tools will reappear [VECTR], [MATR], [LIST], [HYP], [REAL], [BASE] etc.
Hope it helps.
Posted on Nov 09, 2009
Ti 83 will not power on replaced all batteries
When you clear memory, the contrast sometimes changes. If the screen
is faded or blank, adjust the contrast by pressing 2nd and up- arrow or down- arrow keys .
Resetting RAM restores RAM system variables to factory settings and
deletes all nonsystem variables and all programs. Resetting defaults
restores all system variables to default settings without deleting variables and programs in RAM. Resetting RAM or resetting defaults does not
affect variables and applications in user data archive.
Tip: Before you reset all RAM memory, consider restoring sufficient available
memory by deleting only selected data.
To reset all RAM memory or RAM defaults on the TI-83 Plus, follow these
steps.
1. From the RAM ARCHIVE ALL menu, select 1:ALL RAM to display the
RESET RAM menu or 2:Defaults to display the RESET DEFAULTS menu.
2. If you are resetting RAM, read the message below the RESET RAM
menu.
• To cancel the reset and return to the home screen, press .
• To erase RAM memory or reset defaults, select 2:Reset.
Depending on your choice, the message RAM cleared or Defaults
set is displayed on the home screen.
Mar 25, 2012 | Texas Instruments TI-83 Plus Calculator
steps.
menu.
When i turn on my TI-84 silver edition only thing i see is a blinkin blaxk square on the top let corner.hiting any key wont do nothing it stays the same. Need help
If a checkerboard cursor ( black square ) is displayed, then either you have entered the maximum number of characters in a prompt, or memory is full.
If memory is full:
-Press 2nd then MEM and then 2 to display the MEMORY MANAGEMENT / DELETE menu.
-Select the type of data you want to delete, or select 1:All for a list of all variables
of all types. A screen is displayed listing each variable of the type you selected
and the number of bytes each variable is using.
-Press up-arrow and down-arrow keys to move the selection cursor > next to the item you want to delete, and then press DEL
Mar 23, 2012 | Texas Instruments TI-84 Plus Silver...
If memory is full:
We have a TI-89 and it is froze on the home page. we tried holding the 2nd button , left arrow , rigth arrow and pressing the on button. it comes up with installation in progress , but when that is done it...
Hello.
Here is a procedure to reset the TI-89 to factory settings (found online):
  • Press the "Snd Mem" key to display the memory screen.
  • Press the "F1" key.
  • Press the navigation key to select the "RAM" icon, then select "1: All RAM" to erase all data and programs from the random access memory and press the "Enter" key, or select "2: Default" and press the "Enter" key to reset all system variables to original factory settings. This preserves any user-defined variables, functions and folders.
  • Press the navigation key to select the "Flash ROM" icon, then select "1: Archive" and press the "Enter" key to erase all data and programs from the read-only memory or select "2: Flash Apps," then press the "Enter" key to erase all applications from the Flash ROM. Select the "All Memory" icon and press the "Enter" key to erase all data, programs and flash applications from the RAM and Flash ROM.
  • Hope this helps.
    Aug 21, 2011 | Texas Instruments TI-89 Calculator
    My HP 48GX just displays a black (all pixel) display screen with one vertical stripe down the middle. I tried reset button and now it displays 2 vertical stripes (the new one divides the right half in...
    I just had this exact problem so I reset the memory as instructed below. Know I am back in business. Memory reset A memory reset will return the HP 48 to its factory-default state, which will erase all stored user memory. Use this feature very carefully.
    1. If necessary, turn the calculator on.
    2. Press and hold the ON+A+F keys simultaneously.
    3. Release all three keys at the same time. This should cause the calculator to display the message "Try to recover memory?"
    4. Press the A key to attempt to recover memory or the F key to erase the user memory. When A is pressed, occasionally the objects in memory are recovered in new sub-directories of HOME labeled D.01, D.02, et cetera, although there is no guarantee that all of the variables will be recovered. Pressing the F key will cause all information stored by the user to be erased from calculator memory. This will also affect any RAM card that is merged with main memory. If the card is not merged or it is write-protected, it will not be affected by this reset.
    Hardware symptoms and solutions I. The display screen has a blue/purple blotch of color, even when the unit is off The screen is damaged, and the calculator requires service. Please contact HP . II. All of the pixels on the screen are lit (blue)
    1. Try to adjust the contrast by holding down the ON key and repeatedly pressing the [ - ] key.
    2. If the screen is still dark, try to halt the system using the keyboard.
    3. If this does not correct the problem, try to reset the system using the reset hole with the batteries removed.
    4. If this does not work, remove the batteries and let the unit sit for 48 hours. After 48 hours, replace the batteries. If the problem persists, attempt a memory reset. Although removing the batteries for 48 hours should erase the user memory, performing a memory reset will ensure that the calculator is reset to its factory defaults.
