Question about Boxlight SP 6t Multimedia Projector
Boxlight CP-670K no video
The unit turns on, lamp function, however, when auto search for connection it does not find video connection. I tried both analog and digital ports. I did noticed that there are only two options available when ''menu'' is pressed.
I did not find the actual model of my project which is "CP-670K."
  • 2,237 Answers
Change cables, and then check the resolution. it doesn't do digital video.
Posted on Jan 27, 2010
CP745ES How do you reset the lamp hours?
You have to enter the factory menu by pressing a sequence of buttons when the projector is on: Power > Auto > Menu. I remember it by the female name Pam.
Feb 21, 2012 | Boxlight CP-745E LCD Projector
My light comes on dim then goes off an the thing still run a fan and look like it on??? please help
it's either the lamp or the ballast. check the inside of the lamp. if you have bulges, black spots, flaking or fogging, replace the lamp. if the lamp is ok, replace the ballast.
Jan 01, 2010 | Boxlight CP 310t Multimedia Projector
Cant find source with a vga or s video
depends on the model. please provide more info.
Sep 04, 2009 | Office Equipment & Supplies
Boxlight cd-850m won't turn on
You must reset the lamp timer after you replace the lamp before the unit will turn on. Do this:
Power on the unit. On the projector's keypad, hold down the the two volume keys simultaneously for 10 seconds. At that point the LED will turn green. Now you can turn on the unit again and it should work.
Feb 12, 2009 | Boxlight CD 850m Multimedia Projector
in the menu option,under signal source , select option manual(deactivate auto search) & then connect inputs & try selecting each source from the remote
If this does not work then the main board is at fault
Jan 26, 2009 | Boxlight Office Equipment & Supplies
Do you know any sights for to view Boxlight manuals online?
you can try www.projectordoctor.com. if you don't see the link for it, scroll down to see if the model is the same as other brands. some of the boxlight projectors are made by sanyo and infocus.
Sep 27, 2008 | Boxlight CP 310t Multimedia Projector
Boxlight cp-310t won't display image
loose connection. possible crack on main board. needs to be sent in to have a look at.
Aug 16, 2008 | Boxlight CP 310t Multimedia Projector
Lamp shuts down after startup
it is the power supply/ballast. when you first turn it on, the caps on the ps/bal charge then discharge when the lamp is to strike. if the caps are dried out (from excessive heat), it takes a while to build a charge. so the power drain from striking the lamp brings the ps/bal into shutdown. after you try again, the caps are now up to full power and everything is fine. but every time you unplug it, you'll have the same problem. replace the power supply and ballast.
Dec 11, 2007 | Boxlight CP 19t Multimedia Projector
Boxlight SP 6t Multimedia Projector Logo
85 people viewed this question
Top Boxlight Office Equipment & Supplies Experts
jasbo
jasbo
Computer Links
Mike Charette
Are you a Boxlight Office Equipment and Supply Expert? Answer questions, earn points and help others