    5. If the problem persists, the unit requires service. Please contact HP .
    Dec 30, 2010 | HP 48gx Calculator
    How do i format my sd card via bluetooth
    I'm sorry but u have to manually format ur memory card using the phone or a computer...
    back up ur files first...
    To format a microSD memory card follow the steps below:
    1. Insert a microSD memory card into the memory card slot, located on the left side
    2. From the standby screen, press the right soft key for Menu
    3. Select My Stuff (7)
    4. Highlight the On Card tab, using the left or right navigation keys
    5. Highlight either Audio, Graphics or Videos, using the navigation keys
    6. Press the left soft key for Options
    7. Select More (4)
    8. Select Memory Card Settings (2)
    9. Select Format (2)
    10. Press the left soft key for Yes to confirm formatting the microSD Memory Card
    11. If prompted to rename, press the left soft key for Save
    Dec 14, 2009 | Samsung Propel A767 Cell Phone
    How do I use a micro sd card to save photos?
    Before doing the steps pls format the memory card first
    To transfer pictures to memory card follow the steps below:
    1. Remove the memory card slot cover, located on the upper right side of the handset
    2. Insert a microSD memory card into the memory card slot, until it locks in place
    3. From the standby screen, press the left soft key for Menu
    4. Select My Stuff (7)
    5. Highlight Graphics, using the navigation keys
    7. Select Open (1)
    8. Highlight desired Photo, using the navigation keys
    9. Press the left soft key for Options
    10. Select either Move (4) or Copy (5)
    11. Select either Selected (1) or Multiple (2)
      • If Multiple, highlight each Photo, using the navigation keys
      • Press thecingular%20logo%20only.jpg key to check each Photo’s box
      • Press the left soft key for either Move or Copy
      • Highlight Memory Card, using the navigation keys
      • Press the left soft key for Select
      • Highlight the Graphics folder, using the navigation keys
      • Press the left soft key for Options
      • Select Paste to selected folder (2) to Move or Copy the Photos to the microSD memory card
    12. Highlight Memory Card, using the navigation keys
    13. Press the left soft key for Select
    14. Highlight the Graphics folder, using the navigation keys
    15. Press the left soft key for Options
    16. Select Paste to selected folder (2) to Move or Copy the Photos to the microSD memory card
    17. Remove the microSD memory card from the memory card slot
    Oct 19, 2009 | Samsung SGH-A707 Cellular Phone
    T-mobile dash text problem
    You can not recover lost texts. once gone, they are gone.
    Try to get credit from your provider.
    To correct issue do a hard reset:
    The T-Mobile Dash™ includes a button sequence which can be utilized to perform a hard reset. This method is much more difficult to do but it will perform the reset if the menu options are not available.
    Note: Before attempting this procedure make sure to backup your data using ActiveSync. All unsaved data will be lost.
    Hard Reset
    1. Power the device off by pressing and holding the Power key.
    Note: If device is unresponsive remove the battery.
    2. With the phone off press and hold both soft keys (The two keys directly under the screen, used to open menus.)
    3. While continuing to hold the soft keys, press and hold the Power button for 1-2 seconds.
    4. Continue holding the soft keys until you see a message that starts with This operation will delete….
    5. Release the soft keys.
    Note: If you see the standard boot up screen load steps 2 and 3 were not performed correctly.
    6. A boot splash screen will appear, followed by a black screen prompting: Press Send to restore factory defaults, Other keys to quit
    7. Press the Send key.
    8. When prompted to powercycle device, select Ok
    Note: Once the hard reset is performed it could take up to a few minutes to completely boot back up.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Jun 15, 2009 | T-Mobile Dash Smartphone
    Memoty full mesage
    this happens quite abit with Samsung devices. Try to make sure you can move your pictures to your computer. Then, reformat your card.
    1. Insert a memory card into the microSD slot, located on the bottom left side of the handset
    2. From the standby screen, press the left soft key for Menu
    3. Select Fun & Apps (6)
    4. Select Files (1)
    5. Select Memory Card
    7. Select Memory Card Info (5)
    8. Press the left soft key for Format
    9. Press the left soft key to confirm Formatting the Memory Card
    You can also reset the MMS option on your Samsung with this star/pound code:
    Enter *2767*667#
    E2P MMS Reset Is Displayed When successful
    Feb 02, 2009 | Samsung U900 Soul Cellular Phone
    HP 48gx Calculator Logo
    150 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
